Crelant
Results 1 to 8 of 8
Thread: Surefire turbohead finish/o-rings question
    Flashaholic* batman's Avatar
    Oklahoma/VN
    Default Surefire turbohead finish/o-rings question
    Greetings all,
    I've noticed over the years that there is some slight flaking away of the finish of the reflector of my SF turbohead (M6 Guardian) inside the shaft where the lamp assembly slides in/out. So far it's only inside that cylindrical shaft area and hasn't seemed to migrate to the orange peel area, but it almost looks like shoving in a lamp too fast would cause some of this chipped debris/finish to end up inside the business end of the reflector. I'm not going to touch this or mess with it for now because I don't think its causing a problem, but have others noticed this characteristic and is there any reason to OR good way to remedy it?
    Also, how many orings is the M-6 supposed to have at the front end? Seems to be slots for 2 but I only have one.
    Thnks,
    Batman
    It isn't the life that matters, it's the courage you put into it.
    Oklahoma/VN
    Default Re: Surefire turbohead finish/o-rings question
    I'm surprised there hasn't been any responses, anyone with any ideas or experience with that?
    Administrator Size15's's Avatar
    Aug 2000
    Kettering, England
    Quote Originally Posted by batman View Post
    The M6 (no such model as "M-6"), has one o-ring on the bezel-end of the body.
    One may assume that the apparent location for an additional o-ring may be so that SureFire can supply small quantities of deep depth-rated Millennium-Series models to specialist military units.
    All of my M6 flashlights have one forward o-ring, but there is a place for a second.
    Oklahoma/VN
    That's good to know,..for the last 2 years I've thought there were supposed to be 2 orings and that one of mine broke off.
    Aug 2000
    Kettering, England
    I suppose that frequent removal of the Lamp Assembly would cause some wear of the 'location shaft' - I've not noticed this obviously happening to any of my TurboHeads though.
    Key things to remember is that it is almost impossible to clear reflectors once they are dirty so if you're going to attempt to clean it I suggest extreme caution. Don't get any cleaning tool close to the reflector finish. One thought I'd had on this would be to clean it from below with the window pointing upwards on the thinking that any debris would less likely enter the reflector. Also, I'd not want to get moisture inside try to keep the cleaning operation dry or as dry as possible.
    Good luck!
    Oklahoma/VN
    Coolio,..I think I'll just leave it alone for now. I turned it upside down and tried to gently rub some of the material out with a q-tip to no avail. It seems like it's permanent,..like rust or something from the humidity of Oklahoma. HUmidity seems to be extremely hard on everything.
    Flashaholic* cland72's Avatar
    Nov 2009
    Texas
    If you want to get all the moisture out, get some small packs of dessicant and put them in the body of the light (with batteries and LA removed) for 24 hours and it should draw out all the existing moisture/humidity.
    Chris
