HKJ
[size=+3]AW ICR10440 350mAh (Blue)[/size]
Official specifications:
Internal resistance has been calculated between 1A and 2A.
There is a good match between the two batteries.
In this test I do overload the batteries, this is possible because it is a unprotected battery.
I uses 500mA as charge current, this is to high for the battery and will reduce the lifetime of it.
[size=+3]Conclusion[/size]
This is the first 10440 battery I test, this makes it difficult to say much about the performance compared to other 10440.
With AW behind it I will rate it as a good battery.
[size=+3]Notes and links[/size]
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Comparison to other LiIon batteries
- 10440 ( AAA )
- 350mAH
