Bronte Flashlight
Results 1 to 14 of 14
Thread: Alpha Magnetic Tripod Mount
    Flashaholic* archer6817j's Avatar
    Aug 2010
    Mountain View, CA
    Default Alpha Magnetic Tripod Mount
    I've been dreaming up all kinds of ways to make the Alpha more useful. This certainly isn't a new idea but I made a few of these prototypes for personal use and I'm liking them a lot. Most "mounted" lights I've found are as bad as anything else you can buy in the hardware store. I'll have to say, this comes in pretty handy whether I'm fixing a toilet or replacing the belt on my air compressor.
    Here is a link to my blog post with a little more info.
    Are these kinds of accessories something y'all would like to see?
    Jul 2009
    Northern VA, USA
    Default Re: Fooling around in the shop
    There is a plastic bracket used to hold red reflectors on the seatposts of bicycles. I use one on the front of my bike to hold a headlight, because it lets me hang the headlight directly below the handlebar stem, perfectly centered instead of mounted off to one side. Unfortunately the only headlight I ever found that fits is really cheap and I'd love to replace it with something better. Maybe you could make an adaptor that would let me mount any flashlight to the plastic bracket?
    Oct 2007
    Sitting' on the dock o' The Bay...
    Jason, when I saw the thread title my immediate response was that we need to keep it family friendly
    Other than assorted clamps and attachment systems I can't think of anything. The only issue with your tripod attachment is that there's no way to monitor the heat of the light if someone decides to use the high mode of a freshly charged cell for its full charge.
    Fyrstormer, got any pictures? Typical seat posts are 27.2mm and manufacturers who make accessories that attach to them have to accommodate a wide range of diameters.
    Jul 2009
    Northern VA, USA
    Quote Originally Posted by PCC View Post
    Sure there is: http://www.telatemp.com/p/494/449-2-...rmometer-strip
    I do now.
    Here's the bracket itself: http://www.amazon.com/REFLECTOR-CLAM.../dp/B0046DZUZM
    And here's how I'm using it:
    http://i5.photobucket.com/albums/y18...s/CIMG5291.jpg
    Your image is too large and has been replaced with a link. Please resize and repost.
    See Rule #3 If you post an image in your post, please downsize the image to no larger than 800 x 800 pixels. - Thanks Norm
    The problem is I've only ever seen one light that just happened to have an attachment point close enough to the necessary shape to fit on the bracket securely. A ring clamp that could grab an Alpha Shorty (18350-powered) and bind it to this bracket would be an excellent lighting solution for me.
    I've never understood why bicycle lights are made to attach to the handlebars. They will always be off-center that way, and since they usually mount above the handlebars, if the bike gets flipped the lights are guaranteed to be damaged. I like my solution much better.
    Jul 2009
    Northern VA, USA
    So...I had a Eureka moment last week, and I solved my own problem. Details posted in the Bicycle Lighting forum. Just in case you were considering my request, feel free to ignore it henceforth.
    Nov 2012
    Switzerland/Scarsdale
    Default Re: Alpha Magnetic Tripod Mount
    Yes, another tool in the chest. Sometimes you need light and work with both hands. Ever need to change a flat tire in the dark?
    I would worry about the clamp scratching the surface of the light. Delrin inerts?
    Nov 2012
    It is a little silly responding to my own post, but I was thinking about screw threads on the clip. I have Joby mini pod similar to one shown and it would be easy to use just by screwing the head onto the clip.
    Aug 2010
    Mountain View, CA
    That would "work" as I know McGizmo does that with his new clips; however, I think the Alpha is much too large for that. Too much weight and too much leverage if you hold it at the extreme end of the light. I actually work next to a BMW garage and a Jaguar garage. I sent my neighbors up with an alpha and magnetic Joby and they say it's become an indefensible part of their tool kit...they won't give them back Are there any mechanics around here that work around iron? Sorry aircraft mechanics
    Dec 2012
    Hawaii
    Mechanic here. That would be an excellent product for the Alpha. The magnets should be strong enough to hold the alpha upside down especially while working under the hood where majority of the work is done. Another idea is having the magnets that have "switches" where you can turn off the magnetism of the battery when you want to reposition the mount without scratching the painted surface of the vehicle(customers doesn't like new scratches).
    -John
    Flashaholic* nfetterly's Avatar
    Oct 2008
    Cincinnati area, but lots of travel
    Nice accessory - I'd be very interested in one. Tripod mountable.
    Aug 2010
    Mountain View, CA
    I did forget to mention the Joby with the red feet (pictured in the OP) actually has magnetic feet. It's got plenty of holding power to support the light if you make sure the red toe(?) is perpendicular to the surface so the magnet can do the most work. The added benefit is the feet are coated in rubber so they are no-scratch as long as they don't get loaded with metal chips.
    The Joby is of course a tripod with a standard 1/4x20 mounting screw.
    Dec 2012
    Hawaii
    Today I actually saw this Joby Light in the Matco Tool Truck. I didnt had the chance to try out the stand, just the light which is not up to my standards. Just by the look of the mount, I thought it was kinda flimsy. But if it's actually sturdy enough, this mount would be very handy and especially for those emergency repairs. IE: flat tires at night, leaky sink, blown circuit breaker, etc.
    Flashaholic* TKC's Avatar
    Dec 2004
    Soon to be OR.
    That is a great idea!! I really like that.
    "He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion."
    Flashaholic* Benchiew's Avatar
    Nov 2011
    Malaysia/Shipping Oregon
    Is this for sale yet?
