MojaveMoon07
I have several questions about the knurled stainless steel bodies for the Eiger and Logan/AA
These two links talk about the degree of sharpness of the knurling in the stainless steel bodies.
http://www.candlepowerforums.com/vb/showthread.php?283486-Eiger-Stainless-Steel-Knurled
http://www.candlepowerforums.com/vb/showthread.php?338098-17500-AA-Peak-Logan-QTC
In the second link, someone made this comment about the Logan SS:
"The body has a different knurl that all my other Peak lights - it's a very fine knurling with a number of shallow knurls rather than a few deep knurls. It gives excellent grip but I don't like the feeling - it feels a little like 1200 grit sandpaper; smooth with a bit of bite."
(1) So the Eiger SS body has a knurling that is less sharp than that of the Logan body ? And is the knurling of the Logan SS body sharp enough to be abrasive to a trouser pocket and to the aluminum body of a flashlight carried next to a Logan SS body ? How is the sharpness of the Eiger ss body for carrying in a trouser pocket and next to another flashlight ?
(2) In a thread (link) where a few people reported flickering in their SS Peak flashlight, someone speculated that SS is the culprit because of poorer electrical transmittence.
I'm unclear if the flickering that has been reported in Peak flashlights is limited to those units with momentary switches or if stainless steel may be a part of the problem; if I order a stainless steel lug, flat, or keychain body, is there a risk of flickering ?
(3) The Eiger at oveready.com uses a stainless steel head. If I paired that with an aluminum body, I wonder if that would make it top-heavy and if that top-heaviness would make that Eiger land probably on its head if it got dropped.
Peak's website (peakledsolutions.net) reports the weight for aluminum, ss, and brass bodies.
The Eiger ss bodies weighs about 0.7 ounces more than their aluminum counterparts.
What do you think of the possibility that pairing a ss Eiger head with a ss Eiger body would make it more likely that the Eiger would land anywhere other than the head because of the additional weight of the ss body ?
My concern about how a Eiger would land if dropped is because of the damage to the head from a drop described by member eyeeatingfish in post #14 here (link)
(4) A complaint I've read about titanium bodies is coarse gritty threads.
Would an Eiger ss body have threads that would make the head harder to loosen or tighten in contrast to the threads of an aluminum Eiger body ?
Thank you in advance for your time and help!
