neutralwhite
do any modders have this drop in already ?.
also does one LED just give like 150 lumens if it was just on its own ?.
then there is a better reason to maybe have 3 right?.
thanks kindly...
EDCPlus/IS X60L3 Triple LED P60 Dropin (High CRI/Neutral White)
$74.99
EDCPlus and Illumination Supply have teamed up to bring you the X60L3, a triple LED dropin that is low on cost, but doesn't skip on an ounce of quality! The dropin was designed with the user in mind, and comes in a diffusor/head tool case, and even an AR lens to maximize the output from the dropin. Unlike competing dropins, the X60L3 has been tested in an integrating sphere and is compliant to the ANSI FL-1 test. The LEDs - 3 Nichia NVSL219AT-H1 , are being driven at 2A, and puts out an extremely efficient 465 High CRI lumens rare in such a small package. This is achieved by our custom LED board and full copper unibody construction. For eelctrical conductivity and appearance, we have also silver plated the copper.
Introductory Pricing! Use the coupon code: X60L315 to get 15% off from now till the end of January! (While supplies last)
Specs:
Features:
https://illuminationsupply.com/edcp...d-p60-dropin-high-crineutral-white-p-320.html
thanks kindly...
$74.99
Specs:
- Powered by 3x Nichia NVSL219AT-H1 High CRI (92) 4500K (Neutral White)
- Modes: 3 Mode (High, Medium, Low)
- Current: 2A +/- 100mA
- Input Voltage: 3-6v
- Supported Cells: 1x18650/17670 Li-ion cells or 2x CR123 Primary Lithium cells. Do NOT use 2x RCR123/16340 Cells.
- Dimensions--Length: 29mm (40mm with spring), Weight: 38g (1.3 oz)
- Compatible with: SureFire P, C, Z,
Features:
- Pure Copper with real silver electroplating for superior thermal and electrical conductivity
- Triple XP-G2 Optic with up to 90% optical efficiency.
- Reverse polarity input protection
- Over-discharge protection ~2.75v (applies only to High and Medium modes)
- Gold-plated spring
- Linear current regulated. No PWM.
- Thermally potted driver
- X60L3 Drop-in module
- 60DC (case, removal tool and wand)
- 28.5 x 2.9mm AR glass lens
