BlackShadow
Page 1 of 2 12 LastLast
Results 1 to 30 of 44
Thread: Sunwayman C20C (XM-L, 1x18650/2xCR123A) Review: RUNTIMES, VIDEO, BEAMSHOTS and more!
    Wink2 Sunwayman C20C (XM-L, 1x18650/2xCR123A) Review: RUNTIMES, VIDEO, BEAMSHOTS and more!
    Warning: pic heavy, as usual.
    The C20C is the latest member of the new C-series lights from Sunwayman - this time in a 2xCR123A/1x18650 form factor. Very compact, it shares a lot of similarities (and a few differences) from the C10R. Let's go through them …
    Manufacturer Specifications:
    Note: as always, these are only what the manufacturer/dealers report. To see my actual testing results, scroll down the review.
    • CREE XM-L U2 LED
    • Soft-contact Side Switch:
    • One Turbo mode, three modes constant output, hidden Strobe and SOS (below are output and runtime details by using one 2600mAh 18650 battery)
    • Turbo Mode: 450 Lumens (for safety’s sake, after 5 minutes’ turbo mode, the light will go to High mode automatically to avoid over-heat)
    • Three constant output modes: 280Lumens (3hrs) – 95Lumens (10hrs) - 15Lumens (50hrs)
    • Strobe: 450Lumens
    • SOS
    • Constant current circuit, constant output
    • Effective range of 139 meters
    • Uses two 3V CR123A batteries or one single 18650 battery
    • Working voltage: 4~8.4V
    • High quality OP metal reflector maintains great throw distance and spread with an ideal beam pattern
    • Dimensions: 105mm (length) x 25mm (head diameter) x 24mm (tail diameter)
    • Weight: 57g(battery excluded)
    • Aerospace-grade aluminum alloy, stainless steel retaining ring on the head
    • Military Specification Type III- hard anodized body
    • Waterproof, in accordance with IPX-8 standard
    • Ultra-clear tempered glass lens resists scratches and impacts
    • Tail stand capable- can be used as a candle
    • Accessories: Clip, lanyard, holster, O-ring
    • MSRP: ~$69
    Unlike my C10R, the C20C came in full final retail packaging. As expected, packaging included a belt holster, lanyard strap, extra o-rings, manual, warranty card and product insert.
    In keeping with the current Sunwayman labeling convention, the C20C has a model "name" as well as number – in this case, they are calling the light the "Tomahawk".
    From left to right: AW Protected 18650, Sunwayman C20C, Zebralight SC600, Nitecore EC2, Eagletac D25LC2, Lumintop ED20, Foursevens Quark 123-2.
    Measured Dimensions
    Sunwayman C20C: Weight 57.6g, Length: 104.8mm. Width (bezel): 25.6mm, Width (head at widest part): 28.6mm
    Eagletac D25LC2: Weight: 50.0g, Length: 116.3mm, Width (bezel): 22.5mm
    4Sevens Quark Q123-2 X (Regular tailcap): Weight: 44.6g, Length: 112.7mm, Width (bezel) 22.0mm
    Jetbeam PC20: Weight: 60.0g, Length: 127.5mm, Width (bezel): 22.6mm
    Lumintop ED20: Weight 84.4g, Length 121.6mm, Width (bezel) 25.2mm
    Nitecore EC2: Weight: 60.9g, Length: 101.7mm, Width (bezel): 25.5mm, Width (widest):26.7mm
    Spark SL6: Weight 77.8g, Length: 125.5mm, Width (bezel) 30.9mm
    Thrunite TN12: Weight: 64.0g, Length: 126.9mm, Width (bezel): 24.1mm
    Zebralight SC600: Weight 87.2g, Length: 107.8mm, Width (bezel) 29.7mm
    The C20C is definitely very petite for the class. Overall build of the C20C is very similar to the C10R – in fact, from the "neck up" (i.e. the heads), they look identical. The C20C is also not that much larger overall really, as you can see in the comparison pic below.
    Here are some detailed pics:
    As with all Sunwayman lights, you get the dark gray natural finish anodizing on the C20C. Sunwayman has always had one of the best quality finishes. As always, all labels are fairly small and bright white against the dark background.
    Like the C10R, and recent M11R/V11R, Sunwayman has knurling of reasonable aggressiveness on the C20C. With other build elements (ridges, raised areas, etc), I would say overall grip is good.
    The body tube is wide enough to take protected 18650 cells, as well as 2xCR123A. I didn't experience any issues with longer cells.
    Like the C10R, the C20C is controlled by Sunwayman's new "Smart Switch" - an electronic switch in the head (under a rubber button cover). Switch feel is good for this type of switch, with a definite "click" upon activation. Scroll down for a discussion of the UI.
    There is a red LED on the other side of the head from the switch, which serves as a low voltage indicator for the battery. See the UI section below for a discussion.
    A clip-on style pocket clip is included with the C20C. While nothing special, it holds onto the light reasonably well for this sort of clip. Note that no clip was included with the C10R.
    The light only opens at the tailcap, and screw threads are a thick square-cut and fully anodized for lock-out. I am glad to see Sunwayman restore anodizing after leaving it off the C10R. Screw thread design and number is otherwise similar to the C10R (which differs from the earlier 1xCR123A/RCR lights.
    As previously mentioned, the C20C looks virtually identical to the C10R. There is one difference on my sample – the reflector doesn't seem to be quite as deeply seated on my C20C. You can see some evidence for this above – notice the reflection of the bond wires in the upper left-hand size of the reflector? This will likely result in a greater number of beam artifacts around the hotspot.
    I've opened up the head to take a look inside:
    A few other makes and models have been known to suffer from reflector depth issues (e.g. Zebralight SC600). But as a general rule, it is always easier to raise a reflector than lower it. And in this case, there is nothing I can really do to adjust the height – the plastic insert around the LED seems fully seated. I presume this is therefore just natural variability between samples.
    The tail cap allows tailstanding, and a cut-out region to allow you to attach a lanyard through a split ring (while maintaining the ability to tailstand). Why I like these sorts of designs, the aluminum seems very thing on the attachment point of the tail (i.e., I worry it may wear through over time).
    User interface is similar to C10R, but with an additional constant output mode.
    With the tailcap fully-connected, turn the light off/on by the electronic clicky switch. The C20C has two options – click (i.e., quick press and release) for constant on, or press-and-hold for momentary.
    As with some of the Spark and Zebralight models that use a similar interface, it may take you a little time to get the timing just right (i.e., too slow on the release, and the light will shut-off, thinking you wanted momentary). But this delayed momentary does give you option to signal with light if you want (i.e., short and long pulses of Morse code).
    First time you activate the light, it comes on in Turbo mode. Change output modes by pressing and holding the switch from clicked on. The light will cycle between constant output modes in the following order: Turbo > Hi > Med > Lo, in repeating order. Let go off the switch to select the mode you want.
    Light has mode memory, and will retain the last constant output used when turning off and on.
    There are "hidden" modes; a strobe and SOS (activated and double-clicking the switch rapidly). On first double-click you get strobe, on second double-click you get SOS. Single click to turn off. Light returns to the memorized constant output when clicked back on.
    As this is an electronic switch, a standby current is required (see below for measurements). To reduce the risk of accidental activation, Sunwayman provides a switch lock-out mode. After waiting a minimum of 7 secs with the light off, do a quick click followed immediately by a press-hold. After 1 sec, the light will shut off and cannot be re-activated until the lockout is deactivated. To restore full functioning, double-click the switch followed by a press-hold.
    As with all lights with anodized threads, you can also physically lock out the light by a head twist.
    There is a secondary red LED on the other side of the head from the switch, which will warn you when a battery is running low. On my C10R, this indicator was set to only work on 1xRCR (by checking for a minimum 3.3V on connection, with a double-flash). The indicator went solid red when the cell reached ~3.05V resting voltage. By that point, output had already dropped to <10% initial output, so it wasn't much of an advanced warning.
    On the C20C, the indicator is set to work with only 1x18650. There is no need to check the voltage ahead of time (since that is the lower voltage power source it supports), so there is no flash on connection. The indicator went solid red at ~3.45V resting voltage on my sample. This is a more useful advance indicator of waning battery capacity than the C10R, but is likely already obvious to you by the dropping Hi/Turbo output. Note that it is so low that none of the 2x sources will ever trigger it in practice (i.e. 2xCR123A would be nearly dead, and 2xRCR would have triggered their protection circuits long before then).
    For information on the light, including the build and user interface, please see my new video overview:
    PWM
    There is no sign of PWM that I can see, at any output level – I presume the light is current-controlled, as claimed.
    Strobe is a standard "tactical" high frequency strobe, measured at 11.6 Hz (similar to the C10R).
    Standby Drain
    As the switch is an electronic one, a standby current drain is always present when a battery is installed.
    When I first connect my DMM, I measured an initial current of 1.5mA (on an 18650 cell). However, after a few seconds, the stand-by drain dropped to 10.0uA, and remained there stably. This would translate into nearly 30 years before a 2600mAh battery would be drained. It is definitely negligible, and not a concern.
    Sunwayman provides a switch lock-out mode that is activated by a quick click followed by a sustained press (see UI section – same as the C10R or T60CS). But unlike the C10R, you can fully lock-out the C20C by a twist of the tailcap (thanks to the anodized threads).
    Time for the white-wall beamshots. All lights are on Max output on an 1x 18650 AW protected cell. Lights are about ~0.75 meter from a white wall (with the camera ~1.25 meters back from the wall). Automatic white balance on the camera, to minimize tint differences.
    You can't really see it in the beamshots, but as I expected, the slight depth misalignment of the reflector has resulted in a number of subtle artifacts around the hotspot. Rather than a sharply defined hotspot, you get an overlapping pattern of distortions in the corona. While not severe on my sample, they are noticeable on a white wall.
    Looking back at my C10R, I see it also has some evidence of this same effect - it is just more noticeable on my C20C. This not much of a problem in real-life use, but it is noticeable by eye on white walls.
    Sunwayman reports a max output on Turbo of 450 lumens. That seems a lot lower than my sample, which I would estimate as >600 lumens (and pretty close to the Eagletac D25LC2). However, once the Turbo mode steps down to Hi, I get ~450 estimated lumens on the C20C (which is a lot higher than the spec 280 lumens).
    Interestingly, my peak intensity and beam distance measures on Turbo are right on with Sunwayman specs (i.e. 139m reported vs 140m actually measured).
    Let's see how output varies across batteries, in estimated lumens (estimated as described above, at ANSI FL-1 standard of 30 secs after activation):
    As you can see, the C20C is very consistent in output across all battery types.
    Interestingly, it is also very similar to several modes of my Eagletac D25LC2 (which was also very consistent on different battery sources). Shown below are the comparable D25LC2 levels, on 1x18650:
    Lo1: 28 estimated lumens
    Med1: 125 estimated lumens
    Hi2: 470 estimated lumens
    Turbo: 660 estimated lumens
    Output/Runtime Comparison:
    Output/runtime efficiency is good on my C20C, just as it was for the C10R. The C20C is more heavily driven than I would have expected (based on output specs). Relative mode level spacing appears to be reasonably good, but I would have preferred a lower low.
    Note that despite my higher estimated output levels, my actual runtimes are quite consistent with Sunwayman specs (when you take into account the higher capacity battery they used, and the ANSI FL-1 standard time to 10%).
    Note the official specs don't make any mention of 2xRCR. However, the voltage range (up to ~8.4V) would suggest it can handle them. And the SWM website does make mention of "16340" (aka RCR) at one point, so I figured it was worth a try.
    Switch timings may take a little getting used to. As you can activate a momentary mode by a sustained press, you must be quick on the press-release for it to register as a click (for sustained on). Other electronic switches (e.g., Zebralights and Spark) can similarly take some getting used to initially.
    Due to the electronic switch, a small standby current is always required when a battery is installed. However, this drain was measured at an inconsequential level (i.e. several years before it would drain a battery). As always, I recommend you store the light locked-out when not in use (which is possible here thanks to the anodized threads).
    The split-ring/lanyard attachment point in the tail looks thin, and my wear through over time. But this is a design style I like, as it maintains tailstanding.
    My sample developed some intermittent flickering in the Turbo mode. It would disappear upon switching down to the lower modes, and may or may not re-appear when switching back to Turbo. Removing and re-installing the battery usually resolved it, and I couldn't reliably elicit it. I suspect it is a circuit issue, as there was no sign of it on the other modes.
    As the second member of the new C-series from Sunwayman, the 1x18650/2xCR123A C20C shares many of the same characteristics I described in my recent C10R review. But there are few aspects I prefer to the C20C.
    The UI is basically the same, except for the addition of an extra "Turbo" mode on the C20C. This interface gives you a range of options, with blinking modes well "hidden". As with all electronic switches that offer both momentary-on and click-on, it may take you a little while to get used to the exact timings. But once you do, it works consistently.
    The physical build is also comparable, with similar styling and the trademark attractive natural anodizing finish from Sunwayman. I am very glad to screw thread anodizing has been restored on the C20C (i.e., so that you can lock out the light). The C20C is quite petite for a 1x18650-sized light as well.
    Performance-wise, the C20C is very similar to my Eagletac D25LC2 clicky – both for absolute output levels and relative runtime performance (see output measures earlier in this review). This demonstrates a good current-controlled circuit. Although relative spacing is good, I would still like to see a lower Lo mode (i.e., there is certainly no "Moonlight" level here).
    The C20C shares the same head design as the C10R, so should have a comparable beam. However, I found my C20C sample to have more irregularities in the corona around the hotspot (likely due to variability in the exact seating of the reflector). This produces some artifacts around the beam's hotspot (although it is really more a problem on white walls than in real life use). Overall beam pattern is still quite good, and very similar to some of the XM-L-based Zebralights (i.e., relatively large hotspot, with a wide and even spillbeam).
    While generally similar to the C10R, I personally prefer the extra touches on the C20C (e.g., the anodized screw threads, pocket clip, extra Turbo mode, larger battery capacity, etc.). It is also remarkably compact for a 1x18650 light. Unless you really need the compact size of the C10R, the C20C may be a better option for overall versatility and extended battery capacity.
    C20C was supplied by Sunwayman for review.
    Default Re: Sunwayman C20C (XM-L, 1x18650/2xCR123A) Review: RUNTIMES, VIDEO, BEAMSHOTS and mo
    Nice review. Thanks you!
    1st) SWM V11R, 2nd) Klarus XT11, 3rd) Klarus XT1C, 4th) JetBeam PC10, 5th) Malkoff MD2 w/ M61W, 6th)...
    Thanks for the great review, as always.
    Flashaholic* kj2's Avatar
    The Netherlands
    Thanks for the review
    Fenix HL10 - E01 - E11 - E20 - E21 - E25 - E35 - E40 - PD32 UE - TK11 R2 - TK21 U2 - TK35 - TK41 - TK70 - TK75
    Olight M22 - SR51 - SR95UT - Klarus P1C - XT2C - SWM R10A - EagTac GX25A3
    Just 2 questions Selfbuilt:
    (1) How come your SC600 now throws 167 meters, over the old 145 meters?
    And the RRT-21 throws 173 meters, over the old 155 meters?
    Most of your data has changed?
    Edit:
    Oh, now you measure them 30 seconds after activation.
    That means before, you measured them instantly?
    (2) Is there any good reason the Sunway C20C only outputs 620 lumens OTF, rather than the SC600's 780 lumens?
    Quote Originally Posted by peterharvey73 View Post
    Edit:
    No, I've always measured at 30 secs post activation. The new numbers (in orange highlight) are due to a new NIST-calibrated lightmeter. It is all explained here:
    Revised Selfbuilt beam intensity measures: new NIST-calibrated Extech EA31 lux-meter
    It's a design choice - not everyone chases the max lumens. Of note, the SC600 was always pushing the envelope for max output - but offers several other programmable lower multi-hundred lumen Hi modes to choose from instead. The C20C is a more straight-forward light, with a balanced approach to size and output.
    Flashaholic BWX's Avatar
    Aug 2007
    Upstate NY
    That lanyard looks identical to the one I have on my Crelent 7G5 v2 (production).
    I think it came with my 7G5, about 90% sure- I have so many lanyards laying around from all these lights....
    |I¤I|Fenix LD20+ Premium R4, TK45 - Quark AA/2AA R5&S2 x2, Preon 1/2 S2/ h.CRI x2 - Olight i6 Paladin - Spark SL6-800CW / ST6 500CW headlamp - Xtar S1 - Crelant 7G5 V2 - Eagletac D25LC2 - ZL SC600 MKI b U2, [s]MKII pre-ordered![/s]|I¤I| [s]strike[/s]? WTF?
    Flashaholic frosty's Avatar
    Jun 2006
    Glasgow / Edinburgh
    Another great review.
    Just updated the review with specific measures of when the red LED battery indicator activated.
    Aug 2007
    Upstate NY
    For me, a warning at about 3.6 volts would be helpful.
    Nov 2001
    los angeles
    Thank you for the review! A few questions:
    1) Is the protruding button easy to activate by accident?
    2) How many amps on turbo?
    3) Any beamshot comparisons with the ZL SC600?
    Questions/Answers here:
    http://www.answersingenesis.org/home/area/qa.asp
    "So then, each of us will give an account of himself to God." Romans 14:12
    Quote Originally Posted by carl View Post
    Hard to say, I haven't tried carrying it on me. It would certainly be a lot easier than the Zebralights, and I used to find those periodically activating on me. I recommend storing it locked out at the switch or tailcap if EDCing on your belt or in a pocket.
    I don't typically do tailcap current draws at higher outputs, as I know from experience that the DMM and leads can introduce significant resistance. On more highly-driven lights, this can definitely lead to spurious outcomes (i.e., circuit reacts differently, with lower output, etc.). The only way to ensure reliable current draw measures is at the head, using a bench-top power supply (which I don't have).
    The white wall beamshots are in the review - I don't plan to do outdoor ones. As you tell from the shots, the profile is similar - with the SC600 having a slightly wider spillbeam and a slightly wider hotspot.
    Nov 2001
    los angeles
    Selfbuilt - thank you for your answers and for this review. This light is a very interesting option to the ZL SC600. As you said, I wish it had a lower low though.
    Enlightened ouchyfoot's Avatar
    Apr 2010
    After examining mine, I tried opening the tailcap using medium strength. Mmmm...maybe it doesn't open this way. I checked the included manual and it showed it in the diagram with the head off and a battery beside it. I really had to tork down on it, but finally it gave. I looked inside and there was blue gunk dried all over the threads. Mmmmm
    I read your review closely and noticed you said only the tail opens. Mmmmm. I exerted presure and the cap came loose.
    I guess I wasn't supposed to remove the head. What I need to know is if I should leave the head as is or locktite it back down?...or maybe I should just grease up the threads.
    Quote Originally Posted by ouchyfoot View Post
    It shouldn't matter. The head of mine is obviously loctited, but it shouldn't make much of a difference either way. Surprised you had a hard time withe the tailcap on yours, sounds like they loctited both ends on your sample?
    Aug 2009
    Far east, Nippon
    Great review!
    I really like this SWM, because of its size, but a draw back is the Medium Low, I`m missing really a Low Low.
    Specs say 15lm.. but you even measured 27... thats a bit too much for a low..... my taste!
    Buttrock Re: Sunwayman C20C (XM-L, 1x18650/2xCR123A) Review: RUNTIMES, VIDEO, BEAMSHOTS and mo
    My C20C showed up from Battery junction, light was smaller than I thought, and I like it a lot, thanks for the review. My Callies 3100's fit just fine, and the kids have spent 4 hours in the pool with it last night, no leaks!!!!!!!!!!! It's floody(knew it would be), and maybe we will see a light like this with a G2 LED. No low/low so it will be more of an EDC light vs camping. I've ordered 3 more for family members.
    Quote Originally Posted by brag View Post
    No that's what I call extreme torture testing.
    Apr 2010
    I found that I have to crank the tailcap really hard to make contact. It doesn't matter what kind of battery. I'm a big guy and when I tork down the lid of a peanut butter jar...your not gonna get it open. I think the body could have used an extra thread. I'm afraid I'm eventually going to mash the threads or lose tailcap contact altogether. Is there some kind of very thin washer I could put in the bottom of the tail to effect earlier contact?
    LOL, I know, 4 hours in water, no Problem. 4 hours with kids, EXTREME testing. I bought a Pelican light many moons ago, it had a small piece of paper stating: "The guarantee does not cover shark bite, bear attack and children under five" I wish I had framed that!! Pelican people equals smart peoples.
    I agree, lower lows needed. It seems like manufacturers do not want to make the perfect all around light so to justify the large line of offerings. If all SWM products had sub 1 lumen modes and a beacon mode I would probably never buy another brand.
    Quote Originally Posted by ChibiM View Post
    Great review!
    Oct 2010
    Ukraine, Kiev
    Unprotected cells supported?
    Quote Originally Posted by Romanko View Post
    Judging from my protected 18650 runtimes, it looks like the light will just continue to drain the cells until they are dead. However, there is a very clear drop-off in output long before that happens, which you could use as a signal to recharge the cell.
    What is the current drain on Turbo mode and High mode ?
    Are the 650 lumens on turbo mode for the production model also, or only the prototype one ?
    Quote Originally Posted by BlackhawkB View Post
    I don't typically do tailcap current draws, as they aren't always indicative of emitter drive levels (and the output/runtime graphs answer what most people want to know in terms of levels over time).
    AFAIK, my sample is the final shipping version. But as with all lights, I don't know if the manufacturer has made any changes in drive levels since this review was completed.
    Nov 2012
    Auburn, Wa
    Question on "working voltage" when using 18650 cells in this light. Per specs above "Working voltage: 4~8.4V". So how is this possible with a 3.7v cell? My concern at this point is running unprotected 18650 cells and this light over discharging past 2.5v min that may ruin the batteries. Any help appreciated..
    Quote Originally Posted by Verndog View Post
    The working voltage range is to indicate that 2xCR123A and 2xRCR will work in the light, in addition to 1x18650.
    The issue of over-discharge is different. In this case, you can tell from the runtimes that 1x18650 either drops-down or rapidly falls off in output as the cell nears exhaustion. So you could probably use unprotected cells fairly well (on Med-Hi) if you wanted to - just make sure to charge the battery by the time you notice a drop-off in output.
    Nov 2012
    Auburn, Wa
    OK I get that you can tell when to change, but my concern with a light of this type is if accidental power on occurs (very possible with this type of switch), and it goes undetected...will it drain the battery an ruin the cell? Since I haven't bought the cells yet, I could get protected, but prefer the unprotected for cost and possible fit reasons. So, bottom line, is there a low voltage cutoff in the light?
    Thank you for the help.
    Kevin
    Great review!
    Sunwayman use one 2600mAh 18650 battery. Can i use one battery like this below or 3400mAh?
    • Panasonic 18650A
    • Capacity: 3100mAh
    • Recommended Max Discharge: 6.2A (2C)
    • Full charge: 4.2V
    • Nominal voltage: 3.6V
    • Cut-off: 2.5V
    The reason I ask is I don't know the technical specs of the light. Is it better to have the possible higher retained voltage of the 2600 mAh battery. Or the possible higher retained amperage from the 3100mAh or 3400mAh battery?
    *Flashaholic* Patriot's Avatar
    Feb 2007
    Arizona
    Kevin
    Kevin, I'm certainly 'on board' that it's interesting to know if it has low voltage cutoff or not but the reasons that you're citing for the possibility of running unprotected cells are quite trivial. It seems that this light accepts 3100 & 3400mAh cells. No fit problems thus far so count that as a non-issue . 18650 protected cells are available for as little as $7-8 a copy. What does an unprotected 18650 cell cost....a dollar less? I think the safety benefits far outweigh any perceived objections.
    Without a bench top / power supply, I don't think Selfbuilt has any way to test whether this light possesses a low voltage cutoff without actually running a non-protected 18650 in the light. Perhaps you could send him one to possibly ruin.
