EagleTac 18650 3400mAh (White-green)
Official specifications:
- Made in Japan battery cells
- 304 Stainless steel button top
- High current load of up to 5A
- IC protected against short, over-discharge, over-charge
- Measures only 68mm in height
- Steel plate reinfocred bottom
- Ultra high capacity and high voltage even under heavy loading
- Voltage: Typical 3.7V (4.2V when fully charged)
- Capacity: 3400mAh (discharged at 0.2C)
- Dimensions: 18.6mm x 68mm (+/-0.1mm)
- Weight: 50gram
This is the latest cells from Panasonic with the highest capacity.
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
The two batteries does track nicely, due to the protection circuit the battery has slightly lower output voltage at high current.
Conclusion
This is a very good battery.
Like the EagleTac 3100 battery, this battery is very short for a protected battery, this can be useful sometimes.
Notes and links
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Bookmarks
