Silky Gomboy
CLHC
PNW|WA|USA
Got this new Japanese folding saw yesterday.
Silky Gomboy
Two Locked Open Positions
Weight and Measures
Saw Blade
Side-by-Side Comparison with Bahco Laplander
In Hand
Initial Counter Top Imperssions
This Silky Gomboy feels great in the hand. It is relatively light in weight and appears to be built quite solidly. The entire "frame" down to the handle is metal with rubber "over mold" on it. Plastic would be the top "black" portion of the locking mechanism.
Technical Features
- 9-1/2-inch (240 mm) blade length
- 8.5 teeth per inch (10 teeth per 30 mm) teeth configuration
- 0.6 pounds (272 grams) operating weight; 0.8 pounds (362 grams) weight with carrying case
- Clear plastic hinged carrying case for storage and carrying is included
- Product applications include pruning & trimming, lawn & garden, construction
Specifications
Teeth per 30 mm / inch : 10 / 8.5
Length : Overall 19.88" (50mm), Blade 9.5" (240mm), Closed 10.63" (270mm)
Width : 2"
Weight : With Sheath 0.80 lb (363 g), Operating 0.60 lb (272 g)
Material : Steel, GOM Rubber
Color : Natural
Metal : SK4 High Carbon Steel
Blade Thickness, mm : 1.3
Kerf, mm : 1.4
Will have to put this Silky to some wood to see how it performs. That's all for now!
Similar threads
