So we know the Fenix E01 is a great vampire light to draw the last drop out of an AAA, but what do we have in the AA front?
NOTE: Edited post. Previously said "parasite" instead of "vampire"...
CMG/ Gerber Infinity. Pulls every last ma out of a cell.
+1 on the Gerber Infinity..!
Any of Peak's AA models.
Great spirits have always encountered violent opposition from mediocre minds.
-- Albert Einstein
Oh, you mean vampire lights.
Safe lights/PALights use a 9 Volt battery long after a smoke detector says it is dead.
EDIT: My mistake... I missed the AA prerequisite.
I do have a joule thief that can use a AA. I am not sure how long it lasts though. I have had it by my bedside for the better part of a year using it a bit each night. I am still on the original half used battery.
Hahaha yes vampire lights. An AA battery vampire. I thought it sounded funny but couldn't quite put my finger in it, which is why I put it in quotes
Know of the Joule Thief but not wanting to hack a host for it...
________________
Sent from my mobile device. Please excuse the brevity of this message.
Member Qwillis makes a joule thief driver and now member Nailbender is makeing dropins with them
No need to hack
Best one I have for this job is an old and cheap Task Force 1AA that Lowe's used to sell. I haven't seen this model in a while, however. My Nitecore D11.2 is a good vampire, too.
Geoff
Inova has a few AA models that should work well for this. Only reason I still have my 123a Inova.
• Mobile post
I assume the value of having a "vampire" light would be to drain the last of the charge out of PRIMARY batteries (alkaline or NiMH)?
ὁ θεὸς φῶς ἐστιν
Anybody ever use an incan for a vampire light? I assume that would work well since it's more of a resistive/inductive load compared to that of an LED.
EDIT: I know this is an LED forum, just curious...
Last edited by Tegan's Dad; 08-06-2012 at 08:00 AM. Reason: incan comment in LED forum
Incans don't even compare to LEDs for sucking the last 5-10% out of a battery they tend to go "orange" at about 1.1v per cell vs LEDs can change tints but give useful light down to 0.5v per cell with the right driver. The currents at which the low level outputs are at are so low that I don't think any incan bulbs are designed for that low current and voltage to give any light at all.
JT is basically a DC-DC step-up circuit (not necessarily regulated), originally designed to power a single LED from a 1.5V battery and drain nearly all of its available energy. There are many variations on this theme. Wikipedia article
Any flashlight able to almost completely drain the battery can be considered a vampire light.
Cheers
+2 for El Capitan. I found an old "heavy duty" zinc-chloride AA cell in a drawer in an office building my company is remodeling for utility use. On a lark I popped it into my El Cap. To date, the light has been draining the cell for over five hours of occasional use, with no sign of diminishing output. Either its a very efficient light engine, or the zinc-chloride chemistry was vastly underrated.
The Gerber recon is pretty good at running down cells as well
What is it in the electronics that makes a flashlight a good "vampire" light? That Peak QTC El Capitan looks like a pretty nice light, although a little pricey for me right now. Which of the less expensive AA lights would be best as "vampires"?
ὁ θεὸς φῶς ἐστιν
Thanks folks I'm going to pull the trigger on the El Capitan that I've held back since last year. Now it's just a matter of figuring out the scheme (eg. SS head with Brass body and SS lug... etc). Was thinking the Eiger as well but I'll hang on to a E01 for AAA.
That's a good point. I'm eyeing the 6v Haiku and Sapphire GS. I'll jump on those first and keep thinking about it. If I happen to see the Gerber locally soon (WalMart, etc) then I'll stop thinking about the Peak.
________________
This is a smart statement for sure, people spend a lot to suck alkalines dry which is like saving 2 cents of wasted energy to damage a $30 light for good (at times). Personally my vampire type setups are typically under $20 and more often I have drained batteries with something like a nite ize 2-6 cell drop in wired up to a paper clip attached to a battery so if it leaks it ruins nothing but the surface it is sitting on.
