MrAl
Hello,
This is a long story
It started when i bought a new cordless drill back about 6 months
ago. It came with two battery packs, which was nice, for only
$30 US at Home Depot. It's a 9.6v model drill. The drill came
with a 'battery charger' that also doubles as a radio OK, i
know that sounds strange, but the charger is actually a radio
with battery charging capabilities. The radio doesnt work very
well however, for pulling in faint signals, but the charger does
charge. I had hoped it was a 'smart' charger, but it wasnt.
The problem is, the charger keeps about 100ma (maybe a little
less sometimes) pumping into the battery pack, so leaving the pack
to charge 24/7, 365 days a year, will shorten the packs life down
to maybe a year or two. I didnt want to leave the pack out of
the charger either, because then you forget about it until the
next time you go to use the drill, when you find it's depleted too
far to use for anything practical, so you have to wait for a pack
to charge up before you can use the drill.
OK, so now you know the problem The question is, what is the
best way to do something about this?
I could open the 'radio/charger' and tinker with the charge circuit
to set up a trickle charge, and mount a switch on the thing to
switch between 'full charging' and 'trickle charging' which isnt
such a bad idea. On the other hand, it will void the warranty.
OK, so another idea would be to build up a new charging circuit
just for trickle charging, which wouldnt be too hard to do.
On the other hand, it will pretty much void out the original
charger and i'd have to have still yet another charger laying
around, and plugged in constantly.
Then i remembered some advice i had given on perhaps this site or
maybe another site, about using a timer to turn the charger on
once per day for about 15 minutes or so. At about 100ma, that would
ensure the correct trickle charge to the battery pack since
it would only be running for 15 minutes a day.
Well, the other day i was at Home Depot again for some other things,
and i noticed a small timer for $5 hanging on one of those displays.
It had four 'tabs' for turning something on and off up to twice per day.
Needless to say, I bought one and brought it home.
I plugged in the charger and pack, and set it up to turn on twice
per day (for now) but the intervals are set up such that you cant
turn it off before a 30 minute period is up. The way i figure it
though, 30 mins a day probably isnt too bad either so that's what
im going to do from now on. The charger will turn on once per day
and run for 30 mins and turn off again, every single day.
So far ive been monitoring the battery voltage and i'll probably check
it once a week until i determine that this method works good enough
to replace conventional trickle charging. I think it will, and i dont
think that the slightly more charge time will hurt the battery pack
either.
I just wanted other people to know about this technique so they can
keep their drill (or other portable tool) battery pack charged up
without worrying about damaging the battery pack.
If you want to try this, here are a few things you should know about.
1.
When the timer switches 'off', if your particular charger draws
any significant current from the battery pack you will end up with
a dead battery pack after a certain time. This means before purchasing
a timer you should check the current draw of the charger when it's
unplugged with a full battery pack installed. If it's more then
about 500 microamps, you may not want to use this method, although
it may still work. The 'break even' point is about 2 milliamps, so
if it draws as much as 2ma you wont be charging unless you increase
the charge time to 1 hour instead of 30 mins.
If it draws more then 2ma i wouldnt use it at all unless i was
willing to do some experimentation to determine if charging and
discharging a little more then usual would work in the long run.
2.
Almost any timer on the market will probably work, but it should
be capable of turning off within 30 mins. Some timers only turn off
after 1 hour of operation. While this might work too, i would stick
to the 30 min models only.
3.
This might work with NiMH cells too, but i'd monitor the
cell for the first few weeks. Also, 30 mins might not be
enough time per day for a typical 2Ah NiMH cell.
4.
If your charger is a 'smart' charger, you probably wont have to do
this at all.
RESULTS SO FAR
So far i've had mine on for about a week now, but because the
pack was self discharged for about two weeks im allowing it to
charge twice per day instead of once per day. I've checked
the battery voltage and it's only risen slightly, showing that
it's certainly not going through a full charge 24/7 but that it's
only getting a fraction of it's full charge per day. I expect
this to work very well. I'll switch to once per day soon too.
I'll try to remember to post any further results also, perhaps in
6 months or so.
Take care,
Al
either.
1.
2.
3.
4.
this at all.
RESULTS SO FAR
6 months or so.
Take care,
Al
