Fitorch
Page 1 of 2 12 LastLast
Results 1 to 30 of 40
Thread: "Feit Electric" 3C LED flashlight
    Jul 2002
    Champlin, MN
    Default "Feit Electric" 3C LED flashlight
    When I was at our local Costco store today they had a rack with some "Feit Electric" brand LED flashlights in a 2-pack for $24.99 after $5.00 "instant rebate".
    If I recall correctly the information on the package said that the flashlights had two brightness levels plus a strobe and SOS mode. It also stated
    that the beam was "zoomable" from spot to flood. The package included six C size batteries, so I'm assuming each flashlight would
    require three C batteries. It said that the emitter was a Cree LED, but didn't specify which emitter was used. Brightness levels were
    advertised as 500 lumens (high) and 295 lumens (low). The Feit Electric product number was 654427, but it's not coming up on a
    Google search.
    Has anyone purchased one of these and if so what are your impressions? Sometimes some of these less expensive flashlights aren't
    too bad considering the price point.
    Flashaholic* mcnair55's Avatar
    Oct 2009
    North Wales UK
    Default Re: "Feit Electric" 2C LED flashlight
    Take a look on the budget section,they have Costco lights on a post at the moment,not yours but looks a deal to me if they do them in the UK I will have a pack.
    Diagnosed with Grumpy Old Man Syndrome
    I looked at them today at my Costco,for $12.50 each, might be worth a shot.
    Flashaholic* Newuser01's Avatar
    Jun 2006
    concord, ca - eastbay - US
    There is a bit of write up @ Slickdeals and some pictures there too. Seems like a better deal than the one from HD/Defient one? It may be direct driven like those 3 AAA lights but has modes: 500 lumen beam (7 hour run time), 295 lumen (10 hour run time), strobe, sos, off.
    Noob
    Poor noob who want some lights.
    Unenlightened
    Jan 2013
    Default Re: "Feit Electric" 3C LED flashlight
    Got this 2 pack today at Costco. Very impressive wide and concentrated beam and it appears that the 500 lumen rating is accurate. I informally checked it again my Surefire Fury. The problem that I noticed is that when you move the "zoom" too fast the light will change modes (e.g., high to low to stobe). I'm almost certain that this is not intended. I plan to return this pair and get another to see if this problem is only with this light or is, perhaps, a design flaw.
    Jul 2012
    D.C. Metro Area
    Aug 2002
    Stuck in California again
    Per the SD discussion, this is an aspherical lens type of setup, the sort that projects an image of the die at max zoom. Now I'm really curious.
    Aug 2002
    Was in Costco with the wife today, was able to snap a pic of the business end. That lens is not like any I've seen before. It looks to me as if a good percentage of light is lost inside this setup.
    Flashaholic* Beamhead's Avatar
    Jul 2004
    gone "Squatchin" :p
    Quote Originally Posted by jyflash View Post
    Mine don't do that, are you sure the tail cap is on tight?
    Quando Omni Flunkis Moritati
    Jul 2002
    Champlin, MN
    I wonder how this flashlight would perform on a single 18650 rechargeable lithium-ion cell?
    (i.e. using some form of spacer tube for proper fit and custom size dummy cell for connection).
    Just a thought...
    I got the Feit 2 pack too. It has a TIR lens similar to tbe Coast. HP550 they had a few weeks ago.
    The Led is a genuine Cree XM-L. At 12 bucks a light (including 3 Duracell Cs) I think is a good deal.
    Things i don't like is that when adjusted to spot, projects the led chip. Also the zoom head is way too loose and focus will move if are not very careful. The lens is plastic.
    other than that... 500 lumen aluminum.light for $12 considering also the price of the included 3xC cell.. should not be complaining
    Sent from my SGH-T999 using Tapatalk 2
    Aug 2002
    Allrighty, I picked up a set of these. All numbers are by eye, I have no instrumentation to measure output.
    The first thing I noticed was that the optic looks like the Coast frog-eye, but oddly installed "backwards", flat side facing the emitter. Not until I tried flipping it around did I realize the truth: it's not an aspheric, it's a Fresnel optic with just two "steps".
    Of my two units, one came in on the pinkish side, and the other came in on the pink side of the first one. Compared to my Coast HP550, definitely pink.
    Pics.
    The retaining ring comes off easily. There's a translucent silicone gasket that needs a bit of careful coaxing to fall out, and the optic comes with it.
    Optic in its original orientation.
    Pill in maximum zoom position. As predicted, a chunk of light around the edges is lost in those black sides, and this reduction is visible in bounce tests, I'd say 35-45% reduction.
    At the wide end. That yellow stuff looks like it could be a remote phosphor or something, yes? Nope. Checked it with a blue light, only the emitter glowed.
    Compared to the HP550, this light is about 70% as bright in wide mode. Zoomed in, it's no contest as this light loses output when zoomed in while the Coast actually gains it due to its design. The Coast hotspot also remains round, and by my eye would match or exceed the Feit for throw cd. That yellow ring also is dimly visible around the emitter square when zoomed in on a white wall.
    Heat sinking is good, the warmth gets to the outside world quick.
    Swapping in Eneloops (all at 1.28V) in one unit had no apparent effect on brightness versus the included Duracell C's in the other.
    Quote Originally Posted by Flashlike View Post
    Just a thought...
    Looks like two 18650's would fit in nicely, is there a easy way to tell if the driver can handle the increased voltage if they're run in series? I have about two dozen 18650 rechargeable lithium-ion cells from laptop batteries that I would like to be able to use. I know they're unprotected but I would match them, could this be done safely or is a single battery the way to go?
    Jun 2006
    Quote Originally Posted by ParadiseRob View Post
    18650 fresh off the charger is 4.2v x 2 = 8.2v sure thing it will go
    3 C cells are 4.5v So just one 18650.
    I would suggest you buy a light that uses one cells- It will be better all around.
    Or run c sized AA holders with Eneloops cells would be better.
    Noob
    Ok, one 18650 runs the light fine, I also tried two and it fried in an instant. Then I signed on and read Newuser01's warning oops!
    Anyone seen these in a UK Costco? I'd like one.
    Smile Re: "Feit Electric" 3C LED flashlight
    For the tube spacer on mine I just cut the side wall plastic on a powdered drink jug rolled it up and slid it in then for the dummy cell I used a 5/8th s wood dowel drilled down the center, copper wire pushed through and a drop of solder on each end. It works good.
    Jun 2006
    That would do.... Nice. Sorry to hear about the burn light though!!
    I would consider this a bed side light or a club to take with you when you hear things go bump in the night?
    Cheers.
    Noob
    I just got two of these and for the price, they are great! The finish on them is good and the focus actually works well. I am using them with 3 AA rechargeables with an adapter made from a piece of PVC pipe. The only thing odd thing about them is the spacing between low and high mode. There is not that much of a difference. A 50 lumen low would have made more sense. Anyhow, for $12.50 a piece with batteries, one cannot complain too much!
    Have they been spotted in UK yet?
    Not really a fan. They are heavy and the zoom rattles. That can likely be fixed with o rings, but I can buy a much better light for $12, even if it takes a couple of weeks to arrive.
    Default Feit Electric 500 3 C Cell at Costco $25.00
    Is it any good. Are they lying about the 500 Lumens?
    Got Any More Bright Ideas?
    Jul 2004
    gone "Squatchin" :p
    Default Re: Feit Electric 500 3 C Cell at Costco $25.00
    Quote Originally Posted by Top Cat View Post
    Where at?
    None in my UK costco. They just have the 3AAA
    I got a pair of these over the weekend at my local Costco. They're made OK -- the zoom focus on mine is reasonable smooth and well damped. On wide angle they're fine, with bright and uniform field. On narrow beam they project a perfect square image of the die which is hugely distracting.
    Good price, decent quality, big let down on optics. I'll probably return mine to the store.D
    on
    Quote Originally Posted by 4xdog View Post
    on
    The Sipik sk68 prjects an image on throw as well, all you have to do is zoom it out a touch to get a circle.
    I use mine all the time with the zoom on wide angle. If you take the light outside, you will not notice the LED image and they actually throw light a good distance. I just picked up some Powerex 5000mah NIMH C's for one of mine so I should get really good runtime with it also!!
    I am a "cheap but good" flashlight junkie (probably like a lot of others around here). I was at Costco today and saw the Feit 500 lumen 2-pack for $25 (with 6 C-cell batteries). Could not resist. Opened the package. uncscrewed the cap/base, loaded 3 batteries, put a dab of Tri-Flow on the threads, and screwed the cap on. Pushed the button and it shines pretty darn good! I have a couple of inexpensive Costco units on my shelf for comparison (the 200 and 250 lumen compacts that were sold in a 3-pack for $15-$20). They were labeled "Tech Lite Lumen Master (200) and "Cree" (250). Those little buggers are my standard measure for comparisons They are bright and have a nicely focused beam. All-around very good for the price. On-par with the $40+ Coast PX45 in terms of light output and beam clarity. Build quality is not quite as good as the Coast, but very respectable. The little Costco units are brighter than the $30 MagLite XL50, although bigger and heavier. The Mag's beam is more nicely focused. All I'm trying to say is... the little 200/250 Costco LED flashlights that came in the 3-pak are pretty darn good and overall quite nice. Especially for the price. Well, the Feit 500 COMPLETELY drowns them out when shine them side-by-side. I'd say that the 500 lumen rating for the Feit is accurate (relative comparison). At the "wide" (zoomed-out) setting, the Feit is fabulous -- with a perfect circle of uniform very bright light. Zoomed-in (narrow beam) it is certainly bright, but not quite as aesthetically pleasing -- because you see the square shape of the LED on the wall. Back off the zoom slightly and it becomes a softer more pleasing shape. I have not gone outside in the dark to evaluate range, but the packaging says 978-ft. And the Feit easily outshines the 2D LED Mag-Lite ($30) that I got as a gift about a year ago (which was my brightest LED flashlight with the longest/strongest beam -- until now). For $12.50 each (with batteries) I'd say the Feit is excellent. Amazing. Of course, with 3 C-cells, it is bigger and heavier than the lower-powered units with 3 AAA's. But it is quite a bit smaller than the 2D Mag.
    Holy smokes! I just went outside (dark) and "zoomed in" (narrow beam)-- Whoa! What an impressive long-distance spotlight! The packaging says 978 ft "beam range" -- which doesn't seem out of the question based on what I just saw holding the thing in my hand and pointing it down the street at some trees.
