Orbita
Page 1 of 8 12345678 LastLast
Results 1 to 30 of 214
Thread: NEW XML2 90 + HIGH CRI P60 / D26 Replacement Modules
    Default NEW XML2 90 + HIGH CRI P60 / D26 Replacement Modules
    These are XML2 emitters (XMLBWT000US60Z7) 3000k 90 cri emitters, S6 flux is the highest flux available in 90CRI. As with all XML2 emitters they have pretty good throw with a adequate amount of spill.
    As with most warm white emitters these look much like a incan and the color rendition is great. At S6 flux it is the highest lumen Hi CRI single emitter
    As with most XML2's both smooth and op reflectors are available. The smooth gives the best throw with a distinct hotspot while the Op will yield a slightly floodier and more blended beam.
    Please let me know if you are using in a Solarforce product as they can use a longer module.
    NOW MOUNTING EMITTERS ON ALL COPPER DIRECT BOND SINKPADS
    Available in the following levels
    3 amp regulated with last mode memory. (2.8v - 6v )
    These have reverse polarity protection and low voltage protection
    • 1 level
    • 3 level (low 5% / med 30% / hi 100%)
    • 3 level (low 5% / hi / Strobe)
    • 5 level (Moonlight / low 5% / med 30% /med high 40% / hi100% )
    While these can be ran at higher amperage you are paying for a certain tint and rating and above 3.0 amps the tints may not be true as designed.
    Also available in a 2.2 amp (3.6-16volt) One level
    __________________________________________________ ________________________________________________
    Price is $40 Includes free shipping in the US / free potting and 1 pc of Copper tape included in price.
    International shipping is $12 for 1st class Int. and $23.95 for priority mail Int.
    Paypal addy is in my Bio / please include CPF nickname and what ordered in paypal notes and below in thread.
    MAKE SURE YOUR ADDRESS IS SHOWING IN PAYPAL OR INCLUDE IN NOTES
    Dont forget to specify smooth or Op reflector if not listed Op will be installed.
    Below is a beam shot, it is not quite that beige looking in real life but a bit more incan looking. It must have been picking up the slightly off white walls.
    Default Re: 90+ HIGH CRI CREE XML P60 / D26 replacement modules.
    Hi
    This is a re-post of a thread started several days ago that got lost in the shuffle of the last few days. So here it is again.
    Sorry I can't do anything about the posts and the previous orders shown in previous thread but be assured all previous orders have been shipped.
    Thanks
    Dave
    *Flashaholic*
    Oct 2007
    Great South Bay, LINY
    Hi Dave,
    I'll take one:
    2 level (low 5% / hi)
    3.1A
    Smooth Reflector
    Potted
    Are you going to use any of these in D36 modules?
    Quote Originally Posted by donn_ View Post
    Hi Dave,
    I'll take one:
    3.1A
    Smooth Reflector
    Potted
    Hi Donn
    Sure I can put these in a D36 no problem but they either have to be a 6 volt max driver or the above mentioned 2.2 amp single level 18 volt max.
    Price would be $5 more / smooth or op
    Thanks
    Dave
    *Flashaholic*
    Oct 2007
    Quote Originally Posted by nailbender View Post
    Hi Donn
    Thanks
    Dave
    Cool. 6V is fine.
    for one with the same spec as the one I already ordered.
    3.1A
    Smooth Reflector
    Potted
    This is huge, IMO the most desirable XM-L available. Highest 90-CRI, highest flux group, and a "whiter," slightly cooler 7A2 tint (~3200K) versus the warmer 7A1 (~3000K) tint.
    ErikP for D26 drop-in: XM-L, 90-CRI, S6 flux, 7A2 tint *direct drive*, smooth reflector
    (Unique Transaction ID # 69V814567H8910444)
    Flashaholic* senna94's Avatar
    Dec 2005
    Houston, Texas
    Dave,
    I will take a 2.8 amp regulated 3 level (low,medium,high) with last mode memory and OP reflector.
    Thanks!!
    My father always told me there are three things I should never sell. My guns, guitars or McGizmo LS 20s.
    Cool. 6V is fine.
    3.1A
    Smooth Reflector
    Potted
    Hi Donn
    Both of yours have shipped
    Dave
    Dave,
    I'll take 1
    2.8A 2 level, SMO
    Paypal incoming
    Flashaholic ToyTank's Avatar
    Sep 2011
    Your Momma's house...
    Any chance you could make a mule P60 drop-in with these?
    CPF: 91FromStars
    90+high CRI XML P60 style
    2.8 amp regulated with last mode memory. (2.8v - 6v )
    3 level (low 5% / med 30% / hi)
    OP reflector
    Potting
    90+high CRI XML P60
    2.8 amp
    OP reflector
    Potting
    I will be putting this in a LP2, but I will be using protected batteries. Thanks for your help Dave.
    I'll take the following:
    2 Mode
    OP reflector
    Potting
    International shipping $5 for 1st class Int
    Paypal incoming
    Quote Originally Posted by ToyTank View Post
    +1 - Would this work OK in a P60 format?
    Quote Originally Posted by Xmldriver View Post
    Hi
    I am not sure what you all really are after, while not an expert I dont think the P60 pill will thread in a mule properly. Now if you mean can I do a module like a mule then the answer is no. To work in a P60 host there must be a reflector or something that provides the tension it takes to make a ground and positive connection.
    As I said I am not quite sure what you all were asking but maybe that answered it.
    Dave
    Hi
    Dave
    Thanks Dave, great response as always :-)
    For me, I'm after a 'wall of light', with no or very little hotspot and an even beam. I understand this is a challenge in the P60, hence my question. I think maybe the closest we'll get is a heavily stippled reflector? What do you think?
    Sep 2011
    Thanks Dave that is exactly what I was asking. I'm not sure what they are called but I have seen P60 modules without reflector and the emitter mounted shallow for flood. Similar to some of the triples but without optics.
    Jan 2006
    Germany
    Hi,there!
    I will take one,
    2.8amp 3200k 90 cri
    OP Reflector
    potted
    Sep 2011
    Dave,
    I'd like 1x 90+ CRI XM-L drop-in
    2.8V-6V driver
    2.8A
    3 Level(low/med/hi)
    OP Reflector
    Potted
    Thanks
    Hi Dave, my high CRI drop-ins arrived safely and as ever I am very pleased with your work. The colour rendition is very good to my eyes
    Dave,
    I'll take one 90+ Hi CRI Warm White CREE XML P60 style replacement module.
    • 3 level (low 5% / med 30% / hi)
    • OP reflector
    • potting
    Thanks!
    Thinking of running one of these in a Fivemega 2*18650 Mag D26. I think it should handle 3.1amp with no problem, could I get any higher perhaps 3.5a or even 4.2a do you think?
    Hi
    If you do not want the proper tint then yes it can be built for 4.2 amps but still can only be ran for shorter periods of time on high.
    I am not quite sure why you would want to run a high CRI that much higher than specs but sure it can be done.
    Do realize it will tint shift running that much higher amperage and I am not smart enough to know if it messes with the CRI rating but I would imagine since it will tint shift there is some corresponding deviation in CRI.
    Dave
    *Flashaholic*
    Oct 2007
    Hi Donn
    Dave
    Gottem today, and, as usual, they're great. The tint and beam are fantastic, and low is excellently low.
    If anyone's on the fence on this emitter, don't be. It's beautiful!
    Hi Donn
    thanks for the kind words, I knew you would like them. They are a great warm white tint, Cree keeps surprising us. I would love to see some colored XML's such as red and greens.
    Have a great weekend
    Dave
    Dec 2005
    Houston, Texas
    I received mine today and was not sure what to expect. I am blown away by the tint on this beauty. It renders incandescent lamps obsolete. It is like the tint on my Surefire A2. This has given new life to my SF G2 nitrolon and replaced the FM strion kit I had in there. Incandescent color rendition,3-levels of output,primary and rechargeable compatible,LED regulated efficiency and long runtime. This is a no brainer.
    Please put me down for another one exactly as the first one I ordered Dave.
    Thanks!!
    Default
    One 90+ Hi CRI Warm White CREE XML P60 style replacement module.
    3.1amp regulated with last mode memory. (2.8v - 6v )
    3 level (low 5% / med 30% / hi). OP reflector. Potting and tape. Plus intl.post. 45 Paypal sent.
    Thanks!
    Sent from my XT320 using Tapatalk 2
    Oct 2002
    Baden.at
    Default
    Hi Dave,
    interesting tint, so I have to get one ...
    + a spare for my existing "neutral" insert.
    1 piece 90+ Hi CRI Warm White XML P60 Style insert +
    1 piece XM-L T6 3C 5000 K P60 Style insert
    both 2.8 A,
    3 level (low-->med-->high)
    last mode memory
    2.8 - 6 V
    potted
    OP reflector
    for
    2*40,--for the inserts
    2* 5,-- potting + tape
    1* 5,-- intl. shipping (up to 2 inserts)
    95,-- * 1,04 for PP fees
    = 98,80 sent
    PS: if the XP-G2 inserts will once be offered in three level low>>med>>high, or 2 level low>>high, I might be in for one (at least)
    another thing:
    after having done some very prolonged accu-cell testing, I noticed the following discoloration:
    I dont think there is any effect on the output or the beam.
    Insert with metal tape is very tight fit into body, heat transfered to body immediately.
    While having the light run, it was in front of a fan to cool it down ...
    ... but I am asking myself what to do, to prevent that for the new modules?
    (except for not doing the cell testing any more ...)
    [edit]
    that poor insert is done now, as the discoloration has extended further ...
    If anyone reads this, pls take my advise to not use a fan for cooling, but to submerge the light in water. That works much better. You have to get the heat generated away!
    (I did this at first, but the host showed not to be waterproof)
    [/edit]
    Quote Originally Posted by yellow View Post
    Hi Dave,
    both 2.8 A,
    last mode memory
    2.8 - 6 V
    potted
    OP reflector
    for
    = 98,80 sent
    another thing:
    Hi
    These are high wattage emitters and prolonged running of these emitters on high may have a detrimental effect, even with a fan running on the flashlight it is NOT like holding it in your hand. I have many many times told of the possible detrimental effects for laying a light down on high level for an extended period of time, I have always said a good rule of thumb is if it is not too hot to hold with your Bare hand then you are fine if it is uncomfortable holding it then turn it down or off. You hand still will wick heat better than moving air in my opinion.
    The other down side is the light is usually sitting in one position so all the heat is wicked upwards to same point to some extent. P60's are never going to be as heat efficient as an individual host designed for heat transference and of course this is why you will seldom find a manufacturer building XML lights above 2.5 amps.
    I can only do so much and then you have to monitor the heat, I use Arctic Aluminum when mounting all MCPCB's and fill all cavities with thermal epoxy after that you pretty much have to monitor the heat as there is not much more to do on my end.
    I quit doing runtime tests your way when the emitters got to the high wattage they are at now. I purchased a CBAIII battery tester (now CBA IV) and while expensive with the higher wattage emitters I thought it safer.
    Sorry wish I had a foolproof way to help
    I believe I answered your question on the XP-G2 in that thread
    Dave
    Flashaholic Ti²C's Avatar
    Jul 2009
    France
    Hi,
    PP #
    34B985473S0005504 sent for one module, xm-l 90+ cri, 3.1Amps with memory, 3 levels low-mid-high, OP reflector, free potting and int'l shipment.
    Thanks,
