Results 1 to 6 of 6
Thread: Any headlamp with an asymmetrical beam?
    Flashaholic TweakMDS's Avatar
    Jun 2012
    The Netherlands
    Default Any headlamp with an asymmetrical beam?
    I realize this is kind of a long shot, but when I was looking at some beamshots combining the SC51 and H502, I made the connection to my car's headlight and wondered if any headlamps (or simply flashlights) exist that have a beam that's floody on the bottom and throwy at the top?
    If you take a look at a car's headlight, that's exactly what they do: throw a wide, oval beam in front of you and then throw kind of a low beam straight forward (angled down a little).
    Seems like a great idea to optimize the light output for a headlamp, especially in the single AA / CR123 lights, where max output is rather limited by the available power.
    Flashaholic* degarb's Avatar
    Oct 2007
    Akron, Ohio
    Default Re: Any headlamp with an asymmetrical beam?
    The PROBLEM is battery limitation. I have a wide hgih def cree. Great wide flood, but no use for it, with its forty min of useful lux. Floodier means more current to do things. I would be happy if rather than flood v. Spot debates, we would be asking wide v. Spot. I say this as the wide disciplined beam is all you could ever ask for in vision, with no wasted light.Also, keep in mind that car headlamps are not mounted on you head, so the light does follow around where you are looking. That is the beauty of hl over flashlight. If you use a flashlight plus hl, you get foot flood. I make my own wristlights that I wear on watch wrist, from flash lights and a better battery source. There is a new fenix 4 aa that I wonder would work.
    Some people are all lumens and no lux, while others are all lux and no lumens. Some just thank God they have neither.-- All of my lights have throw--some pretty darn far, into the garbage.
    Flashaholic* Bolster's Avatar
    Oct 2007
    Mexifornia
    Quote Originally Posted by TweakMDS View Post
    ...wondered if any headlamps (or simply flashlights) exist that have a beam that's floody on the bottom and throwy at the top?...
    Yes, the Pixa 2 & 3 have a "weighted" beam that's throwy top, floody bottom.
    See: http://www.petzl.com/en/pro/pixa/pixa-line (Mods please note: this is not a sales link, it is a product description link.)
    Sorry, thread necromancer here as I brows some of the older posts. Ahorton makes a floody/throwy headlamp, now on his third version of the design. Only issue that I have heard is that the floody and throwy LEDs have a different tint to them, so it makes for an interesting blend. His design uses two 18650's mounted on the back of the head, so while the flood may be more "wasteful" there is enough juice to compensate for convenience. Dunno if that's the type of light you're looking for. Its more of a "throw on the top and flood all over. Its $300 too...
    Thread is....
    here
    Flashaholic* uk_caver's Avatar
    Feb 2007
    Central UK
    If the original question was about beams with a spot and downward throw, there were 'Dosun' headlamps, which, used an optical arrangement of an LED firing downwards into half a reflector, giving a spot beam with floody downspill (from light missing the reflector) but no upspill.
    Not sure if they're still making them (couldn't be bothered trawling through their website).
    It's a nice geometry for some uses - I was using it myself for some caving lamp inserts well before they invented/patented it.
    Aug 2012
    UK
    Fenix BT20, if you can find a way of sticking it on your head...
    GM
