The Fenix-Store
Page 1 of 3 123 LastLast
Results 1 to 30 of 66
Thread: Olight M22 Review
    Flashaholic* firelord777's Avatar
    Jul 2010
    USA
    Buttrock Olight M22 Review
    Olight took advantage of the new XM-L2 LED in their new M22 flashlight. When the light was released, it received mixed reactions from the market regarding its look.
    Bottom line is, some liked it others, not so much. See for yourself:
    They sort of really emphasize the tactical aspect with all the military stuff on it don’t they?
    This side seems like something made for retail stores, it even has the square with the code on it.
    The presentation is stellar:
    The Olight comes with an Olight M22 (duh), a diffuser, a cool holster, a battery magazine for CR123s, a lanyard, 3 o-rings, and an extra GID tail boot (Glow In the Dark). For the purpose of this review though, Olight sent a SS bezel along with the light.
    Construction:
    My first impressions of the light was that it feels solid, reliable and has a surprisingly good finish to it. The letters and font on the two sides of the battery tube are nice and clear. The cooling fins on the head are just the right size, not too small to be of any use, but not so unnecessarily large either. The knurling is just awesome, it’s composed of these small little checkered raised rectangles. The bezel is tough and has a caution sign with the words “hot surface” laser etched net to it, and on the other side “CREE XM-L2” also laser etched.
    You cannot tailstand the light because of the protruding tail boot:
    The tailcap has a gold-like contact, below it is a normal spring, so it maintains its springiness but with good contact.
    Threads are well lubed and look like they’ll last for a long time:
    Inside the battery tube there is a convenient little shiny sticker in place to remind you which way to put in the batteries just in case:
    You can remove the grip ring, but doing so will expose an o-ring, you see two in the picture because I deliberately did not tighten down the tailcap fully.
    There is also a cool feature I haven’t seen yet. The clip and the grip ring have a complementary mechanism to keep themselves in place.
    The head doesn’t have anodized threads, so the light stays on even when the head is partially unscrewed, which is kind of needed because of the UI.
    The reflector is smooth and moderately deep, producing a beam that is throwy but balanced
    The light has thick walls, and it feels like it can take a brutal beating (the light to the side of it is the ArmyTek Predator):
    The bezel is simple to remove, just apply an average amount of initial force and the bezel loosens.
    The red o-ring is sprinkled with GID powder and at night it glows, I’ll take a few pictures of this soon.
    This is how it looks like with the Stainless Steel bezel:
    Diffuser:
    Straight forward pictures coming your way:
    Holster:
    The holster that comes with the Olight is impressive. It is made with some sort of slightly hardened material so it retains its shape. The stitching is flawless and thick. To the sides are two battery holsters so you can carry two extra 18650 along with your M22 in the holster. That’s an amazing feature, one I was waiting for a company to implement one day.
    A How-to Guide
    Replacing the tail boot on the M22 is a bit deceptively simple. For those familiar with common parts in a tailcap and steps to replace tail boots, the Olight has a slightly longer procedure.
    First, take some tweezers or something to poke into the two “pits”
    Next, start unscrewing it. It took quite a bit of initial force to loosen it, and make sure you press down, I slipped a couple of times and gave it a few scratches.
    Now, typically once you’ve done all this, all that is left is to remove the tailcap and put in the new one, however, this time, you will have to repeat the process again with another retainer inside.
    Cree XM-L vs. Cree XM-L2:
    Notice how the XM-L has lines across the LED while the XM-L2 does not
    Whitewall beamshots:
    First some suspensful pictures of the competitors:
    Below are the output levels of the M22
    Low:
    Mid:
    High:
    Reduced Exposures:
    ArmyTek Viking X:
    ArmyTek Predator SMO
    ArmyTek Predator OP
    Fenix TA21
    Crelant V6CS
    More to come soon
    I’ll be working on a few waterproofing tests, outdoor beamshots, diffuser beamshots and even the GID o-ring,
    UI
    I showed a few pictures previously of the UI of the Olight. Many originally wanted the side switch of the previous military lineup such as the M21. However, I think the UI with the M22 offers a better range of flexibility. I always have mine set to low, because I find that way, I have the best dynamics. I can readily use the low mode, and if needed, I can very easily access high output. Strobe is also accessible and “hidden” at the same time. Just give it a try.
    Conclusion
    I personally believe that the Olight is a considerable competitor in the tactical light market. Especially at the price point of $95. Outdoors, this light really shines. When I have the outdoor beamshots up, you’ll see what I’m talking about. It lights up the targets you point at and also everything around it. I think this type of beam can really help out in tactical situations, when operators need to cover large areas quickly.
    One thing I really did not cover in depth was regulation. The M22 is regulated on high, but has thermal management that steps down whenever the light gets too hot. This is welcoming, as usually it is much more beneficial to decrease the output to an almost unperceivable level and maintain safe operating parameters than push the LED too hard.
    For civilians (like me), the M22 offers a well designed light with high performance. Not only that, but it also has fantastic accessories to boot.
    Olight itself is a great company to deal with and respond to emails and inquiries.
    If you have any questions or requests, please feel free to ask me or send me a PM,
    Regards,
    Alain
    *Flashaholic* kj2's Avatar
    The Netherlands
    Default Re: Olight M22 Review
    Thank you very much and so many pics, I like that
    Hope mine will come this week.
    Question; if you remove the clip, will the tactical ring spin around freely?
    Jul 2010
    USA
    Default Olight M22 Review
    It's a bit difficult to remove the clip, I'll see what is the best way to remove it and I'll report back to you.
    Cheers
    Flashaholic* tobrien's Avatar
    Dec 2005
    Georgia Highway 441
    awesome work man
    How would you compare M22 to Fenix TK22 and Surefire Fury P2X in terms of quality of contruction?
    Jul 2010
    USA
    awesome work man
    Thanks a lot buddy You rock!
    Jul 2010
    USA
    Quote Originally Posted by Filip11 View Post
    As much as I would love to, I can't really help you there my friend. I do have a couple of Fenix lights, and they are also well built.
    Rest assured, they are all high quality lights, even the M22. I would expect it to survive and thrive with whatever you throw at it,
    Cheers
    Quote Originally Posted by firelord777 View Post
    Cheers
    Thanks for reply!
    I still have to think a bit, and decide between this and TK 22. Sweet decisions.
    should be submitted for the review forum section.
    very helpful pics!!
    Thanks! The only thing I found lacking was a picture of the light in your hand so I could get an idea of the size.
    Unfortunately I fall on the side of not liking the look of this light which was why I went with EagleTac's new XM-L2 light. Seeing your pictures next to other lights I think that it may not be as bad as it seems in pictures by itself. I did almost order the M22 from amazon to see if I liked it given their easy returns. Now if I could buy an M22 head to screw onto my M20 for like 60 bucks I'd have a hard time not doing it (unfortunately the threads are different ).
    Also, do you know which way that holster is intended to be used (up or down) ? Mine does not seem to fit through the bottom hole when pointing up.
    Thanks for the pictures!
    Flashaholic* SilentK's Avatar
    Jan 2008
    Southern Mississippi
    I'm actually one who thinks this light is quite attractive. I'm curious, I realize that you can tap the switch in quick succession to get instant access to high and strobe. Exactly how fast do you have to tap it momentarily to change modes? At what point does it not change modes, and just come back on in the set level?
    Jul 2010
    USA
    Quote Originally Posted by shelm View Post
    very helpful pics!!
    Thanks, but for some reason I'm never able to post my reviews there, the system just won't let me. All my reviews are in the LED subforum hehe
    Jul 2010
    USA
    Quote Originally Posted by TronPlayer View Post
    Don't worry, I'll get back to you soon
    Jul 2010
    USA
    Quote Originally Posted by endoracing View Post
    The holster to me was designed for both, but you're absolutely right, I have to give the light a push to make it go through when it's head up
    Jul 2010
    USA
    Quote Originally Posted by SilentK View Post
    All right, I just tested it out and you have to tap it within one second, after one second it comes back on whatever mode you left it on. So for strobe, I guess you have 2 seconds total to access it.
    If you don't really understand let me know
    Jul 2010
    USA
    @tronplayer:
    It's more or less the size of a small pen
    If you want more comparisons feel free to suggest other things to compare the size
    My hands are not the same size as yours most likely, so it may be misleading. I find comparisons to common household objects to be a much better representation of size,
    Cheers
    Any problem with the tint?
    I have a few Olights and 4Sevens. The lights that have XM-L emitters emit GREEN. Repeat, GREEN.
    Jul 2010
    USA
    No problems here, the beam is straight up white, the corona of the hotspot has a touch of yellow,
    Cheers
    Jan 2008
    I got it. Thank you very much! Even though I just blew a little bit of cash on a PD32, I'll certainly be adding this one to my list.
    Jul 2010
    USA
    You're very welcome my friend,
    Let me know if you need anything else,
    Cheers
    Flashaholic holylight's Avatar
    Feb 2013
    Germany
    Good review. Nice shot. Thanks.
    lights: saber1a, v11r, sc52, sc600ii, ea4, tn31, archer1a.
    Jul 2010
    USA
    Quote Originally Posted by holylight View Post
    Thank you
    Jun 2010
    South Korea
    Very nice review! Thanks a lot for your time & effort. firelord777!
    The polished bezel looks nice as well, and I feel the light is very sturdy.
    Is that bezel optional to purchase? Thanks in advance.
    Jul 2010
    USA
    Thanks buddy
    I'm not sure about the bezels, I'll ask Olight
    Cheers
    Jul 2010
    USA
    Hey Candlelamp,
    Olight has responded that they are, in fact, offering bezels for sale. You'll have to contact then for details, I'm not sure exactly how much they cost
    Cheers
    The Netherlands
    Just received the M22 and so far I love it -pocket-clip is way to tight to use it but I don't care (won't use it anyway )
    And don't know if it's standard but mine came with the black and stainless bezel
    edit; Thing that I don't like is, that the ring isn't threaded. Because it isn't the ring can slightly move- it moves even more when you don't use the pocket-clip.
    Jul 2010
    USA
    Sorry for the late response kj2, I've been a bit busy
    I'm glad to hear you got both bezels
    Although the clip isn't threaded, mine has no play at all. I can't even get it to budge when the tail cap is screwed on. Perhaps yours may be a bit different?
    Cheers
    Jul 2010
    USA
    Never mind, I thought you meant the clip In that case, you're right. I wish the ring was also threaded. Maybe Olight will offer a solution soon
    I'm working on the rest of the review, Italian and Spanish versions coming soon
    Cheers
    Flashaholic* xevious's Avatar
    Dec 2007
    Hudson County, NJ
    Terrific review, Alain. Very thorough!
    I'm tending to like the new design. It has a kind of retro look about it, especially the head. Aesthetically, I wish they used a different texture pattern on the body and tail cap. The shallow but tight knurling of Surefire lights seems to grip better, especially with gloves on.
    These lights are seriously tough. I spotted a Russian demonstration of an M20 being crushed by a steam roller (link). The glass shattered and the head was partially flattened, but it still functioned.
    Lights in my rotation: Zebralight SC52w | Olight S1/S15/i3E-CU/S35 | Nitecore EA4 | Surefire U2 | Sunwayman V11R | NovaTac 120P| Febux L0D
