Olight - S1 - MINI
Page 1 of 2 12 LastLast
Results 1 to 30 of 38
Thread: Brightest handheld LED flashlight
    Default Brightest handheld LED flashlight
    Hello everyone.
    Out of curiosity I would like to know what is the brightest in lumens led flashlight that is out there commercially available, no mods. This topic has been brought out a few times but the threads were dated to many years ago and so in 2013 i kinda expect that there were some advances from many years ago. Thanks everyone.
    Default Re: Brightest handheld LED flashlight
    Depends on what you mean by handheld. You can hold a XM18 with one hand... but its kind of ridiculous at 15000 lumens and 12lbs. I think the more "reasonable" option is an Olight X6 Marauder at 5000 lumens. Beneath the X6 there are a ton of multi emitter lights in the 2000-3600 lumen range.
    "And the city has no need of sun or moon to shine on it, for the glory of God gives it light, and its lamp is the Lamb."
    | TM26 | M2S | M1X | BC25 | JET-IIIM | EYE15 | EYE10 TIC | Preon 2 Ti |
    Flashaholic* BLUE LED's Avatar
    Apr 2008
    UK
    Perhaps something a little smaller, Thrunite TN30 XM-L2 or Fenix TK75
    Thanks for the replies guys. I was refering to flashlights that don't look like spotlights.
    A P60 host with insane heat dissipation capability and triple/quad XP-G2 drop-in.
    Anywhere from 1,200 to 2,000 lumens.
    Mar 2013
    Boston
    I keep dying to have somebody do a head to head comparison of TM26 vs new TN30 XM-L2, they've been mentioned in the same thread a few times but no head to head analysis
    After searching around I found a "skyray" flashlight rated at 6000 lumens for about 70 dollars and i want to know if its any good since its much cheaper than led lensers and olights rated at 2000 lumens or above.
    Mar 2010
    TN
    You get what you pay for. Many lights with high ratings do not come near the listed specs, and the math simply does not add up.
    just a quick example. Still a bright light. But not as advertised.
    http://www.candlepowerforums.com/vb/...18650-or-26650)
    Keep it between the ditches and the shiny side up.
    Flashaholic Dr.444's Avatar
    Jan 2013
    Egypt
    Nitecore TM26 ,, 3.5K lumens ,, best choice !
    Quote Originally Posted by mestizobloke View Post
    It's very unlikely to be 6000 lumens. Many cheaper flashlight brands are known for heavily inflating their lumen numbers. It's probably more like 2000 lumens.
    so the general consensus here is that the tm26 is the brightest in lumens commercially available LED flashlight (that looks like a flashlight) right now on earth?
    Flashaholic holylight's Avatar
    Feb 2013
    Germany
    can't help much my brightest is p25
    lights: saber1a, v11r, sc52, sc600ii, ea4, tn31, archer1a.
    yeah pretty much,but off world,well yeah, thats a whole nother story
    Mar 2010
    TN
    Its old, but the Fielong 2D80 360 csm is likely brighter when it works. Its a 360 csm is essentially 4 sst 90's on the same led board. The csm is capable of 6k lumens from what I understand, but likely less than that but still bright.
    Mar 2013
    Boston
    Quote Originally Posted by fireonhigh View Post
    Are u really gonna buy it or just kidding?
    Jul 2008
    Michigan
    Default Lumens king
    I haven't been keeping up for awhile, but I was just curious what's the current brightest flashlight out there.
    _________________________
    She says I have a fetish.
    Flashaholic* GordoJones88's Avatar
    Nov 2011
    Tennessee
    Default Re: Lumens king
    Eagletac SX25L3 is very compact for 2400 ANSI lumens.
    It is a new single emitter LED.
    Dec 2009
    Frisco, TX
    Coming this month Lupine Betty TL2 - 4500 lumens and much smaller than the TM26. Also, they are "measured lumens" out the front.
    http://lupine.de/files/documents/Lup..._2013_2014.pdf
    http://www.lupine.de/files/manuals/Betty_TL2Web-5.pdf
    Flashaholic* CarpentryHero's Avatar
    Jul 2010
    Edmonton
    Lux Rc Fatboy FB1 or the Olight marauder as said above. Both are at least 5k lumens and they are stock.
    Aside from those the new benchmark is about 4k lumens. There's an Olight Sr96 coming out, the new Lupine lights and more trickling out as the weeks pass
    I'm glad I found CPF, I was beginning to think I was strange
    I'm a Canadian and a proud Flashaholic
    Thanks CPF, thanks Think2x
    Zebralight s6330 should fit snug in the hand and has a decent 2400 lumens and moonlight mode is a bonus too. Difficult to find atm, though.
    Dec 2009
    Frisco, TX
    Quote Originally Posted by alex21 View Post
    S6330 is in stock at e2fieldgear. http://www.e2fieldgear.com/zebraligh...ed-flashlight/
    Mar 2013
    Boston
    Quote Originally Posted by CarpentryHero View Post
    Lux RC Fatboy doesn't even exist. It won't till at least 2014
    Jetbeam DDR30 @ 3200 Lm
    Sent from a BlackBerry Classic.
    Jul 2010
    Edmonton
    @ BeastFlashlight I thought the FB1 had already been released, I know they do really small runs and figured there sold out.
    Not that I have that kinda scratch lying around
    Mar 2013
    Boston
    I just found out not to long ago via the Lux-RC FL33 review thread that the Fatboy is a 2014 'Future' light, i swear finding out info on the Fatboy was like pulling teeth. Still don't know what the price tag will be, or what the lumens, and most importantly what the max output runtime will be. The deal breaker for me will be if it can only hold max output for a minute or so, and at it's tiny size i imagine that will be the case
    fb1 is built around active cooling turbine concept so you can run it on full as long as needed with no heating at all.
    this is basically the core idea of this light.
    grab 12 leds and drive 2 amps to each isn't something extraordinary, it's rather a trivial thing to do
    Mar 2013
    Boston
    Oh only driven to 2 amps, so it isn't gonna be a ton of lumens?
    2 amps per each led. The total count is 12. The total wattage is 80 watts. The total flux is about 7000 lumens at least.
    yes, it's nothing special out of a pocket EDC light.
    PS. Thanks to new synchronous regulator the wattage has been extended to absolute maximum of XP-sized leds, so 6000 lumens is obsolete information. In fact the regulator is able to supply up to 170 watts (~4A per led) but this would fry the leds in seconds so 2-2.5 per led is a reasonable maximum. Probably I will shift the limits after testing the turbine in combination with direct heat sinking. It would be nice to try 150-170watts at least for a few seconds . The bottleneck is the supply (12 amps per cell). Only IMR will cope with this load.
    ----- updated on 17-sep-13 ------
