RofisLight
Page 1 of 3 123 LastLast
Results 1 to 30 of 69
Thread: Test/Review of Keeppower 16650 2000mAh (Black)
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Default Test/Review of Keeppower 16650 2000mAh (Black)
    Official specifications:
    • 16650 2000mAh Protected Rechargeable Battery
    • Min Capacity: 2000mAh
    • Typical Capacity: 2100mAh
    • Normal Voltage: 3.7V
    • Quality Lithium Ion rechargeable cell
    • In Built Safety Circuitry
    • Protection Circuit (Against overcharge, over discharge, over current and short-circuit.)
    • 4.3 volts max voltage and 3.6-3.7 volts nominal voltage
    This battery is a 16650, i.e. it the diameter is less than 18650 batteries, this makes it a good battery for 2xCR123 substitution in lights that are to tight for a 18650.
    To get the full capacity from the battery it must be charged with a 4.3 volt charger.
    The protection PCB restrict the current to somewhere between 2 and 3A continuous load.
    The protection PCB stops this test premature.
    The batteries can hand about 3.3A for a short time.
    Test with 4.2 volt charging
    When charged on a 4.2 volt charger, there is about 80mAh capacity loss.
    Conclusion
    The battery size is interesting and can be useful and because it is a new generation LiIon it has better capacity than 17670 batteries, even when only charged to 4.2 volt. As long as it is used to replace CR123 batteries, the current limit will seldom be a problem.
    All in all I will rate it as a good battery.
    Notes and links
    Keeppower is a OEM manufacturer, i.e. many of the batteries they produce is sold with other names on them.
    The batteries was supplied by Keeppower for review.
    How is the test done and how to read the charts
    How is a protected LiIon battery constructed
    More about button top and flat top batteries
    My website with battery, charger, usb reviews, comparisons & information: https://lygte-info.dk/
    Latest addition is multimeter reviews
    Dec 2007
    USA
    Default Re: Test/Review of Keeppower 16650 2000mAh (Black)
    Do these use the LiNiCoO2 NNP cell design?
    Will the 17670 ever increase in capacity?
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by MichaelW View Post
    That is a Panasonic technology and this cell was designed by Sanyo (Sanyo is now a part of Panasonic). The Sanyo datasheet does not specify anything about cell design.
    Depends, if some manufacturer want to use a few millions cells in that size, the large LiIon manufacturer might update the design.
    Flashaholic* BenChiew's Avatar
    Nov 2011
    Malaysia/Ship to Portland, Oregon
    Any news updates on this battery? Perhaps from someone that has used it.
    Any issues with usage and charging?
    Flashaholic* všlineurheilija's Avatar
    Jun 2011
    Finland
    Quote Originally Posted by Benchiew View Post
    I am using this battery in a Surefire G2X pro but i havent done any runtime tests and i charge it with a Nitecore intellicharger I4 V2.No problems so far
    Flashaholic* LEDAdd1ct's Avatar
    Jul 2007
    Hudson Valley
    HKJ, what say you?
    How is this cell holding up?
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by LEDAdd1ct View Post
    HKJ, what say you?
    Being a Sanyo cell, I would not expect any problems with lifetime, but I have no data on it.
    Jul 2007
    Hudson Valley
    Roger that.
    Thank you.
    Now that Sanyo is a (subsidiary?) of Panasonic, what will happen to Sanyo branded cells?
    Dec 2013
    Wisconsin
    I have a couple of lights that could use these batteries, but I have a couple of questions:
    1) How much capacity is lost at 4.3v versus 4.3v?
    2) Why 4.3 when 4.2 seems to be the standard?
    3) Will a typical protected cell by other mfr charge safely in a charger that outputs 4.3v?
    4) Is there a good charger that can do multiple different batteries and 4.3v that you'd recommend? I'm thinking 26650, 18650, maybe 17670, and possibly some aa type shorts.
    The Thrunite MCC-4 looks decent, but is 4.2v and a USB out would be handy.
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by Diesel Pro View Post
    1) How much capacity is lost at 4.2v versus 4.3v?
    Please check the review, it contains data for both 4.3 volt and 4.2 volt.
    This is one way to increase capacity.
    Mostly, especially with cheap batteries there is an increased risk (The big brands are tested that they can handle over charge).
    Using 4.3 volt on a 4.2 volt battery will overcharge the battery and seriously reduce lifetime.
    It looks like Xtar has a new charger that can do 4.35 volt, but I have not tested it yet.
    At the current time the best solution for 4.30 volt is a hobby charger, where the output can be adjusted (Like iCharger), but that adjustment can only be adjusted to 4.30 volt, not 4.35 volt (As some other batteries requires).
    The usb output on chargers can usual not be used while it is connected to power, only from a battery and for that purpose I will recommend getting a separate usb box.
    Flashaholic* tobrien's Avatar
    Dec 2005
    Georgia Highway 441
    HKJ, I have two of these cells and just to clarify, is 4.35 volts what the charger will have to put out?
    I am going to be buying an XTAR SP1 for some LG D1 cells (I will be buying those D1 cells at the same time as the SP1), but it appears there are 4.3 volt cells as a different class or something.
    Are 4.35 and 4.3 volt cells the same thing or is it just semantics that is causing this confusion?
    This review says 4.3 volts, but cottonpicker's charger and the XTAR SP1 both say 4.35 volts, for example, so is this cell not okay to use with the cottonpickers 4.35v charger or the XTAR SP1?
    edit: my two 16650 2000 mAh cells I actually bought because of your review!
    I see you kind of answered this question in the post above, but I'm not entirely clear still on if 4.3 vs. 4.35 is a huge difference or just a semantics thing or they shouldn't be mixed lol
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    There are both 4.30 and 4.35 volt cells, they are not the same thing.
    Using a 4.35 volt charger on a 4.30 volt will overcharge it and reduce the lifetime of the cell.
    I looked at these batteries for a while before placing them in two slightly modified Surefire E2D models. The first is an incandescent with a Lumens Factory EO-E1R 3.6V bulb, and the second is a LED with a Malkoff Devices E2/Scout M600 2-3 CR123 3.4-9.0V head. While I don't have the equipment or experience to provide any detailed runtimes or battery performance data, I can say that the batteries fit perfectly in a E2 body and have performed very well in both lights while carried on a rotating daily basis.
    Enlightened editedby's Avatar
    Dec 2005
    New York City
    I'm not able to locate these from a USA dealer. Anyone have a source? FYI Keeppower.com.cn has these listed as 2200 @3.7
    Mar 2006
    BE
    Quote Originally Posted by __philippe View Post
    That's not a USA dealer. It's based in China.
    Mar 2006
    BE
    If you ask me, CN dealer trumps no dealer at all. Beggars can't be choosers...
    __philippe
    Dec 2011
    Southwest PA
    Just ordered two of these from Illumination Supply, although they are 2,500 mAh instead of 2,000 mAh, with a maximum voltage of 4.35 v. If these work as expected in my FourSevens QT2L, I may be looking for a 4.35 v. charger. If the unused capacity from using a 4.2 v. charger is on the same order as the 2,000 mAh cells tested above, it does not appear that I will be losing much capability by using my current 4.2 v. charger until a 4.35 v. charger can be located.
    Feb 2013
    Amsterdam
    I have two of these 2000mAh batteries and they fit perfectly in stock Surefire E2E, 6P and C2 bodies.
    It's mainly used charged to 4.2V with Tana's low voltage TripLED 219 on an 11 year old E2O body with the option to switch to AA in case they run out.
    Dec 2005
    Georgia Highway 441
    Quote Originally Posted by BillSWPA View Post
    I think the difference with the new Keeppowers is they are UR16650ZTA, whereas what HKJ reviewed here were the UR16650ZT (no -A at the end)
    Moderator
    Dec 2008
    Penn's Woods
    Just ordered a pair of the "A" suffix 2500ma protected cells from doingoutdoor via Amazon. Looking forward to seeing how they work on a 4.2v charger, and how quick shipping is. More capacity than 17670's, and I won't use these in the high-drain stuff.
    Flashaholic* LightWalker's Avatar
    Jul 2007
    USA
    Are these actually shorter than the AW 17670?
    I am come a light into the world, that whosoever believeth on me should not abide in darkness. - John 12:46
    Jun 2008
    TX, USA
    I have the new KeepPower 16650 2500mAh UR16650ZTA 4.35V battery and it fits a LITTLE tighter in my WF-139 charger. So just a hair longer than AW 17670.
    Jul 2007
    USA
    Quote Originally Posted by Bright_Light View Post
    Ok, thank you.
    Enlightened CSSA's Avatar
    Mar 2011
    Between Denver and Colorado Springs
    Orbtronic (orbtronic.com) expects to have 16650 protected cells available next week.
    What charger would you recommend to charge the 16650? XTAR says the VP2's 3.8 Volt setting charges to 4.35V.
    "Output: DC 3.0/4.35v
    3.0v/3.2v LiFePO4 Battery Charger (Charges to 3.2v)
    3.6v/3.7v Li-ion Battery Charger (Charges to 4.2v)
    3.8v Li-ion Battery Charger (Charges to 4.35v)
    " XTAR VP2 Specs
    Jun 2008
    TX, USA
    Just an FYI,
    I got my new Xtar WP2H charger in today and I can't get my KeepPower 16650 2500mAh UR16650ZTA battery to charge up to 4.35V. The charger gives me the "short circuit" warning and stops charging the batteries at 4.17V when using the 1 amp setting. I can get it to charge up to 4.21V when I use the .25 amp setting before the charger gives me the "short circuit" warning.
    So it must have something to do with KeepPower's protection circuit. That's my guess at least....
    Feb 2013
    Michigan, USA
    Just an FYI,
    Interesting, I have a VP2, and the same Keeppower 16650. Testing now - it has been a while since I needed to charge (run it in my Elzetta, and 235 lumens takes a LONG time to drain a 2500 mAh cell). Perhaps the protection circuit was not properly designed for the higher voltage? We shall see...
    Jun 2008
    TX, USA
    Quote Originally Posted by thedoc007 View Post
    Maybe.
    Let us know what happens with your test. Thanks
    Feb 2013
    Michigan, USA
    At 4.26 volts, as indicated by digital readout on my VP2. No issues so far, still charging away.
    Feb 2013
    Michigan, USA
    Just an FYI,
    Well, it isn't just your cell. It seemed to be running OK, but of course the readout leads the actual voltage by a bit (more at higher charge rates). My cell stops a bit shy of 4.2 volts also.
    I just noticed that the label on the cell lists it as 3.7 volts. If the spec was correct, full charge at 4.35 volts, it should be listed as a 3.8 volt cell. So now I am really annoyed. Whether or not the original cell was rated for 4.35 volts, I'm not sure, but clearly the protection circuit is not going to allow a 4.35 volt charge. So the specs (I bought mine at Illumination Supply) were definitely misleading. I wish I had a way to measure the total capacity of the cell, with a 4.2 volt charge. I suspect it will be substantially lower than 2500mAh.
    Overall, I still think it is a good cell. As I said before, I get plenty of runtime. But I will be informing Keeppower and Illumination Supply about the charging issue, and hopefully they will get the specs updated.
