Fitorch
Results 1 to 6 of 6
Thread: List of Honda part numbers for Stanley light bulbs
    Flashaholic* RobertM's Avatar
    Nov 2007
    United States
    Lightbulb List of Honda part numbers for Stanley light bulbs
    After browsing the Automotive sub-forum quite a bit, I see that Stanley light bulbs are often recommended due to them being high quality. Since it appears that Honda dealers are the only place you can buy them anymore, I decided to compile a list of Honda part numbers for future reference for fellow CPF members. I have only included bulbs that have "STANLEY" specifically stated in Honda's part description.
    Bulb Type Honda Part Number Honda Description
    ? 34351-657-921 BULB, (12V/5W) (STANLEY)
    168 34901-SB0-671 BULB, (12V 5W 3CP) (STANLEY)
    921 34901-SB3-671 BULB, (12V 18W 21CP) (STANLEY)
    3496 34906-SL0-A01 BULB, (12V43/3CP) (STANLEY)
    3497 34903-SF1-A01 BULB, (12V 45CP)
    3652 34306-SH3-003 BULB, (12V 5W) (KRYPTON)
    H3 34908-SA0-811 BULB, (12V55W) (H3) (HALOGEN) (STANLEY)
    H3C 33165-SM4-003 BULB, (12V 55W H3C) (STANLEY)
    H4 33115-SM3-003 BULB, HEADLIGHT (H4) (12V 60/55W) (STANLEY)
    H8 33165-S5A-J01 BULB, FOGLIGHT (H8) (12V 35W) (STANLEY)
    H11 33165-S5A-003 BULB, (H11) (12V 55W) (STANLEY)
    HB2 (9003) 33111-SR3-A01 BULB, HEADLIGHT (HB2) (12V 60/55W) (STANLEY)
    HB3 (9005) 33115-S84-A11 BULB, HEADLIGHT (HB3) (12V 60W) (STANLEY)
    HB4 (9006) 33116-S84-A11 BULB, HEADLIGHT (HB4) (12V 51W) (STANLEY)
    P21/5W (Osram 7528) 34911-634-611 BULB, (12V 21/5W) (ECE) (STANLEY)
    PY21W (Osram 7507) 33301-S04-004 BULB, (12V 21W) (AMBER) (STANLEY)
    W5W 33301-SNA-003 BULB, (12V 5W) (STANLEY)
    WY5W (Osram 2827) 33301-S5H-T01 BULB, WEDGE BASE (WY 12V 5W) (AMBER) (STANLEY)
    W21W (7440) 33303-SL4-003 BULB, WEDGE (12V 21W) (STANLEY)
    WY21W (7440A) 33303-S2R-003 BULB, WEDGE (12V 21W) (AMBER) (STANLEY)
    W21/5W (7443) 34906-ST5-003 BULB, (12V 21W/5W) (STANLEY)
    Hopefully others will find this list helpful.
    -Robert
    Nov 2007
    United States
    Default Re: Honda part numbers for Stanley light bulbs
    If you see any mistakes in the above list or know of other Honda part numbers for Stanley bulbs, please let me know and I can edit or add to the list.
    If you do have an addition to the list, I'd appreciate it if you could list the part number, the generic bulb number, and an example Honda vehicle that it can be found on.
    Ex.: 33303-SL4-003, 7440, 2011 Honda Civic 4-dr
    You're missing bulb type 3497, Honda P/N 34903-SF1-A01.
    Also, there's no such bulb type designator as "992", that is an error in the US aftermarket catalogs (Sylvania, Wagner, GE -- all get their info from one source who made the error).
    Also, 2827, 7507, and 7528 are not bulb type designators. They're Osram (also Sylvania) item numbers. Correct designation for "2827" is WY5W, for "7507" is PY21W, and for "7528" is P21/5W.
    Also, you're missing bulb type 3652 (Krypton/Xenon 12v 5w W2.1x9.5d base, just like W5W except 75 lumens rather than 50). I think the Honda P/N is 34901 S6D G01HE, but cannot confirm to my satisfaction. 1990 Accord (USA market specification) parking lamp is one application where a Stanley 3652 is original equipment.
    Also, it's likely those two you've got listed as "168" at the top are (A) not the same as each other, and (B) probably at least one of them is really a W5W and not a 168--close, but not the same bulb.
    Also, the third item on your list is also probably not a 168; the closest US equivalent to a W3W is a 194, again close but not the same bulb.
    Also, the "7507" bulb you list as "Fr. Turn" is probably used in some front turn signals, but it's also definitely used in rear turn signals -- probably more rear turn signals than front ones.
    Nov 2007
    United States
    Quote Originally Posted by Scheinwerfermann View Post
    For some reason, this bulb doesn't have "(STANLEY)" in the description from Honda. Can you confirm that these are definitely Stanley bulbs? I went ahead and added it to the list for now.
    I changed this listing to 7440A. Is that correct?
    I made these changes and kept the Osram item numbers in parenthesis for members who may be searching for a bulb by the Osram number.
    From what I could find, 34901-S6D-G01HE was used as a High Mount Stop lamp on 2002-2005 Honda Civic 3-dr Si models, but it is never listed as a Stanley bulb (?).
    34306-SH3-003 should be the 1990 Honda Accord's 3652 bulb, but again, I'm not seeing it ever listed as a Stanley bulb. Thoughts?
    I'm going to try to do some additional research on these.
    I removed the "FR. TURN" from the description to avoid any confusion for others.
    Thanks for your help with the list!
    Quote Originally Posted by RobertM View Post
    Yes, confirmed.
    Yes, that's a common referent number. The type number is WY21W. Likewise, 7443 is W21/5W and 7440 is W21W.
    Where (which catalog) are you looking?
    Definitely a Stanley bulb.
    There are others missing, too -- 9004, H1, H3, H3C, etc.
    Nov 2007
    United States
    I added the 3642 information to the list. I did some looking into the 3x 168 listings that I originally had. Since I have a 2011 Civic 4dr, and my car has all three, I decided to take a look at the markings on the actual bulbs (all its bulbs are OEM and haven't ever been changed).
    Here is what I found:
    34901-SB0-671: STANLEY 168
    33301-SNA-003: W5W
    34351-657-921: KELLY 12V 5W
    Scheinwerfermann, I am a bit confused--what is the difference between W5W and 168?
    I'm a bit new to all of this ...what is the difference between the type numbers and common referent numbers?
    I have been using multiple online catalogs (primarily collegehillshondaparts.com and hondapartsnow.com).
    I have more Honda part numbers for bulbs, but again, I'm running into issues where the part descriptions do not specifically state STANLEY.
    EDIT: I was able to find and add the following to the list: H3, H3C, H4, H8.
    Here are some additional Honda part numbers, but none of them specifically state STANLEY in the descriptions. Would you be able to confirm any of these?
    Bulb Type* Honda Part Number Honda Description Yr Model Location on vehicle
    194 33301-S70-003 BULB (12V 3.8W 2CP) 11ACCORD4D Step/Courtesy light
    1157A 33303-SD4-671 BULB, FR. TURN (12V 2CP) (AMBER) 11CIVIC4D Front turn signal/side marker/parking lights
    7444NA 33303-SZT-A01 BULB (12V 28W/8W) (AMBER) 11CRZ Front turn signal/parking lights
    2825 34103-SMA-003 BULB (12V 5W) 11CRZ License plate lights
    158 34253-SNA-003 BULB, WEDGE (12V 3.4W) 11CRZ Ceiling light/trunk light
    194NA 34351-SJA-003 BULB (12V 1.5CP) (AMBER) 11FIT Front side marker/parking lights
    H1 34901-SZ3-000 BULB, HEADLIGHT (H1) (12V 55W) 08S2000 Headlights High
    3457A 34906-SJC-A02 BULB (12V 28/8W) (3457NAK) (AMBER) 11CIVIC2D Front turn signal/side marker/parking lights
    3057 34906-S82-A01 BULB (12V32/2CP) (WEDGE BASE) 98ACCORD2D Rear turn signal lights/Stop/taillights
    *From Sylvania's online bulb guide
