Test/Review of King Kong ICR26650 4000mAh (Gold)
HKJ
Copenhagen, Denmark
[size=+3]King Kong ICR26650 4000mAh (Gold)[/size]
Official specifications:
  • Volt:3.7v
  • Capacity: 4000mAh
  • Size: 26mmx66mm.
  • Charge current: <=1a?
  • Weight: 95 g
The capacity is well above the marked value.
The two cells has the same capacity, but the voltage is not the same at higher loads.
[size=+3]Conclusion[/size]
The cells has a good performance, but they has a slightly different voltage when loaded.
I will rate this battery as acceptable.
[size=+3]Notes and links[/size]
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
tobrien
Georgia Highway 441
It works fine at 10A load, the difference in voltage does just mean that two batteries might not have the same performance.
okay thanks! i misinterpreted your results. :)
do you know if they're magnetic ends (like for a CottonPickers charger)? what normal retail charger (XTAR, etc.) would work well for these in the button top style? I think the WP6 II charger may be too short for the button top versions of these King Kong cells but I want the button top
HKJ
Copenhagen, Denmark
Have you tested the INR version of these? How would these compare? Thanks.
Not yet, I have ordered them and will test them when they arrive, i.e. the result will be up in one to two months, depending on shipping time and how many other batteries I have to test at when it arrives.
HiltiHome
Germany
...do you know if they're magnetic ends (like for a CottonPickers charger)? what normal retail charger (XTAR, etc.) would work well for these in the button top style?...
I own a couple of ICR and INR King Kong.
All of them can be connected with magnets.
I recommend XTAR SP2 charger.
Both flat-top and button-top batteries fit and are charged quick and spot on to 4,20V,
if You give them a second charge, at 0,5A, after LED went green.
tobrien
Georgia Highway 441
Magnets does work on the battery. For a retail charger I would look at the SP2.
thanks a lot you two! I appreciate it. :)
I'll pick up some of these King Kong cells and an SP2. thanks! :D
samgab
Auckland, New Zealand
These suckers are pretty consistent over the years.
I just bought one of these to run in a new 26650 flashlight, and did a quick initial 1A discharge test and this is the results I got:
Measured at 4335mAh / 15.8Wh with a 1A discharge. Rated at 4000mAh, so I'm pretty happy with that.
