Page 1 of 2 12 LastLast
Results 1 to 30 of 35
Thread: My Deus Ex: Human Revolution-inspired candelabra project
    Default My Deus Ex: Human Revolution-inspired candelabra project
    I have started a project to imitate the candelabra featured in the computer game Deus Ex: Human Revolution. The candelabra looks like this: http://imgur.com/a/BUQ8D#1
    I'm having some trouble implementing my project, specifically with the diffusion of light. See below for a bad representation of my plan.
    I'm using frosted 38mm diameter acrylic tubes and my original plan was to insert a metal tube holding a strip of 5050 RGB LEDs. However, despite the frosting and even addition of light diffusion "gel" (plastic sheet) inside the tube, points of light are clearly visible. One possible (long-shot) solution I read was to insert clear beads in the space between the LEDs and the outer tube, which may or may not diffract the light sufficiently.
    Alternatively, I could use an RGB power LED such as the one here but the viewing angle is quite wide and I'd suppose I would need an optic which I am unable to locate for this LED.
    The wiring will not be hidden but will be braided and decorative so that it doesn't look out of place.
    Click to enlarge:
    Default Re: My Deus Ex: Human Revolution-inspired candelabra project
    Interesting project, first of all to say, you want to imitate the candelabra in a computer game, seems interesting. Try to get some help from the internet if you can regarding the query. There is no display of image on link 2 i.; the (one here) link. Try to find an optic for your project if available on the Internet.
    The issues you are dealing with are the same ones DIY light saber makers have to deal with. More specifically, the issue with LEDs killing the illusion of a diffuse rod because of hot spots. A suggestion to approach the problem from that angle first. I know a lot of those guys have solved it.
    Apr 2010
    Brisbane, Australia
    As per blasterman's reply, but not just DIY; the cheap Hasbro lightsabers use a white polyethylene foam tube as a diffuser, and I know others have used this method. Not sure where you can find this as I've never looked for it, but white rod polyethylene foam (ie. no hollow in the middle) can be found in many hardware stores as foam sealant strips for doors etc. DIY NERF people use it to make their own foam darts.
    Here's a look at the lightsaber thing on Park Sabers: http://www.parksabers.com/Blade_Anatomy.html
    Hi. Thanks for all the replies. Regarding the foam tubes, I see the Hasbro design uses multiple small LEDs. I'll keep this as an option but since I would like to be able to change and tune the colour, I want to use RGB LEDs and it would be such a chore to solder so many leads. I imagine that the foam severely attenuates the luminosity of the LEDs as well?
    There are many DIY light sabres which use power LEDs and collimator lenses so I think I'm going to attempt this route next. Can anyone suggest good value suppliers to the United Kingdom (I'll see if I can find any on this forum)?
    I should also say that I'm hoping to use one of these controllers, designed for LED strip lights, to power the LEDs. I'm pretty sure that for most RGB power LEDs, I can wire three in series and connect directly to the controller, as though it was an LED strip.
    Last edited by seanspotatobusiness; 07-29-2012 at 07:09 PM. Reason: Compliance with rule 3. Sorry!
    Apr 2010
    Brisbane, Australia
    Maybe you could use a tight-angle TIR (total internal reflection optic, think of them as kinda part reflector part lens), I got some bits shipped from LED Rise and they came from Romania, so kinda local for you and I believe it would be free shipping.
    You haven't said how long or thick the tube is, from the 38mm OD I'd guess from the pics it's maybe 250mm long? Shouldn't be as much issue with fade-out along the length for you if you use base illumination.
    Not sure about the controller, generally around here anything refered to as a "power" LED is considered to be more reliant on a constant current rather than a constant voltage, but that's probably going a bit overboard for your application. Find out what the Vf (forward voltage) of the LED is (or should roughly be), how much current (roughly) is required, then feed that into an LED calculator and grab a resistor to match the results. Your source driver is 12V, so for example if your LED Vf is 3.5V and current is 350mA, you'd need a resistor to suit a voltage drop of 10.5V (3x LEDs) and 350mA, with a supply of 12V (that one looks like it can do up to 2A, so that's fine); resistor for such a case would be 1Watt 4.7Ohm.
    http://led.linear1.org/1led.wiz/
    Hi Rogue. Thanks for your advice; I really appreciate it.
    The tube is 38 mm outside diameter, 35 mm inside diameter and 300 mm length. Indeed you're right; I won't want as tight an angle of collimation as those making light sabres. Any idea what angle I should try first? My guess is 25 degrees.
    Regarding the resistors, the main (only?) reason I want to wire it up in series (I guess I will need separate cathodes/anodes for blue/green and red for that to be possible) is to avoid heavy energy loses in resistors. One watt per colour per LED comes to 9 W of wasted energy and problematic heat! If I can get them in series, I think I'll only need to drop 2.5 V with 350 mA for blue and green and maybe 1 V for red. I expect that I may use these (I've ordered one to test).
    I will need to investigate the above pictured controller. I only measured the voltage when it was disconnected - I don't know whether it regulates current or voltage.
    Apr 2010
    Brisbane, Australia
    Actually I don't know if those controllers would regulate anything, pretty sure they'd just PWM each line. It says input/ouput: 12V. Also make sure you take note of whether it's "common cathode" or "common anode", this will dictate which pins you need to tye together. Come to think of, you NEED common cathode if you are dealing with a "power LED", as these only have one cathode and three anodes, whereas the 5050s have indiviual cathodes and anodes for each colour, and can be set up either way.
    Honestly with the distance you are dealing with, I'd just say "experiment"! Get some power LEDs and put them at the base, see how well or badly the light shapes. You could then try something like a ping-pong ball as a diffuser, experiment sanding it in various places to maybe diffuse it more or thin it down to allow more light through... yes you are drastically losing light rather than trying to reshape it, but I think if you have a bright enough source it won't matter a damn at such short distances. You could spend forever trying to model the beam patterns, calculating to the inverse-square law, etc.
    [EDIT] Ah just checked your LED link, those ones have individual cathodes, so ignore my comment about power LEDs
    *Flashaholic* Gunner12's Avatar
    Dec 2006
    MA
    What about electroluminescent stuff? You could try wrapping white electroluminescent panel around something, or a few white electroluminescent wires in a white plastic tube. This will decrease the hotspots of LED and will not require a TIR optic or a diffusing tube. If your TIR and diffuse tube is not matched well, you could end up with one end of the tube being brighter then the other.
    White uelectroluminescent is pink when unpowered though, so that might not work for your project, and I don't know hot bright they are and if they are useable for actual lighting.
    Best of luck with your project!
    Flashaholic* AnAppleSnail's Avatar
    Aug 2009
    South Hill, VA
    Quote Originally Posted by Gunner12 View Post
    Rarely useful for useful light beyond indicator lines.
    I suggest: Get 3 RGB strips in a triangular prism, put white foam around them, and call it a candlestick. You'll need all your usual controller-type stuff hidden, but this conceals the wires inside the light diffuser. White foam passes a fair amount of light, especially if you get the kind without TiO added to whiten it.
    My biggest light-hog is my camera.
    Hi. I did consider electroluminescent stuff but both the light output, lack of colour customisation and the expense led me to ultimately choose LEDs. I think electroluminescent panels would look pretty sweet nonetheless.
    AppleSnail, I'm not sure what you mean re: the triangular prism... would the LEDs be facing into the prism or away from it? Are they inside it or out?
    Aug 2009
    South Hill, VA
    Quote Originally Posted by seanspotatobusiness View Post
    My (white) LED strip lights are about 8mm wide. Imagine cutting a bar from triangular stock with 8mm faces. Glue the LED strips to the sides this bar (Which serves as a heat spreader) and stab this into the center of your foam 'candle' shapes. Attach wires in secret and you're halfway there.
    Crude drawing of RGB LED strip being applied to one face of a triangular metal bar stock.
    Hey Apple. Thanks for the schematic! Unfortunately, I don't think it will work for me. I've currently got an RGB strip wrapped around a metal tube. I wrapped some packaging foam (this sort of stuff) and the spots are still clearly visible. In fact, while the spots are dimmer, I'm not sure that the gaps between them are actually brighter (I've got half of the length with foam and half without). I'm going to use the tube/strip in some other application where I will have a larger distance for the light to diffuse.
    Aug 2009
    South Hill, VA
    Try carving styrofoam? It's far more isotropic. I find the soft foam rolls don't diffuse as well as I thought.
    Apr 2010
    Brisbane, Australia
    Actually sean you haven't mentioned what the LED spacing is on the 5050 strips? I've seen plenty that have big gaps between them, no matter how you try to diffuse it you won't be able to overcome that, you need tight spacing to begin with.
    If you do have the ones with large gaps, perhaps there could be a way of wrapping them so two strips cross each other diagonally in such a way as to fill the gaps in one with the LED of another...
    As a side thought, to try to diffuse multiple spots, you'd want to place the diffuse material far enough away from the LED so that it is catching overlapping pools of light from the neighbouring LEDs, rather than having the diffuser hard up against the LED, which will just give you a diffused spot. Perhaps also you could experiment with adding a dollop of clear caulking silicone over each LED, it may possible act as a dome lense and give a larger angle of emission? (or it might do the complete opposite, hence "experiment")
    Okay, I'll try it next time I get my hands on some (will ask friends to save any Styrofoam they get) but I imagine it will severely attenuate the light.
    The LEDs strip is the highest density I could find (120 per metre for RGB). Unfortunately, the circumference of the pole leads the LEDs to almost be in a line. There are four lines running up the pole. In retrospect, I could have avoided that by wrapping two separate strips up the pole and aligning them out-of-phase.
    As well as the acrylic tubes already being frosted, I inserted a few layers of diffusing plastic sheet. There isn't enough space in the tubes for other items to not be pressed up against the LEDs. Although I will try the Styrofoam, I'm expecting I'll have to use the strips for something else and wait for the power LEDs to arrive. The strip I already adhered to a pole, I will use in a frosted vase of 10 cm diameter. I think the extra 3 cm all around will make a lot of difference, plus the glass is more heavily frosted.
    Incidentally, I noticed that my aluminium pole got very (skin-damagingly) hot after about 15-20 minutes power. I will need to ensure that the pole is connected to some metal which can better dissipate heat to the environment.
    Apr 2011
    Hungary
    Can't you just put high power emitters on the bottom of the frosted tubes, so it will be like a flashlight with a traffic wand?
    Look up "Philips LivingColors", maybe you could also fit Red, Green and Blue colored dies on the bottom, then you could make all the colors you want and the tube should light fairly even.
    Hi Yliu. Indeed, that is the method I'm attempting now.
    I'm stuck trying to solder the copper rod heatsink into place. I need a thermal connection between the LEDs and the candelabra and this is my solution:
    The problem is that I'm unable to melt the solder/keep the candelabra heated/heat the copper rod. I've tried using a regular soldering iron to maintain an elevated temperature combined with my soldering gun (which is only meant to be switched on 12 seconds in every minute). I also try using a mini blow torch (about the size of a large permanent marker pen) but the flame keeps going out, presumably because it's upside down and getting blown out by hot oxygen-depleted air).
    Edit: forgot to say that 45, 30 and 15 degree collimators were not sufficiently tight enough. I have ordered 5 degree ones and expect them in a couple of weeks.
    Apr 2011
    Hungary
    Default
    Maybe you can use the thermal glue or whatever it's called, it is used to glue the CPUs to their heat sink.
    Good luck.
    Apr 2010
    Brisbane, Australia
    How are you attaching the LED to the copper rod?
    Is the candelabra cup intended as an extended heatsink, or is the solder purely as an attachment method? Can you perhaps place the cup on a hotplate if soldering is a must? Or could you just drill through the cup and tap a screw into the copper?
    Aug 2009
    South Hill, VA
    Arctic Silver thermal epoxy is also epoxy. Regular 10-ton epoxy in thin layers is reasonably thermally-conductive. My brazing torches run in most any position EXCEPT inside a bottle-shaped object. If you do not trust Arctic Silver, then you'll have to heat the base to puddle solder. Then use needlenose pliers you despise to hold the copper slug as you heat it quite hot. Press this onto the solder while heating the top of the copper slug. Once it sets, remove heat and hold it in place. Or use your second needlenose pliers and apply ice to quickly cool things. This will hiss and steam excitingly. You should probably not breathe the steam (Explains a lot about me, eh!?). Then attach LEDs and wires. I've made custom copper housings out of pipe and sheet copper this way.
    Hi. Thanks for all the responses! The use of solder is intended to thermally couple the LED to the candelabra via the copper rod. Due to the construction of the first candelabra I'm using, it will not be possible to drill and tap but I might try this for the second!
    The LEDs will be attached to the copper rod using epoxy on the sides but with the interface filled with cheap white thermal paste.
    Having looked up the thermal epoxies, I notice their conductivity is 0.7-1.0 W/(m.K), compared to 0.3 for regular epoxy (about 400 for copper). I'm not sure they're worth the additional expense.
    I don't have a hot plate but I could maybe use the gas hob. I won't, unless the following plan fails, because I'm afraid of burning myself!
    My current plan is to epoxy the rods in place and then to melt solder in the space around the rods using my blow torch with the candelabra at an angle to allow hot air to escape.
    Aug 2009
    South Hill, VA
    Try with just epoxy, please. Heating epoxy enough will burn it, leading to toxic fumes. I have found that desoldering with a torch is likely to create sufficient temperatures for common epoxy to burn. A thin layer of epoxy with wide surface contact is not much less thermally-conductive than a metal-to-solder connection (Near-zero 'meters' value in W/m*K gives low resistance).
    Okay, but the problem with using only epoxy is better illustrated in this modified diagram. The shape of the candelabra cup is such that there will actually be very little contact area between the rod and the cup. That's why I think I need something more conductive to fill the gaps. Perhaps I could epoxy the rod in and then just drip solder into place? The joints would be cold and I don't know whether they'd stay in place with the candelabra getting moved around during normal use.
    Flashaholic* bshanahan14rulz's Avatar
    Jan 2009
    Tennessee
    If it can't be damaged by heat, you could remove anything that would melt and just torch the copper and the cup until they are hot enough to wet teh solder and then just start feedign it lotsa solder.
    Another idea is to have someone custom make you some aluminum sinks that will fit the space, or copper sinks if you can afford them.
    Have you already tested the "optics" you will be using? I'd start there to make sure that a single RGB high power LED will give you the effect you are looking for with little/no color separation.
    Apr 2010
    Brisbane, Australia
    Grab a file and roughly shape the copper to fit better.
    Why don't you just try putting the whole thing in your oven?
    Just put a roll of solder in there and bake it.
    Maybe you'll want to take a look at fx-sabers.com
    They look pretty impressive to me Not meant for actual lighting though, but the lightsabers look pretty evenly lit.
    Apr 2010
    Brisbane, Australia
    Another cheap thing to experiment with for end-lit is cellophane (or whatever unbranded non-cellulose cheap stuff you can find in your local dollar store) - make a tube of it, rolling it say 10 times or more (ie. 10 layers), its bifringent properties combined with multiple layers helps spread the light. To a degree. Worth picking up a role for $2 to play with.
    I registered on the FX Sabre forum four days ago but they still haven't approved my registration. There is no contact information that I can find. I wanted to ask them about the cellophane since that's what's recommended in a thread in their forum.
    Regarding the copper rods; on closer inspection of the cups, I noticed that there is some exposed thread (the cups actually screw onto this particular candelabra). I've ordered a tap and die set but the first one was out of stock and eventually my order was cancelled. I've ordered another from elsewhere and am awaiting dispatch.
    Thanks again to everyone for their suggestions. I will update the thread as soon as I make notable progress (or hit the next obstacle)!
    It doesn't look like I'm getting onto the FX Sabres forum any time soon which is unfortunate because they've surely got an answer for this, but my current problem is the visibility of the outside edge of the diffusion film. I've ordered cellophane and will find out if it's any different from my current sheets.
    The photo below shows the issue. Here, I've deliberately cut in various directions in order to break up the line and make it harder to follow but it's still quite clearly visible (the front tube is the one with film in - you can see a jagged line which is the outside edge of the film).
    http://i.imgur.com/zwlwW.jpg
    Your image is too large and has been replaced with a link. Please resize and repost.
    See Rule #3 If you post an image in your post, please downsize the image to no larger than 800 x 800 pixels. - Thanks Norm
