Malkoff
Page 1 of 2 12 LastLast
Results 1 to 30 of 53
Thread: Olight S20 Baton (XM-L, 1x18650, 2xCR123A) Review: RUNTIMES, BEAMSHOTS, VIDEO + more!
    Wink2 Olight S20 Baton (XM-L, 1x18650, 2xCR123A) Review: RUNTIMES, BEAMSHOTS, VIDEO + more!
    Warning: pic heavy, as usual.
    The S20 is the latest addition to the Olight Baton series of flashlights (a series that look like, well, batons). The S20 is a model up from the S10, taking 1x18650 or 2xCR123A. For a comparison to the other Baton lights, see my S10, S35/S65 and S80 reviews.
    Manufacturer Reported Specifications: (note: as always, these are simply what the manufacturer provides – scroll down to see my actual testing results).
    • LED: CREE XM-L
    • Runs on: 2 x CR123A or 1 x 18650 battery (batteries not included)
    • Working voltage: 2.5~6V
    • Output (ANSI)/Runtime: High: 470 Lumens/2.25 Hours, Medium: 100 Lumens/9 Hours, Low: 5 Lumens/120 Hours, Moonlight: 0.5 Lumens/1500 Hours
    • Max beam distance: 328 ft (100 m)
    • Moonlight mode and High outputs can be accessed directly when the flashlight is off
    • Both fixed frequency and Frequency conversion strobe modes
    • Olight patented lock-out function
    • Strong removable magnet at the end of tail for secure attachment to ferrous surfaces
    • Removable pocket clip
    • Stainless steel head ring
    • Low voltage indication: side switch will glow red when power is low
    • IPX-8 water resistance
    • Impact resistant to 2 m (about 6.5")
    • Dimensions: Length: 4.17" (106 mm), Diameter: 0.9" (23 mm)
    • Weight (w/o Battery): 1.83 oz (52g)
    • MSRP: ~$55
    As with many of my other Baton-series reviews, my sample was an engineering sample without final retail packaging. However, I imagine it would look similar to the Olight S10 (which included a simple lanyard strap, extra o-rings, split ring, and manual). The S20 comes with a removable pocket clip, similar in design to the S10.
    From left to right: AW Protected 18650, Olight S20, Foursevens Quark Q123-2, Eagletac D25CL2, Nitecore EC2, Zebralight SC600, Sunwayman C20C.
    Olight S20: Weight: 51.8g, Length: 105.4mm, Width (bezel): 23.1mm
    Eagletac D25LC2: Weight: 50.0g, Length: 116.3mm, Width (bezel): 22.5mm
    4Sevens Quark Q123-2 X (Regular tailcap): Weight: 44.6g, Length: 112.7mm, Width (bezel) 22.0mm
    Jetbeam PC20: Weight: 60.0g, Length: 127.5mm, Width (bezel): 22.6mm
    Lumintop ED20: Weight 84.4g, Length 121.6mm, Width (bezel) 25.2mm
    Spark SL6: Weight 77.8g, Length: 125.5mm, Width (bezel) 30.9mm
    Sunwayman C20C: Weight 57.6g, Length: 104.8mm. Width (bezel): 25.6mm
    Thrunite TN12: Weight: 64.0g, Length: 126.9mm, Width (bezel): 24.1mm
    Zebralight SC600: Weight 87.2g, Length: 107.8mm, Width (bezel) 29.7mm
    As you can see above, my sample was an engineering sample, but the shipping version should look similar (except for the tailcap label).
    As with the S10, the S20 is quite small for its class. Overall build is similar to the S10, and features black anodizing (matte finish), with bright white labels. Although still without typical knurling, the S20 shares the same raised checkered pattern as on the S10. With the pocket clip attached, I'd say grip is reasonably good.
    The pocket clip is comparable to the S10, although a bit longer now. It similarly seems to hold onto the light fairly securely. I personally like it, as you can clip it on you in either orientation (i.e., bezel-up or bezel-down carry), although it might be rough on clothing given how tightly it fits.
    The S20 comes with plastic sleeve for use with 2xCR123A, to prevent battery rattle. You can take this out for use with 1x18650.
    One other thing is new - there is now a spring in the head. You can safely use flat-top high-capacity 18650 cells.
    Like the other Batons, the S20 uses square-cut screw threads (anodized for tail lock-out, like the S10).
    Light can tailstand, and there is a split-ring/lanyard attachment hole on the side of the tail cap as before. The tailcap in fact seems identical to the S10, with the same removable strong magnet (i.e., firm enough for the light to stand horizontally off any vertical metal surface). I previously prepared a video of the S10, showing you how to swap out the magnet in the tailcap:
    As with the S10, I find the tailcap rattles slightly in use. This disappears if you swap the magnet out, as the bundled o-ring is thicker than the magnet (at least on my shipping S10 sample), dampening any movement. If you want to keep the magnet installed, I'm sure you could fully dampen the rattle with a thinner o-ring inserted under spring.
    As before, the light uses an electronic switch, located near the head. However, the user interface has been updated from the S10 (see discussion below). Also, the low-voltage warning LED under the switch is back (i.e., as with the S35/65/80, but missing from the S10).
    On the S20, the switch will glow red as the battery nears exhaustion.
    As before, the light has a flat stainless steel bezel ring with a red o-ring, and a textured (orange peel) reflector. Again, the head looks visually the same as the S10, although I would expect somewhat higher max output here (based on the specs).
    I'll discuss tint later in this review. The reflector isn't very deep, so you should expect a wide spill beam. Emitter was well centered on my sample.
    Something I noticed on the S10 ( but seems a bit more pronounced on my S20, likely due to the greater output), is that there is a purple tint to the edge of the periphery of the spillbeam. This may have something to do with the red o-ring and anti-glare coating on the lens.
    Like the other Baton lights, the S20 uses an electronic switch for on/off and mode control. As before, a quick press and release turns the light on.
    Mode switching is controlled by holding down the electronic switch. The light will cycle between Lo – Med – Hi, in repeating sequence. This is similar to the early Baton lights, but differs from the S10, which stepped down after stepping up in outputs (i.e., Lo – Med – Hi – Med, in repeating sequence).
    As before, simply release the switch to select your desired mode. The light has mode memory – if you turn it off/on, the light returns to your previous level.
    The S20 also features the ultra-low "Moonlight" level, as the S10 did. You access this mode directly from off by a sustained press of the switch. This is an excellent adaptation, as you can always turn the light on in the lowest possible mode if you want (i.e., no matter where you memorized it before). Mode cycling and memory works as before, once on.
    There is still a "hidden" strobe mode, accessed by double-clicking the switch when on. Double-click again to return to constant on.
    The S20 also restores the typical Olight "soft lock-out" (which was removed from the S10). If you hold the switch down from On, after three cycles through the output modes, the S20 turns itself off. It cannot be turned back on until you rapidly press the switch three times.
    For information on the light, including the build and user interface, please see my new video overview:
    PWM
    There is no sign of PWM that I can see, at any output level – I presume the light is current-controlled, as claimed.
    Strobe is a standard "tactical" high frequency strobe, measured at 9.8 Hz.
    Standby Drain
    As the switch is an electronic one, a standby current drain is always present when a battery is installed.
    I measured this standby drain at 38uA for 2xCR123A, and 25uA on 1x18650. Although a bit higher than my S10, that still means for standard 1400mAh CR123A, you could expect over 4 years and 2 months before the batteries would be drained. For a 2600mAh 18650, that would translate into over 11 years and 10 month before a battery would be fully drained. Hardly a concern – although I do recommend you lock out the switch at the tailcap (or soft-lock out electronically) to prevent accidental activation.
    And now, the white-wall beamshots. All lights are on Max output on 1x AW 18650 protected. Lights are about ~0.75 meter from a white wall (with the camera ~1.25 meters back from the wall). Automatic white balance on the camera, to minimize tint differences.
    Beam pattern is as you would expect for a XM-L light with this size textured reflector – a fairly big hotspot and decent sized spillbeam. Scroll down for full output details in my tables.
    One potential issue – my S20 is rather green-tinted for a Cool White emitter, especially on the lower output levels. Note that there is always considerable variability in potential tints, as most manufacturers do not purchase specific tint bins from Cree. But it does seem like this relatively greenish tint is a common occurrence on these S10/S20 models.
    Note also that it is to be expected that there would be some relatively "warm" tint-shifting on the lower levels (i.e., this is a common feature of current-controlled lights). In this case, I suspect this is accentuating the slightly greenish tint of many of these emitters.
    The S20 has a balanced overall output pattern, not very throwy (as expected). Output is bit higher on max than the S10, but level spacing is otherwise not that different. Here is a summary table showing what my ANSI FL-1 lumen estimates are for the S20:
    As with my Olight S10, my estimated output levels are not that far off the published specs – except on Hi, where I find higher initial output. Here's the S10 for you to compare:
    Output/Runtime Comparison:
    The S20 has a similar distinctive step-down pattern as the S10: On Hi, after 5 mins, the light steps down to a slightly lower level – but gradually, over a period of ~4 mins. This differs from most lights that have an abrupt step. As a result, you are not likely to be able to notice the gradual dimming here.
    Efficiency seems excellent on the S20, on both primary CR123A2 and 18650 Li-ion.
    Baton lights all use an electronic switch, and therefore require a small stand-by current when fully connected. The standby drain on S20 low enough (25~38 uA) as to be practically negligible (i.e., would take several years to fully drain a battery). However, you can "soft" lock out the switch electronically (which should lower the current), and you can always physically lock out the S20 at the tailcap.
    All my S10 and S20 samples to date have had a noticeably green tint overall, especially so at the lower output levels. It is hard to draw any conclusions from my limited samples, but it is common for current-controlled lights to tint-shift warmer at lower drive levels (thus accentuating yellow-green tints). But it is hard to predict what you will get, as Olight does not confirm a specific tint bin. There is also a noticeable blue-purple tint around the edge of the spillbeam periphery on all my S10/20 samples.
    I described S10 as a nice addition to the Baton series of Olight lights - and the S20 continues in that tradition. Although very similar to the S10 overall, Olight has restored some of the earlier features of the other Baton S-series lights that I always liked.
    Let's start with what's the same as the S10 – the overall look and feel. You get a similar good clip (reversible orientation), keychain attachment point, and reasonable grip (all of which were improvements over the older Baton lights). The magnetic tailcap is identical between the S10 and S20 – and like the later-model S10s, the magnet can be swapped out if you prefer.
    The user interface of the S20 takes the best new feature of the S10 – the "hidden" Moonlight mode accessible from Off – and restores the other characteristics of the earlier Baton lights. Specifically, the mode sequence has returned to standard Lo > Med > Hi, and the "soft lock" after three cycles has been restored. They have also brought back the low voltage warning indicator under on the On/Off button (a feature which was missing from the S10).
    The S20 continues the tradition of a relatively negligible low uA standby current. And the performance of the light remains excellent in my testing, in keeping with the good current-control circuitry (i.e. very long relative runtimes). The S20 maintains the gradual drop-off in the Hi mode step-down brought in on the S10.
    Output levels are similar to the S10. Perhaps the only comment here is that some would like a brighter Lo mode, given you have the Moonlight mode available. I've handled several samples of S10 and S20 lights now, and all have had a noticeable greenish tint. Of course, tint is highly variable usually, but the apparent consistency here is something to keep in mind if you specifically don't like that end of the cool white spectrum.
    The S20 is a nice example of the ongoing evolution of the Baton series of lights. Certainly a strong contender in the slim and compact group of 1x18650 lights, given the excellent runtimes, straight-forward build and thoughtful interface.
    S20 was supplied by Olight for review.
    Default Re: Olight S20 Baton (XM-L, 1x18650, 2xCR123A) Review: RUNTIMES, BEAMSHOTS, VIDEO + m
    Max mode: 1H 22M...is that right? Maybe I`m following the wrong line? If correct thats not that good. The line I was following shows a bit less than 175 minutes...little less than 3 hours...very good.
    Quote Originally Posted by Badbeams3 View Post
    Sorry, that was a mistake in the figure legend. I just updated it. The actual runtime to 50% is just under 3 hours, as you observed.
    Nice review as always! I'm jelous though (as a proud owner of the S10) that the S20 returns the low voltage indicator.
    Thanks for the review!
    I also own S10 and I'm jealous, too But it would be a brilliant feature, if the indicator could serve as a beacon (similar to the Nitecore Explorer series). Too bad that the tint is still green, but there may be a titanium version with a neutral emitter...
    Flashaholic BWX's Avatar
    Aug 2007
    N.E. USA
    If it wasn't for the greenish tint, and if they drove the emitter a little harder on high or gave it a "turbo" mode, I'd like it a lot more.
    Thank you for the review, awesome as always.
    I also own S10, but the greenish tint were not so great, ended I swapped for a T6 3C, now its nicer & love it.
    I not really concern about the indicator on the S10 thou, cheers !
    My list of flashlights, chargers & batteries
    Nice review, thanks
    Does anybody know if an S20 pill will fit in an S10?
    Cheers
    Matt
    Flashaholic* NorthernStar's Avatar
    Apr 2004
    Sweden
    Outstanding review!
    My S20 is a standard production sample, and it does not have the pronounced blue-purple tint around the edge of the spillbeam like the one you describe. In fact i´ve never thought of it before untill i read this and compared it to mine. However your observation about the greenish tint on the low settings is absolutely right. On 0,5 lumens mode and at 5 lumens mode my S20 is realy greenish,but on the other two higher modes it has a perfectly white beam without any green.
    I know that the manufacturer does not recommend using it, but do you think that one can use RCR123 batteries in S20 without being harmful for the flashlight?
    LED: Olight I1 EOS,Olight S1,S1R,S2,S10R,S10RII,S15R,S20R,S30R,S30RII,S30R Javelot,Nitecore SRT7,Sunwayman V20C,Sunwayman R10A,FourSevens Atom AL,Fenix TK75 2015,Crelant CH10, and more
    Quote Originally Posted by NorthernStar View Post
    I wouldn't recommend trying it in this case - in the preliminary specs Olight sent me, they list the voltage range as 2.5~6V. You could thus potentially blow the circuit with 2xRCR (i.e. >8.4V fully charged).
    In 1x18650 lights that list the voltage range as up to 8.4V, you are probably safe giving it a try (even if not "recommended"). But it this case, it seems like it is actually not supported by the circuit.
    *Flashaholic* Patriot's Avatar
    Feb 2007
    Arizona
    Quote Originally Posted by BWX View Post
    I feel similarly. The size of the light is very appealing it just trails in output behind the other top performers.
    Thanks so much for this review Selfbuilt. I'll never post one of your threads without acknowledging your the hard work and time you put into these. Thank you!
    Great review Selfbuilt, I really like your analytical approach of your technical reviewsand looking how nice you do your math, respect!
    Reading your review about the S20 is the main reason I passed the S10 that was available at a very nice price in my village and ordered a S20 via zaklamp.nu. Very nice site and VERY quick delivery!
    Tonight I received my S20 and the size is really nice! The built quality like the bug brother SR-90 is really nice.
    The amount of light is also really enough to light up the complete area where you are walking. Compared to the ultrafire P7 both do about the same where the S20 is twice as compact!, talking about LED revolution
    The green tint at the 2 lowest modes is really present, at the 100 Lumen setting acceptable and at the highest level totally absent.
    Imagine having a shipbreak somewhere and being on an island with a box of CR123 batteries and this baby.
    0,5 lumen with to the dark adapted eyes at such a long runtime?, GREAT!! (Tom Hanks in the movie Cast Away would have been pleased with this baby )
    Two minus points: a) I didn't receive a double CR123 holder wich is nice when using this batteries in case of an empty 18650 an b) My Eden 69mm long 18650 fits barely, Now I have to get a panasonic unprotected 18650, how do I explaint THAT to my wife......
    One question comes up reading your reviews of all those flashlights: let they keep you all these lights??
    does an eagletac 3400 18650 fit in this ok ?
    fenix tk41..fenix tk35..nitecore ea4...olight s10 baton...xtar meteor...sipik 68...eagletac d25lc2...eagletac d25a...eagletac d25c ti 2013... a modded tn31..skyray king...nitecore dx.. sunwayman v11r.. + loads of other lights
    Flashaholic holylight's Avatar
    Feb 2013
    Germany
    Quote Originally Posted by lightliker View Post
    Selfbuilt I also interested to know do they let keep the sample lights...... Lol
    Feb 2013
    Germany
    Quote Originally Posted by Bumble View Post
    can can!! np because i using panasonic 3400 protected and is 1 of the longest and can be use ....
    http://lygte-info.dk/review/batterie...mary%20UK.html
    lights: saber1a, v11r, sc52, sc600ii, ea4, tn31, archer1a.
    Feb 2013
    Germany
    good review as usual. tyvm
    Feb 2013
    Germany
    selfbuild "Output levels are similar to the S10. Perhaps the only comment here is that some would like a brighter Lo mode, given you have the Moonlight mode available. I've handled several samples of S10 and S20 lights now, and all have had a noticeable greenish tint. Of course, tint is highly variable usually, but the apparent consistency here is something to keep in mind if you specifically don't like that end of the cool white spectrum. "
    anyone got a explanation for the green tint? many say is due to low quality cree led! is it true? but I like the green lol
    Quote Originally Posted by holylight View Post
    No, it is not a "quality" issue. All LED manufacturers would love to produce only the most premium (generally agreed upon) "white" tints, for a given color temperature. But it a feature of any manufactured process that you can't control all variables and outcomes. As a result, Cree (like all makers) bins theirs LEDs by color temperature, output, and Vf (and sells the "premium" ones for a higher mark-up). The non-premium bins may not even be uniquely idenfitied. Many makers (especially those doing a high volume of sales) have little choice but to buy a wide range of tints. There is nothing wrong with the emitters - they perform according to spec.
    For some reason, Olight seems to be getting a large number of relatively greenish cool white XM-L LEDs - but that probably just reflects Cree's manufacturing process and local availability. This greenish tint range is certainly been something that has been noticed for other emitters, from time to time (i.e., XR-E R2s and XP-G S2s come to mind).
    In the case, the current-controlled circuitry of the S10/S20 is probably accentuating the issue. It is well known the CC tint-shifts to the warmer-end of the spectrum at lower drive levels.
    Feb 2013
    Germany
    Buttrock Re: Olight S20 Baton (XM-L, 1x18650, 2xCR123A) Review: RUNTIMES, BEAMSHOTS, VIDEO + m
    thanks a lot for the answer.
    Mar 2013
    Eureka, CA
    Does the S20 have the same switch "feel" as the S10? I think my arthritic thumb makes it nearly impossible to double click into strobe on my S10 but on all my larger SR Olights it is not a problem. Thankfully, it isn't something I'd need often. Still, I'd like to be able to do it.
    Dave
    Quote Originally Posted by hikingman View Post
    Switch feel is pretty much the same on the S10 and S20.
    i never noticed it mentioned here, i discovered my S20 got turned on by accident once in my pocket, by loosening the tail cap a 1/4 turn locked it out, as the anodized threads blocks the continuity quite well. ( works on both my S10 & S20.
    Trying to achieve 1.21 Gigalumens. - (Also known as DBSAR)
    Flashaholic* LEDAdd1ct's Avatar
    Jul 2007
    Hudson Valley
    I can't see the beamshots.
    Is it my browser?
    Quote Originally Posted by LEDAdd1ct View Post
    Is it my browser?
    No, it seems to be an issue with photobucket right now. For the last few minutes, none of the images are loading, and I can't log into their site. Hopefully they will get it resolved soon.
    Is it my browser?
    doesnt work for me too ?
    EDIT just seen selfbuilts reply
    I see the lanyard hole, but does it come with a decent lanyard? I've yet to see one in any review. Thanks.
    Quote Originally Posted by Terry M View Post
    Well, the Olight website shows a very basic wrist lanyard as an included accessory. Looks like a lot of the really basic ones out there.
    Thanks! I didn't even notice that. As long as it does have one, that's all I need. Just placed an order, mainly based off your review. Thanks for taking the time to review.
    Does anyone know of a decent holster for the S20? I prefer something without a velcro flap, as the velcro seldom lasts long for me and then the flap sticks up (e.g., the FourSevens holster for the Quark lights). A topless holster, with elastic for retention, or a holster with a flap using a snap or other non-velcro closure would be preferred. I have taken velcro-flapped holsters and tucked the flap inside the body of the holster alongside the flashlight. That works OK, but the ucovered velcro on the outside of the holster then sticks to and destroys some shirt fabrics. Maybe a good quality velcro in a long strip might work, but the little small dime-sized patches of velcro common on cheap holsters just don't cut it in my experience. Thanks!
    Search for Nite Ize Lite holster stretch. I got mine at Home Depot. Not bad.
