Malkoff
Results 1 to 20 of 20
Thread: Olight H15 Wave (XM-L, 4xAAA) Headamp Review: RUNTIMES, BEAMSHOTS, VIDEO and more!
    Rolleye11 Olight H15 Wave (XM-L, 4xAAA) Headamp Review: RUNTIMES, BEAMSHOTS, VIDEO and more!
    Warning: pic heavy, as usual.
    UPDATE OCTOBER 10, 2013: This headlamp has been replaced by a new model, the H15S (XM-L2, 1xLi-ion, 4xAAA). Please see my review of the currently shipping version of this light.
    Welcome to my review of the H15 Wave headlamp, from Olight (or, I guess I should say, the H15 ). AFAIK, this is the first dedicated headlamp produced by Olight.
    I haven't posted too many headlamp reviews here, but I have worked with a reasonable number of different types and models of over the years. Most of the time outdoors, I've stuck with my Petzl Tikka XP2, or its predecessor the venerable Petzl Tikka XP (that I long ago modded with a SSC emitter). Indoors, I've tended to use my various Zebralight, Spark and ITP headlight models. I will review the H15 in those comparison terms.
    Reported Manufacturer Specifications:
    • Dual light sources: primary white light source uses Cree XM-L LED, while red auxiliary light source uses 2 pcs D5.0 LEDs.
    • Two brightness levels for white light: High mode: 150lm/3h (Without diffuser) -- 127lm/3h (With diffuser); Low mode: 5lm/72h (Without diffuser) -- 4.2lm/72h (With diffuser).
    • Two modes for auxiliary (red) light source: Normal brightness: 4lm/60h; SOS mode: 4lm/220h (reviewer note: this is actually a moderate strobe mode, not SOS)
    • Uses 4xAAA batteries
    • Peak Beam Intensity: 1050cd (primary white LED), 52cd (auxillary red LEDs)
    • Maximum throw: 65m (primary white LED), 14.5m (auxillary red LEDs)
    • Non-contact gesture control function, with advanced infrared sensor set
    • Special designed diffuser for short range lighting.
    • Ribbon indicator, can be set to strobe signal instruction.
    • Lens: Tough ultra-clear tempering glass, with anti-reflective coating
    • Split battery design can effectively reduce the weight-bearing
    • Water resistant: IPX6
    • Anti battery reverse protection
    • Impact resistant to 1m
    • Dimensions: 70mm/2.57" (L) * 53mm/2.10" (D)
    • Weight: 94g/3.32oz (excluding battery)
    • MSRP: ~$40
    My review sample was an early release, so it doesn't have the full packaging. I don't know what accessories it comes with, but you can see a 3-piece headband is included. The straps are all easily removable.
    First thing you will notice is that the battery compartment is separate from the head. There is spiral cable connecting the two (again removable from the clips on the headstrap, if you want).
    From left to right: Olight H15, Petzl Tikka XP2, Petzl Tikka XP, Zebralight SC30W, Spark ST5.
    Olight H15 Wave: (4xAAA): Head alone: 42.5g, Battery compartment alone: 28.4g, Battery compartment alone with batteries: 74.8g, complete unit (with headband and batteries): 141.5g
    Petzl Tikka XP (3xAAA): 58.3g, 94.4g (with batteries)
    Petzl Tikka XP2 (3xAAA): 52.3g, 88.4g (with batteries)
    Spark ST5 (1xAA): Weight, 41.5g, Length 58.4mm, Width 42.8mm (max body), Width 24.0mm (bezel)
    ITP H01 (1xAAA): Weight: 22.7g, Length 53.7mm, Width 37.2 (max body) or 15.4mm (bezel)
    Zebralight H31w (1xCR123A): Weight: 28.6g, Length 66.9mm, Width (bezel) 22.1mm.
    To overall shape and look of the H15 is similar to a number of headlamps, especially those using multiple AA or AAA cells. The H15 is somewhat distinctive (if that is the word ) in that it uses 4xAAA. I suspect most users would have preferred 2xAA for increased capacity with comparable weight.
    The H15 also separates the battery compartment from the main headlamp unit. This is not an uncommon design, and it does offer a few advantages (i.e., balances out the weight, and allows secondary signalling from the red LED on the battery case). Still, I personally prefer all-in-one solutions, as it removes the extra cabling.
    Build of the headlamp and battery case is plastic, as you would expect (as is common in AA/AAA consumer headlamps).
    The emitter is different from most comparably-priced consumer headlamps – you get the Cree XM-L emitter here. You also get the option for both throw and flood, thanks to a dedicated reflector and spring-mounted diffuser cover (scroll down for up-close pics and beamshots). There are also two fairly bright auxiliary red LED emitters on the front of the unit.
    The battery case has a secondary (and dimmer) red light that can be used for constant on or slow-flash/beacon mode. The main off/on switch for the unit is on the battery case (scroll down for a discussion of the UI).
    On the top of the front headlamp unit, you have a single large button to control modes. There are also motion-sensitive sensors on the front that can respond to hands-free "waves" to change levels. Again, see the UI discussion below.
    Headband is good quality, IMO. The top-strap is easily removable (if you don't want to muss up your hair too much).
    Let's take a closer look at how the batteries fit in …
    All-plastic multi-AA/AAA carriers tend to be somewhat limited in their battery hinge design and water-proofness. In the case of the H15, you rotate the designated side end-bracket until the end-piece pops open (i.e., out of the retaining clamps holding it down). There you will find an internal connection piece that swivels slightly from the end-bracket. There is an o-ring around this connection piece that helps to maintain water-proofness. There is also a connecting cable to ensure you don't lose the end piece.
    Pay attention to how the batteries go in – the labels on the plastic end-bracket are very small, and hard to see. But you can tell from the indentations on the metal contacts which way the cells are supposed to go (i.e., negative battery terminal to the raised dimpled connector piece, positive battery terminal to the flat connector piece). If you put them in wrong, Olight informs me the unit does have reverse-polarity protection.
    Although I find the carrier end-bracket a little fussy to re-seat and lock into place, I am more confident that it will maintain reasonable water-proofness than most other all-plastic headlamps I've handled. There is actually reasonable good tension on the end-bracket, holding it tightly closed (once you get it properly lined up).
    Prepare the light for activation by the switch on the battery pack. The switch is presumably electronic, and acts as a reverse clicky (i.e., click and release to turn on).
    When on, the red light on the battery pack will illuminate to a constant dim red. To change this to a slow strobe/beacon mode, press and hold the battery pack switch.
    With the battery pack turned on, you activate the headlamp output modes by clicking the switch on the head of the headlamp. Modes are advanced by clicking the head switch again, in the reoccurring sequence of Standby > White LED (Lo) > Red LEDs (constant), in a repeating loop.
    By default, you can the turn headlamp off/on in any given mode by a wave of the hand within 10 cm of the sensors on the front of the light (e.g. wave for off, wave again for back on).
    You can switch from Lo to Hi level on the White LED mode by a rapid double-wave of the hand over the sensor. You have to do this quickly though, or you will instead turn the light off and back on in the Lo mode. Similarly, a double-wave over the red LED mode will move you into red Strobe level.
    To deactivate the sensor and "lock" the given level you are in, press and hold the head switch for more than 3 secs. To re-activate the sensor, press and hold the head switch again for 3 secs, or click the switch to advance to the next mode.
    There is no mode memory, and the unit always defaults to Lo white mode and constant-output red mode when accessed in sequence from the main head switch.
    So, to summarize, clicking the head switch advances you between standby, white and red modes. A single wave can be used to temporarily turn off/on any given mode, and a double-wave will temporarily change the level within that mode.
    There is a diffuser cover for the emitter that is spring-mounted and held in place by a small clip on the base of the head unit. Press on the clip to release the diffuser for more throw.
    For information on the light, including how the wave sensor works in practice, please see my video overview:
    PWM/Strobe
    There is no sign of PWM that I can see, at any output level – I presume the light is current-controlled, as claimed.
    Olight reports a secondary red SOS mode (accessed by a quick double-wave when in red mode). However, this is actually a moderate strobe mode:
    Strobe frequency was 10 Hz on this red strobe mode.
    Note there is also a slow strobe/beacon mode on the battery pack red LED. The intensity is too low to detect with my sound card oscilloscope, but I timed the flashes at a rate of three times every two seconds (i.e., roughly 1.5 Hz)
    Standby Drain
    As both the battery pack and head switches are electronic, a standby current drain is always present when a battery is installed. Given the design of the carrier, I was not able to measure this current, however.
    The H15 uses a cool white XM-L emitter with a lightly textured reflector (LOP). Emitter was well centered on my sample. A spring-mounted diffuser cover allows you to diffuse the beam. Although the reflector is small, it is deeper than most headlamps I have come across.
    There are two red LED emitters on either side of the main white emitter. These were brighter than I've normally come across on headlamps.
    And now, the white-wall beamshots. All lights are on Max output on the identified battery type. Lights are about ~0.75 meter from a white wall (with the camera ~1.25 meters back from the wall). Automatic white balance on the camera for the cool white emitters (to minimize tint differences), daylight white balance for the neutral white ST5.
    Let’s start with un-diffused white beams. Note for the SSC-modded Tikka XP, these beamshots are for the Hi mode (not the momentary Burst mode).
    The H15 gives a pattern similar to other reflector-based XM-L lights, like the Spark ST5 shown above. Lights that use an optic (e.g., the XP-E-based Petzl Tikka XP2, or my SSC-modded Tikka XP) tend to have a narrower beam profile with less spill. They also sometimes have color distortions in the beam (e.g., the stock Tikka XP2).
    Now let's see what happens with included diffuser in place on all of the above lights:
    The H15 diffuser does a good job diffusing the beam.
    And now the red beam shots. Note that the original Tikka XP didn't have a red LED, but Petzl did sell various colored diffuser covers. Shown below is my SSC-modded XP with a red diffuser cover (on Hi).
    Again, you can see the red light emitters on the H15 are quite bright. Scroll down for a direct output measurement.
    As useful as the above shots are, I know people like to have a better idea of the beam angle coming out of the headlamp. So for that, I have turned to my famed "integrating carpet."
    First, the un-diffused beams (the beam tint is a little off on the H15, due to inclusion of the neutral-white ST5 in the same pic, with camera set to auto-white balance):
    The H15 has a fairly typical pattern for a reflectored light. As you can see, the optic of the original Tikka XP can’t be beat for a spill-free beam. Also, notice the prominent color distortions in the beam of the XP2 (i.e. a very yellowish corona).
    And now, with diffuser:
    Again, no surprises for the H15, a typical diffuse beam. The Tikka XP2 is definitely a good choice if you want the widest beam possible (the diffuser also helps even out the color distortions somewhat) Still tough to beat my old SSC-modded original XP for the widest choice of beam profile choice.
    Before I move on, one comment here about the flip-up diffuser on the H15 – it tends to cast something of a shadow on the spillbeam. You couldn't really see it on the beamshots up above, so I thought I would take a zoomed out pic of full white wall beamshot:
    You can see the shadow it casts above.
    The lights are all sitting on top of a step-ladder for these white wall beamshots, in case you were wondering.
    My summary tables are reported in a manner consistent with the ANSI FL-1 standard for flashlight testing. Please see http://www.flashlightreviews.ca/FL1.htm for a discussion, and a description of all the terms used in these tables.
    Olight reports 150 lumens Hi and 5 lumens Lo on the white LED, and 4 lumens on the red LEDs. As you can see in my table, these numbers are not very far off from my estimates.
    The Beam Intensity/Distance measures also seem very accurate to Olight specs (i.e., I know my standard lightmeter tends to under-report slightly, compared to most others).
    FYI, the red LED on the battery pack is quite dim in comparison to the front-mounted ones (i.e., a little under <0.001 estimated lumens in my testing). It is enough to provide an on/off signal in the complete dark, but not much more.
    Output/Runtime Comparison:
    To start, I thought I would show you the performance to my two 3xAAA headlamps, and a recent 3xAAA flashlight:
    The H15 clearly has a lot more output on Hi than these other lights with older emitters. Runtimes seem quite good for the output and 4xAAA battery source. Again, my findings are quite consistent with the reported Olight ANSI FL-1 standard specs (note the standard defines runtime as time to 10% initial output).
    One issue you may observe here is the lack of a Med mode (i.e., the Lo mode of the H15 is very consistent with the Lo mode of my other multi-mode headlamps).
    You will also notice something peculiar on the alkaline Hi mode runtime above. After about 2hr and 20 mins into the run, the output level began to fluctuate slightly. The light then shut-off completely. After a few mins rest, I reactivate on Hi, and saw several more minutes of slightly fluctuating Hi output before the light shut-off again. I then re-activated on Lo, and got more than 24 hours of regulated Lo mode runtime.
    It would seem that as the alkaline cells are no longer able to supply regulated Hi output, the light shuts off rather than simply drop down to Lo. Not really a problem per se, as you can simply re-activate in Lo (or maybe a few more mins of Hi), but it is unusual.
    Let's see how the H15 compares to a 1xAA headlamps. I don't have the Zebralight H51 headlamp, but performance should be comparable the SC51 presented below.
    The H15's Hi output level is in keeping with other well-driven single AA-based lights. Runtime is longer of course, because of the 4xAAA capacity.
    Of course 1xCR123A/RCR/14500 headlights would be expected to be brighter on Hi. You can see this in the 1x14500 output/runtime graphs above.
    The wave switch timing takes a fair amount of getting used to for mode level changes (i.e., you have to be very quick on the double-wave to switch from Lo to Hi in white, or constant to strobe in red). Unfortunately, it is also rather sensitive for simple on-off. As I discuss in the video overview, I found that I could easily accidentally turn the light off by simply passing too close to a door jam, cabinet door, counter-top, etc. You are likely to want to temporarily lock-out the wave feature when working with the light indoors.
    Pressing the mode sequence switch on the head always advances you through Standby > White LED > Red LEDs, in sequence. However, you can turn it off/on at the battery pack as well (always comes back on in Standby mode). There is no mode memory, and the light always defaults to Lo White and constant Red levels in the sequence.
    The light uses a separate battery compartment connected to the headlamp by a coiled cable. It also uses 4xAAA cells.
    Due to the electronic switches, a standby current will always be required when batteries are installed. I have not measured this current, however.
    All headlights that use a plastic battery carrier typically have limitations in terms of water-proofness. In this regard, the design of the H15 seems better than other plastic 3xAAA headlamps I've used (but can be a bit fussy to line-up correctly when installing batteries).
    When the diffuser is not in place over the beam, it sticks out at a 90-degree angle from the front of the unit. This casts a minor shadow over the top of the spillbeam.
    The light lacks a defined Medium mode (i.e., just Hi and Lo).
    I am not sure what final packaging will include, but the bundled headband seems of good quality for this type of light.
    The headlamp space is a new departure for Olight, with the launch of their inaugural H15 Wave.
    To be honest, this is a difficult space to do well. People have very differing needs in a headlamp, and it is probably impossible to have one design that pleases everyone, all of the time. I personally have gone through quite a few different models over the years – and continue to keep several models around for use in different situations and for different purposes.
    Opinions obviously vary about the value of separate battery packs, all-plastic construction, and the use of multiple AAA-sized cells. I will leave that up to personal preference and focus on the specific feature set and user interface in most of my comments below. But I will make the general point that the H15 seems relatively well-built, within the specific design choices made. For example, the tension on the battery pack bracket cover is good, and there is an o-ring in there. I would expect water-proofness to be higher than most of my 3xAAA plastic headlamps (although the bracket can be a bit tricky to seat properly, until you get the hang of it).
    What is particularly novel about the H15 is the control interface, especially the wave feature. While the option to have hands-free operation is interesting, I actually found it rather limiting in practice. It often takes a couple of tries to accurately switch levels within a given mode (through the double-wave), and it can be too easy to accidentally shut the light off by passing you head near an object (i.e. the single-wave). Indoors, I found I frequently had to reach up and lock out the wave feature to prevent accidental deactivation, negating the benefit of a hands-free level change.
    Personally, I am not crazy about the main UI – specifically, having to activate at the battery pack first (which brings you into standby mode), then always switch thorough Lo white, constant red, and standby again (in sequence) from the front switch. It's true you can jump back to standby by turning off-on at the rear (i.e., if you want to avoid red), but you still have to switch on at the front for Lo white. And if you want to activate in red from off, you are out of luck – you need to switch past Lo white first (unless you just temporarily waved off/on in red mode). There's also no memory for the Hi white or strobing red levels.
    In terms of the actual beam, the white LED beam pattern is quite good, in keeping with the reflectored nature of headlamp. The diffuser also does a good job spreading out the beam for up-close work, although it is a little peculiar to always have it sticking out when not in use. At least you don't have to worry about losing the diffuser, but I would have preferred a sliding mechanism.
    Hi white output is surprisingly bright for an AAA-based headlamp, and Lo mode is reasonable. Output/runtime efficiency seems quite good on Hi, and the Olight ANSI FL-1 specs definitely seem accurate for output, runtime and beam intensity/distance. But I find I missed the option for a true Med mode (i.e., when working under a sink or inside a light fixture/wall, I find 30-50 lumens can be the sweet spot).
    One thing I really liked about the H15 was its selection of red light modes – specifically, the relatively bright and throwy red LEDs on the front, and the dim red LED on the battery pack.
    I find most headlamps that even bother to include red light do so as an afterthought. Frankly, a single woefully-underpowered 5mm LED on most headlamps really isn't very useful as anything other than a simple moonlight. It is certainly not much help for navigation in the dark – with most red LED headlamps, I typically have to walk around slowly, starting directly at feet, to be able to make out much of anything. In contrast, the front-mounted dual D5.0 red LEDs on the H15 cast a pretty strong beam several meters ahead, along you to walk at a good clip.
    While I'm not a big fan of separate battery compartments, the secondary red LED on the battery pack is a good idea (as is its slow beacon mode). While not very bright, it does at least provide some signaling use off the back of your head (e.g., if you were riding a bike, etc.). Personally, I would prefer to see the same slow beacon frequency duplicated on the front red LEDs as well (although I know some like a more rapid strobe indicator - as currently used on the front here).
    Ok, I think this review has gotten long enough. Bottom line, like most headlamps, the H15 has some nice features, some neutral/ok features, and some annoyances (according to my personal preferences). The question – as always – is does it have the right balance for the things you need it for? I hope this review was able to give you enough information to decide for yourself.
    Personally, I don't think I'll be grabbing the H15 the next time I have to fix a leaky faucet – but I will definitely take it with me the next time I head out along those wooded walking paths I follow for my outdoor evening beamshots.
    H15 was supplied by Olight for review.
    Default Re: Olight H15 Wave (XM-L, 4xAAA) Headamp Review: RUNTIMES, BEAMSHOTS, VIDEO and more
    Thank your for this great review of yours!
    But I have a question for you that I hope you won't mind answering, is the external sleeve of the power cable that goes from the battery compartment to the headlamp made with hard plastic or soft rubber? From my limited experience with construction tools, soft rubber power cables tend to have much longer lifespans than their hard plastic counterparts.
    Quote Originally Posted by bon1 View Post
    It's a very flexible, soft rubber.
    Flashaholic* Bolster's Avatar
    Oct 2007
    Mexifornia
    Phenomenal review. I wish I could write a quality review like this, but it's far beyond my ability. Thanks for writing it up.
    Quote Originally Posted by Bolster View Post
    Thanks. I haven't done a lot of headlamp reviews, but I have certainly played with a number of models over the years. My original Tikka XP has certainly see a lot of action (lovingly modded to SSC many moons ago).
    I almost wrote up a review of the Petzl Tikka XP2 after I picked it up a couple of years back, but it was already well-known here (and I never got the Li-ion pack for it anyway), so I didn't bother in the end. In case anyone is wondering, the PWM frequency on the Lo modes of that light is 97 Hz (ugh) ... I rarely use it, except for the red LED.
    The H15 wave is certainly an interesting attempt. Personally, I find the UI a bit cumbersome for regular use. But I am sure it will become a staple for my night beamshot walking excursions, given those relatively throwy and bright red LEDs. The wave should work well there for momentary off/on ... I'll report back my experiences the next time I do some of my 100-yard thrower beamshots.
    Any more experiences yet?
    Quote Originally Posted by jsalmika View Post
    No, I haven't actually done any 100-yard beamshots since this review was posted. Hoping to get out soon, when weather permits, and will definitely bring the H15 along for the ride.
    Oct 2003
    Two Rivers, Wisconsin
    Thank you, selfbuilt, for the time you took providing us with a thorough review. I'm in the market for an addition to my PT Apex & Hybrid, Zebra H30, and several 1AA RayOVacs. I might have to buy a few more Duraloop AAA cells and make the plunge. I'm pleased with the quality of my new and tiny OLight Baton. It looks like these guy are serious about their products.
    I'm absolutely certain that I need another flashlight.
    A non-professional video demonstrating my old Petzl Myo 3 (http://flashlightreviews.com/reviews..._myo3_myo5.htm) and Olight H15 Wave:
    http://s220.photobucket.com/albums/d...t_h15_wave.mp4
    I've just done some outdoor beamshot updates in a number of my reviews. As promised, I took the the H15 along for these.
    My initial impression was fairly positive - the H15 was very bright, and made it easy to organize myself in the dark between beamshots. However, I did find reflections from the red LEDs were caught at the top of my glasses, which could be a bit distracting at first. I believe this effect was actually related to the greater output of the red LEDs.
    Excellent detailed review! Is weight the main reason you reserve the majority of you headlamps for indoor work?
    Flashaholic* B0wz3r's Avatar
    Sep 2009
    San Francisco Bay Area
    Awesome review as usual, Selfbuilt!
    The hand-wave UI thing seems gimmicky to me at best... I think I'd find it far more frustrating than convenient.
    Not a bad first try though; compared to some of the 'big-name' makers like PT and BD they did some things pretty well, like having the red emitters come on first. I'll ignore that it's probably very highly incredibly likely they're not true deep red emitters, which makes the idea of using them for true 'night-vision' use kind of a joke.
    I'll stick with my Zebras and Sparks.
    What? Me? Derail a thread?
    Quote Originally Posted by Invisible Hand View Post
    Hmmm, it has more to do with then I think to grab one. I always have two EDCs on me (one on my belt, one on my keychain), and typically additional flashlights in jacket pockets. So unless I specifically think to grab a headlamp before heading out, I'm not likely to have one with me (i.e., I always have some kind of light handy). Inside the house, I'll just go grab one from my drawer if it is useful for a given task (i.e., don't have far to go). Kind of like how you'll use the perfect tool for the job if you have your toobox handy, but will make do with what's available if you are offsite.
    Quote Originally Posted by B0wz3r View Post
    A good assessment. The few times I've had it out with me, I wound up quickly disabling the motion sensor, as I was accidentally setting it off. The red lights are brighter than I'm used as well. As such, I find they are really just a low-lumen solution, as opposed to a true night-vision-sparing one.
    Question Re: Olight H15 Wave (XM-L, 4xAAA) Headamp Review: RUNTIMES, BEAMSHOTS, VIDEO and more
    Not a bad first try? As far as I (we?) know, Olight H15 Wave is a modified (re-branded?) Favourlight PHM0M3B002. It would have been even better try if they re-branded one of the Zebra or Spark models.
    A link to an older discussion which you also took part in:
    http://www.candlepowerforums.com/vb/...light-H15-Wave
    The review is excellent of course.
    In God we trust, all others bring data.
    Sep 2009
    Quote Originally Posted by Esko View Post
    Honestly, I participate so infrequently here anymore that I have trouble remembering the last thing I posted about.
    I was checking out Favourlite's site and I think the above comment could be made for most of the 'big-name' headlamp makers, except for ZL and Spark.
    Not meaning to rag excessively on the Olight, but I honestly have no interest in or use for such a light anymore. I don't care if I have to carry around more than one either (it's simply dumb to not have a backup anyway, particular during an outdoors activity); so, a Zebra and a Spark, or a pair of Zebras, etc. meet 99% of my needs for a headlamp.
    This headlamp has been replaced by a new model, the Olight H15S (XM-L2, 1xLi-ion, 4xAAA). Please see my review of the currently shipping version of this light.
    Thanks for the review. I'm seriously considering getting the Olight H15S Wave, so this was a useful read. However, my other option is to go with either the Petzl Tikka XP2 or the Petzl Nao, and since you also have the Tikka, I would really appreciate your thoughts here. I will mostly be using the headlamp for dark night runs on forrest trails, if so, what would be your recommendation of these lamps for the best light source for that purpose, not taking price into consideration?
    Thanks a lot.
    Sent from my iPhone using Candlepowerforums
    Flashaholic* D6859's Avatar
    Oct 2013
    Finland
    Quote Originally Posted by linusb View Post
    I've had two broken H15 Waves as I've commented on Selfbuilt's H15S review. Replacement H15S I got is still working, but I'm still worried about the battery case. (Also that Xtar H1 I mention in my post has broken down ) I haven't had chance to try Tikka or Nao, so don't base your purchase decision on my bitter comments. Just wanted to let you know there have been problems with the battery case in H15(S). I hope selfbuilt can bring you better comparison of the headlamps.
    I personally still quite like using my Tikka XP2 for most things outdoors. But I haven't used a lot of different headlights in the field, so I'm not really in the best position to advise.
    Good luck with your choice ... and
    Thanks a lot for your answers. Having also looked around at other comments here at the forum as well, and based on potential bad quality with the H15 combined with some superb reviews of the Nao it seems Nao will be my choice. Looking forward to some great evening runs soon!
