SunwayLED
Results 1 to 5 of 5
Thread: Powerful all purpose flashlight
    Default Powerful all purpose flashlight
    Any help you guys can give me would be great, I have been looking for the perfect light all week but no luck. I need a powerful flashlight that also looks pretty cool =)
    ____I would like to purchase the light from a brick and mortar store. I am located in ______________.
    __x__I will be mail-ordering or buying online, so this doesn't matter.
    2) Budget: An easy question, but you may change your mind after answering the rest! :-)
    ____Less than $25.
    __x__Less than $50.
    ____Less than $100.
    ____Less than $150.
    ____Less than $300.
    ____I have no limit.
    ____I’m flexible, tell me what you gotJ.
    ____Other, please specify ________
    3) Format:
    __x__I want a flashlight.
    ____I want a headlamp.
    ____I want a lantern.
    ____I want a dive light.
    ____I want a portable spotlight.
    4) Flashlight-specific format/size:
    ____Keychain size.
    ____Every day carry small (2-4 inches).
    __x__Every day carry medium (4-7 inches).
    ____Holster carry.
    ____Big enough to need its own travel caseJ.
    ____I don’t care.
    ____I don’t know.
    ____N/A
    5) Emitter/Light source:
    __x__LED (known for efficiency, longevity, and compactness)
    ____I don't know.
    6) Manufacturer:
    __x__I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
    __x__I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
    7) What battery type do you want to use?
    __x__I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today’s most powerful lights)
    __x__I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
    __x__I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
    __x__I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
    __x__I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
    8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
    ____I want to navigate a dark room or read a map (0-10 lumens).
    ____I want to walk around an unlit rural area (50-150 lumens).
    ____I want to illuminate my entire backyard or a campsite (150-300 lumens).
    __x__I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
    __x__I want ridiculous amounts of lumens (800+ lumens).
    9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
    ____Less than 1 yard/meter (reading, other close work)
    ____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
    ____5-20 yards/meters (check out a noise in the backyard)
    __x__30-50 yards/meters (I have a big backyard)
    __x__50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
    __x__150+ yards (I want maximum throw possible)
    10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
    __x__30-60 minutes (I have plenty of batteries just ready to be changed)
    ____90-120 minutes (Runtime is moderately important, but still not critical)
    ____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
    11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
    ____Not Important (A “night-stand” light).
    __x__Very Important (Camping, Backpacking, Car Glove-box).
    ____Critical (Police, Fire, Search & Rescue, Caving, Survival).
    ____I don't care.
    __x__I don’t know.
    12) Switch Type and location (choose all that apply):
    ____I want a forward clicky (Helpful for momentary activation and signaling).
    __x__I want a reverse clicky (For use with multi-mode/level lights).
    ____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
    ____I want a body mounted switch (near the head, like on a Maglite).
    ____I want a tail mounted switch (found on the majority of today’s high end lights).
    ____I don't care.
    ____I don’t know.
    ____A simple on-off with only one output level is fine for me.
    ____I want multiple light levels. (Some lights have 5-16 light levels.)
    ____I want a selector ring.
    ____I want a strobe mode. (Blinks to show location.)
    ____I want SOS mode.
    ____I want a beacon mode.
    ____I don’t care.
    __x__I don’t know.
    14)Material/Finish/Coating
    ____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
    ____Stainless steel (durable, but much heavier than aluminum)
    ____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
    ____I don’t care.
    __x__I don’t know.
    15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
    __x__Red filter (for preserving night vision).
    ____“Hybrid” light (bright incandescent combined with long running LEDs)
    ____Pocket/belt clip
    ____Holster
    ____Wrist/Neck Lanyard
    ____Crenulated bezel
    ____Non-sparking Intrinsically Safe (IS) for use in explosive environments
    Default Re: Powerful all purpose flashlight
    With your budget, ShiningBeam Blaze or MG P-Rocket will offer you great bang for the buck. Blaze should do close to 600 OTF lumens, and P-Rocket close to 700. Both are under $50.
    If you absolutely, positively and seriously need something that can produce more than 800 lumens and even more throw, double your budget and take look at ThruNite TN11/TN11S, rated at close to 1,000 OTF lumens and beam distance exceeding 300 yards.
    *Flashaholic* Gunner12's Avatar
    Dec 2006
    MA
    Small and tons of throw don't go hand in hand. Small = smaller reflector = wider beam, but it might be doable in the size you want. The shiningbeam lights are probably your best bet.
    Quote Originally Posted by enomosiki View Post
    The MG P-Rocket is pretty much what i'm looking for. Do you or anyone know of one that may be a little bigger maybe around 7ish inches. Max i would be willing to spend is like 70 bucks on a really good deal. Thanks for the help =)
    PS. I also found the Crelant V9-T6, anyone know much about it?
    Jetbeam BA20 or BC25?
    Fenix LD01 R4, E05 R4, PD31, TK20, TK35, E11, Jetbeam BC25, RRT-0, Klarus NT20, iTP A3 R5, A3 Ti S2, 4Sevens Preon 1, Quark X 123^2, Sunwayman V10R Ti, Surefire G2X Tactical, ThruNite TN31, Mag-Lite XL50, Mag 2D XP-E
