TnC_Products
Ti Micro-Lux (Collector 5)
1. Karlthev
2. Sold
3. Sold
4. Sold
5. Sold
Specifications
Length - 2.490"
Battery Tube - 0.646" Diameter
Head - 0.740" Diameter
1. Karlthev
2. Sold
3. Sold
4. Sold
5. Sold
Specifications
- Made from Domestic Ti 6
- AR Coated Glass Lens
- 2-mode Driver (Hi (550mA) / Low (50mA)
- Automatically drops from Hi mode to Low Mode when battery gets low (lets you know you should charge the battery)
- Over discharge protection built in (Light will shut off when battery needs charging)
- Twist Operation for on/off and mode change
- When turned on it will blink after 2 seconds letting you know that mode is locked in.
- Twist on/off/on to change modes
- Mode Memory
- Intricate milling pattern on light
- 6 Trit slots on Battery tube (1.55 x 5mm)
- Two Trit slots on bottom of battery tube (1.55 x 5mm)
- Key-ring attachment
- Micro-Lux and a Serial Number will be engraved into the Head
- Uses the newest Rebel ES LED that produces 160 Lumens / Watt
- Uses 10280 Li-ion Battery (N-cell size) Will be Included
- N to AA Charging Adapter Will be Included
- Only 5 will be produced (Serialized 1/5 - 5/5)
Length - 2.490"
