Well, you'll have to open the circuit. 'Tailcap' current is easy to measure since it doesn't require disassembly. Otherwise you'll have to pop a wire between the driver and LED to measure it.
Measuring at the tailcap may give different current than is flowing through the LED - for example a 2-cell lamp with white LED will have a boost converter to generate enough voltage for the LED Vf, the boost in voltage comes at the cost of higher battery current.
