just acquired a soft start switch for an old M6 but need some guidance with the install.
I'm not sure how to go about pulling tail tail cap apart. Is there a link anywhere that someone can
send me to?
I took my M6 tail cap apart and it has a plastic retaining ring. It looks different from your photos and I can not fit it together so that it will work. did they perhaps make
different tail caps?
the switch I have does not have the large diameter aluminum part that I see in your photos
do you offer an M6 tail cap that this switch will fit?
If so I'ld be interested
thanks for your help so far
Walter
I guess there are (at least) two versions of the switch I have the small one and need the larger one for the M6.
I plan to get one of Fivemega's Megalennium bodies and use the switch in that with the M6 head
anybody looking for a bipin adapter for the surefire M6? I just found one on line and will not be using it
