Supbeam Light
Results 1 to 11 of 11
Thread: What's the throwiest Peak Mountain Series light? How many lux?
    Default What's the throwiest Peak Mountain Series light? How many lux?
    I would assume it's the Logan with the narrow optic. I see the Eiger Ultra X, but I can't imagine it's sustainable to drive the XP-G that hard for very long at all. Is there anything I'm missing?
    This is probably a stretch as most folks don't buy Peak Lights for the throw, but does anyone have any lux numbers?
    Thanks!
    -G
    Default
    Actually, given its small size (narrower than a p60 by several mm), Logan's throw remarkably well, better than equivalent size reflectors (at the expense of beam quality).
    Ultras use the very optic, just with smaller eiger sized batteries. Ideal would be a Logan ultra, using an optic at once larger and more focusing than comparable reflectors.
    Default Re: What's the throwiest Peak Mountain Series light? How many lux?
    Does a Logan Ultra exist? The only difference would be the drive current correct? Thanks for the info.
    Jan 2006
    Arnieland
    No Logan Ultra. I wish such a thing existed, but that's what the NP300 is for. Now that thing has throw!
    Funniest CPF thread ever. I promise it'll make your day.
    One more question... RMSK says on the Logan page that "All optics are narrow unless stated" but the little chooser on the Oveready site says "Large Optic". Is there a difference?
    Flashaholic* archimedes's Avatar
    Mar 2011
    CONUS, arteriosus
    Default
    I am wondering if the Pamir may have a bit more throw than the Logan, with its larger optic?
    I have a Rainier, but the P7 is a floodier emitter than the XP-G in the Pamir.
    IF 2 = 1 THEN 1 = 0
    Administrator Norm's Avatar
    Jun 2006
    Gippsland Australia
    You can definitely see the project die when using my 2 AA Pamir not as focused as an aspheric but quite throwy.
    Norm
    i think the Ural is the brightest and with the best throw. It is an XML with a TIR. Mine is brass and it is my favorite Peak light putting out around 500 lumens on a 18350 IMR battery
    Is the Pamir body interchangeable with the Logan body?
    Mar 2011
    CONUS, arteriosus
    Default
    Quote Originally Posted by GeoBruin View Post
    Yes, I believe so, although I don't have a Pamir to test directly ... the Logan and Rainier can swap parts between them.
    My guess is that the Ural is brighter, but might not actually have more throw (the XM-L is more efficient but a larger die) .... I found an old post from DUMDUM where he notes that the Pyrenees has the best throw of this series, but less than the Night Patrol.
    The Pamir and Pyrenees should be very similar (each has an XP-G with 20mm optic), with the main difference being the 18mm cell capability and Judco Kroll switch on the Pyrenees.
    EDIT - here's that post ...
    http://www.candlepowerforums.com/vb/...-Peak-Throwers
    IF 2 = 1 THEN 1 = 0
    Great info. Thank you.
