MojaveMoon07
I was proceeding through the order form at oveready.com and got tripped up by two things.
(1) I want to order a head + body and also an additional head.
To order just a head, I have to select "No body (head only) (-$20)"
After that, what is the correct choice from the drop down menus for "Levels" ? At first, I started to select "No QTC (high only)" because I thought that option matters only when you are ordering a body or a body + head.
But then I thought that when ordering just a head that "No QTC (high only)" might mean that the length of the screw threads below the head might different than if I selected "Gen 2 QTC (multi level)".
What's the right choice ?
(2) Prior to the screen where you fill out your credit card information which has a web site address that begins with https, there is a screen where you fill out your name, address, and phone number which does not begin with https -- just http
Does this mean that while I am filling out name, address, and phone # and when I hit the submit-button that this personal identifying information is unencrypted and is being sent unencrypted ?
