Maxpedition
Results 1 to 7 of 7
Thread: Trustfire TR-J12 KD driver swap
    Flashaholic* jmpaul320's Avatar
    Mar 2012
    CT, USA
    Buttrock Trustfire TR-J12 KD driver swap
    Today I did this build:
    Which is to swap the stock driver with the KD 5 mode one. Reports of 4000+ lumens. We shall see
    Heres a stock look at the internals of the TR-J12
    Opening the head and tail cap for access was easy actually.
    I used calipers and they popped right open!
    old driver next to new kd one
    The new driver did NOT drop right in, I had to take a rotary tool to both of the boards to slim them down approx 1-2mm before it fit right. No big deal, and I got to use powertools
    My soldering skills are not great, but theyll do. The positive contact is a ball of copper braided wire with solder
    I then created my own isolation disc.... out of... electrical tape..... this is a budget mod!
    modded the tail cap spring (there is braided copper wire covered in solder to take the heat. From what I have heard this thing will melt springs especially when the voltage drops and the driver sucks even more amps from the imrs.
    tail cap assembled. (I later put the piece of plastic back in for isolation)
    I was definitely nervous about firing this one up. I repeatedly screwed and unscrewed the head in to make sure I wasnt spinning the wires around too much and damaging them. In fact I purposely twisted the head around counter clockwise in the air so that when I screwed it in it actually untwisted the wires.
    Still a bit concerned after checking my connections. I definitely did NOT want 3 26650 unprotected IMRs going nuclear at full charge
    Drumroll:
    good form!
    yes that photo is a bit blurry, and I don't care... my camera sucks - and I blew all my $ on flashlights.
    The only bad thing is that I am getting some serious PWM flicker on 5% and 25% modes... sometimes it even happens on 50% Bad form!
    Oddly, sometimes if I cycle through modes again it stops I was a bit annoyed at first since other modders did not get the same results I did with PWM. Maybe I will mail KD and ask them about it. But then again, I really did not build this for the 5 25 and 50% modes now did I?
    Also, the stock wires in the tr-j12 suck. They're too thin for sure. Perhaps when I get more adventurous I will replace them with teflon wires.
    So how bright is this? And how much improvement was there over stock.
    Well before we go to the numbers let me just say that THERE ARE NO DISCO MODES. This was a huge thing for me. I have no use for modes that are likely to induce a seizure
    Here is some raw data (all measurements were taken at turn on with 3 freshly charged mnke imr 26650s with the flashlight/light meter in the same place under the same conditions)
    Ceiling bounce (for added reference my sst90 mag running on 9a dw driver put out 200 lux on this same test)
    Stock TR-J12
    Low - 42 lux
    Medium - 178 lux
    High - 288 lux
    KD driver TR-J12
    5% - 88 lux
    25% - 202 lux
    50% - 291 lux (essentially the same as stock high mode!)
    75% - 384 lux
    100% - 491 lux*
    * Yes I feel that I must put an * here. This is because I do not believe the 491 to truly be an accurate measurement. I have read reports here that this thing puts out like 80+ watts for the first few seconds on fresh cells and then quicky drops to around ~55 watts (stock driver is 29w)
    Needless to say after about 15 seconds that 491 dropped like a brick!!
    After about a minute it settled down around 425ish and then slowly started declining about 1 lux every 3-5 seconds (most likely due to the heat this thing was throwing off)
    In this test 100-115 lux ceiling bounce seems to equate with close to 1000 lumens. So 4000 lumens does seem accurate.
    This was a fun mod and took about an hour. I think it was worth the $20 I spent on the driver. The 100% mode on this is visibly brighter than the dry 3 xml cool white I am thinking I will replace the crummy stock wiring when I get a chance. As for the PWM flicker - I guess I will live with it for now.
    I believe this is the cheapest way to achieve 4000+ lumens. I paid $58 for my TR-J12 (it can be had now for 49 from ali express) + $20 for the driver. Cost me $78. The dry goes for around 68 on cnquality goods I believe and that is ~3000 lumens.
    Cheers
    Mar 2012
    CT, USA
    Default Re: Trustfire TR-J12 KD driver swap
    Reserved
    Flashaholic* mvyrmnd's Avatar
    Sep 2009
    Victoria, Australia
    Default
    I did the same thing, but my KD driver dropped right in with no modification needed. I didn't do as many low resistance mods as you, which would explain my lower final output.
    I don't believe there's a cheaper way to 4000 lumens at this point, and the 50% mode will run a full burn without overheat or failure. I think of 50% as high, 75% as "turbo" and 100% as "nuke" mode.
    Mar 2012
    CT, USA
    Quote Originally Posted by mvyrmnd View Post
    i agree... low modes are ok, but not really used lol... thats what my edcs are for, low usable light. ill grab this thing when i want to derail a freight train
    Mar 2012
    CT, USA
    i just looked at the dry 3xml cw next to this side by side... the hotspots are close to the same as far as brightness with the trj12s being about 15% bigger. the additional lumens is mostly in the corona/spill which makes sense since it has 5 emitters vs the drys 3
    the drys tint is a little nicer imo, more of a coolish white, just a hint of ice blue, but no purple or uglyness. my trj12 has a slight hint of green to it, but its still acceptable as far as tint goes imo. (btw i am slowly turning into a tint snob, can you tell?)
    Sep 2009
    Victoria, Australia
    Want to see what this mod is capable of?
    120m Beamshot Comparison Thread
    Mar 2012
    CT, USA
    nice beamshots
    this thing does have "some" throw, but not in the traditional sense... what I mean is that it normally is a floody multi emitter light, but due to the sheer output the entire WALL of light gets thrown quite a good distance lol.
