Supbeam Light
Results 1 to 10 of 10
Thread: Charging A 18650 With A Hobby Charger
    Default Charging A 18650 With A Hobby Charger
    I am planning on buying some Xtar 18650 3100mah batteries for my new Crelant 7G5 V2. I was wondering since i already have a quality hobby charger for my RC lipos can i charge some 18650 on there? the charger is a thunder ac680 and can carge any type of cell so i would just put it on the LiIon setting then this is were i need some help to be safe. I have to set the amps i want it to charge at, i was thinking .5 of an amp but my charger can go all the way to 6 amps.
    Default Re: Charging A 18650 With A Hobby Charger
    Panasonic recommends a charge rate of .3C (885ma). While the panasonics can be charged at a higher rate their life expectency will probably be shortened. I would not exceed .7C charge rate. I charge all my li-ions on a hobby charger.
    great to know thanks and how do you tackle the harnessing or connection to the battery? i was thinking some alligator clips with magnets.
    Magnets such as this is what I use. You can also make balancing wires for charging multiple cells by soldering on magnets to the balancing wire leads.
    Good thread on charge rate for panasonic 3100mah batteries.
    perfect thank you! actually one more thing im sorry im making some magnet harnesses right know is it ok to make a charging harness like this
    with 22 awg wire or is that to thin for the main charging wires as im only doing one cell at a time. if not i can get some 18 awg pretty quick which should unless someone tells me different .
    Banned
    Dec 2011
    Northern Europe
    Depends on what current you're planning to charge them at.
    I'd stick to 600mA (CV termination current of the 3100mAh cell * 10), with that current 22AWG is enough.
    http://www.candlepowerforums.com/vb/...p-instructions
    Will yield a better connection than magnets.
    wow that's actually a really good idea thanks for sharing.
    Quote Originally Posted by rustlerdudr987 View Post
    perfect thank you! actually one more thing im sorry im making some magnet harnesses right know is it ok to make a charging harness like this with 22 awg wire or is that to thin for the main charging wires as im only doing one cell at a time. if not i can get some 18 awg pretty quick which should unless someone tells me different .
    According to online wire size calculators 22 AWG should be good for 7 amps for short distances. I would fill safe at 3 amps with a foot or so of length. I have tried pushing 24 AWG stranded wire up to its rated current with a hobby charger. It did work but the wire got hot after a minute or so of use. I changed it out for some 22 AWG and it worked fine at 3 amps with 8.4v.
