Southpawtact
I'm planning on building a direct-drive setup in a Mini Ma@ 2 AA. It'll consist of an XML powered by two LiNiCoO2 14500's or two IMR 14500's. I'm not too well versed in the electrical side of things, so I have two questions. First, what power of resistor do I need to get the battery voltage down to the forward voltage of the led? Second, would I have to use IMR's or can I use the standard LiNiCoO2's for a little more capacity?
This light is going to be for the shock factor of a crazy amount of lumens coming out of a Mini Ma@. Runtime doesn't matter, it just needs to be as bright as possible. Also, the light will probably not be used for more than 30 seconds at a time.
