Imalent
Page 1 of 7 1234567 LastLast
Results 1 to 30 of 194
Thread: Eagletac G25C2-II (XM-L2, 1x18650 2xCR123A/RCR) Review: RUNTIMES, VIDEO, BEAMSHOTS+
    Wink2 Eagletac G25C2-II (XM-L2, 1x18650 2xCR123A/RCR) Review: RUNTIMES, VIDEO, BEAMSHOTS+
    Warning: pic heavy, as usual.
    Last summer, I reviewed the initial launch of the G25C2 - a new, top-of-the-line, 1x18650, 2xCR123A/RCR flashlight from Eagletac. Eagletac has recently sent me a new sample of the Mark II build, with the XM-L2 U2 Cool White emitter. Let's see how it compares to my original XM-L G25C2 T5/T6 Neutral, and the more recent competition.
    Note that the external styling and appearance of the light is not that different from the original version, aside from the new Mark II label (see below). As I result, I will re-use some of the photos from my earlier G25C2 review, updating where anything has changed.
    • LED: Cree XM-L2 (Cool White U2 or Neutral White T6 available)
    • ANSI FL-1 Lumens for Cree XM-L2 U2 Cool White: Regular mode: 980/449/86/7 lumens, Tactical mode: 980/141 lumens
    • Note: U2 LED is approximately 7% brighter than the T6
    • Runtime: Regular mode: 1/1.9/11/100+ hours, Tactical mode: 1/7 hours
    • Note: Runtime measurement is taken with energy saving feature (on by default) and with two CR123A. G25C2 reduces output by 20% after 200 seconds at turbo mode. User can disable or enable this energy saving feature.
    • Powered by 2xCR123A, 2xRCR123A, or 1x18650 li-ion.
    • With 3 cell body extender: 3xCR123A, or 3xRCR123A li-ion
    • With 4 cell body extender: 4xCR123A, or 2x18650 li-ion4
    • With 3x18650 extender: 3x18650 li-ion
    • Voltage range: 2.7V - 12.6V
    • Beam Intensity (U2 version): 21,800 lux
    • Beam Distance (U2 version): 323 yards / 295 meters
    • Two groups of basic output modes, Tactical (100% / 10% / Strobe / Strobe) and Regular (100% / 35% / 6% / 0.6%) – user selectable
    • Brightness level selected by loosening/tightening head/bezel
    • Four levels brightness (user selectable sets) and seven hidden auxillary modes - Strobe/Strobe(Var)/Flash(Hi)/S.O.S.(Fast)/S.O.S./Becaon/Flash(Lo)
    • Titanium coated stainless steel bezel (removable)
    • Waterwhite glass lens w/ harden treatment
    • Anti-reflective (AR) coating on both sides (96% transparency)
    • HAIII hard anodization aerospace aluminum (black)
    • Titanium coated Stainless steel pocket clip
    • Smooth aluminum reflector
    • IPX-8 waterproof
    • Heavy Duty Nylon Holster w/ self-retention device and flip
    • Mil-Spec Paracord Lanyard w/ quick attachment clip
    • Included Accessories: Spare O-rings, GITD (Glow in the dark) switch boot , User manual, Tail-stand rubber boot, Soft cigar holding grip, Cigar grip cover ring, Lanyard ring attachment ring
    • Optional kit: Durable aluminum flip-over filter assembly, Diffuser, yellow, red, blue, and green optical grade anti-reflective coated add-on lens, 3 cells extension body tube for three CR123A/RCR123A, 4 cells extension body tube for four CR123A or two 18650 li-ion
    • Dimensions: Head Diameter 1.55 inches (39.5 mm), Body Diameter 1.0 inches (25 mm), Length: 5.9 inches (150 mm), Weight excluding battery: 4.8 ounces (138 grams)
    • MSRP: ~$110 (~$150 with accessory kit)
    Inside the standard Eagletac box, you get the light with a soft rubber grip ring and metal pocket clip installed. Included inside the box is a rubber tailstanding cap, belt holster with metal button clasp, wrist lanyard, extra o-rings, GITD switch boot cover, cigar grip cover ring, lanyard attachment ring, manual, and warranty card.
    My review sample came with the full accessory kit. This provides an the aluminum flip-top screw-on bezel with diffuser, yellow, red, blue, and green filter lenses, 3 cell extension body tube, and 4 cell extension body tube with anti-rattle insert.
    From left to right: AW Protected 18650; Eagletac G25C2, T20C2-II; Foursevens X7; Klarus XT-11; Thrunite TN11; Lumintop TD-15X.
    From left to right: AW Protected 18650; Eagletac G25C2 Mark II; Nitecore P25; Rofis TR31C; Nitecore MH25; Crelant 7G6CS.
    Eagletac G25C2-II (with diffuser/tailstand cap): Weight 157.0g, Length: 181mm, Width (widest, at bezel diffuser hinge): 46.2mm
    Eagletac G25C2 (stock): Weight 144.3g, Length: 150.6mm, Width (bezel): 39.6mm
    Eagletac D25LC2: Weight: 50.0g, Length: 116.3mm, Width (bezel): 22.5mm
    Foursevens Quark Q123-2 X (Regular tailcap): Weight: 44.6g, Length: 112.7mm, Width (bezel) 22.0mm
    Rofis TR31C: Weight: 180.7g, Length: 153.0mm, Width (bezel): 39.8mm
    Thrunite TN10: Weight: 154.7g, Length: 145.5mm, Width (bezel): 35.1mm
    Zebralight SC600: Weight 87.2g, Length: 107.8mm, Width (bezel) 29.7mm
    Overall weight has dropped slightly on the G25C2-II compared to my original G25C2 sample, but overall dimensions are otherwise unchanged.
    Common build:
    Original G25C2:
    New G25C2-II:
    Physically, the G25C2 Mark II build is not that different from the original G25C2. Anodizing remains a glossy black (HA = type III). All labels are bright and clear (sharp against the black background). There is a new label on the base of the head with "Mark II".
    As before, knurling is present in several bands over body/tail/head, and is of reasonable aggressiveness. I would say grip has definitely increased from the earlier model Eagletac T-series lights.
    Screw threading remains the same traditional-cut (and fairly fine) in the tail region. One minor point is the gold-colored contact cover for the spring in the tailcap. But the major difference on the Mark II version is that the tail threads are no longer anodized for lock-out. This is an unfortunate change, and one that I suspect is due to enforcement of a patent restriction from another maker.
    Screw threads in the head region remain square-cut (and thick). One difference on the Mark II body tube is that the head region is now traditional aluminum color (instead of brass on the original G25C2). I am not sure of the reason for the change. Please see the pics above and UI discussion below for more details on the contact surfaces. Note that you will need to use cells that have at least some sort of raised protrusion on the positive contact surface (i.e., a small or large button top).
    The bundled cigar grip ring is made of rubber, with an extra thin rubber band cover included (in case you want to remove the ring but keep the area covered).
    The titanium-coated stainless steel pocket clip is held in place by a metal screw cover. The clip is removable, and the cover hides the attachment point.
    With the tailstanding rubber cover installed, the light can tailstand. Switch is a forward clicky switch with traditional feel as before.
    There is also a two-piece plastic lanyard attachment ring bundled with the light (for use at the tailcap instead of the tailstanding cover).
    G25C2-II
    Reflector is basically smooth. It is not quite as shiny as some others I've seen, but I would still consider it as smooth. Note the XM-L2 emitter (which is well centered). You can distinguish the XM-L2 (shown above) from the original XM-L by the lack of bond wires over the die surface now, and the use of a silver mask (instead of green) outside the die/dome area.
    One of the key features of the optional accessory kit is the replacement bezel with flip-top diffuser/filter cover.
    The stock head has a scalloped titanium-coated stainless steel bezel ring, replaceable with the screw-on diffuser/filter assembly.
    The flip-top diffuser is very high quality, made of aluminum. Hinge mechanism is good (although stiff on my sample), and the whole unit has a solid feel. There is a metal retaining ring holding the glass lens in place (swappable between the frosted diffuser shown above and four colored filters).
    Eagletac is using high-quality optical glass filters. This is true for all the filters, including the red one (which often tends to be just a colored piece of glass on many Eagletac filters).
    In case you are wondering, here is how the head compares to the earlier Eagletac T20C2-II, with and without diffuser covers (plastic screw on diffuser for the T20C2-II):
    User interface is largely unchanged from the earlier version of the G25C2. As before, turn the light on/off by the tailcap forward clicky switch (press for momentary, click for locked-on).
    There are four output levels controlled by simply loosening or tightening the head (i.e., the four levels are accessed in sequence from head fully tight). There are two possible groups of output modes available - Tactical (100% > 10% > Strobe > Strobe, in sequence) and Regular (100% > 35% > 6% > 0.6%, in sequence). You can switch between the two groups by loosening the head to the second level and rapidly clicking the switch off/on 20 times rapidly in a row.
    In terms of the head twist, as soon as you loosen past fully tight you drop down to the second level. From there, you drop down again to the third level after a ~90 degree angle turn, and similarly again for the fourth level after another ~90 degrees. This means that after ~190 degree turn from tight, the light is in the lowest mode. It remains in this mode until you complete almost a full turn from fully tight (at which point the light shuts off).
    It is important that you keep all the contact surfaces in the head and the top of the battery tube clean. Eagletac recommends regular use of red Deoxit contact cleaner, and limiting silicone lube to the o-rings only (i.e., not to the threads). I can confirm that mode switching can become erratic if the threads dirty-up (especially for moving in/out of the highest levels, and accessing the auxiliary modes).
    To access the hidden auxiliary modes, do a quick loosen-tighten twist of the head (from first level tight to third level and back again). Repeat this twist to advance through the modes. Mode sequence is: Strobe I > Strobe II > Hi-Flash > SOS I > SOS II > Beacon > Lo-Flash, in repeating sequence. Note that this is updated slightly from the original G25C2, with two additional blinking modes now. Turn off the light or loosen the head to quit the hidden modes. I will describe these modes in more detail below.
    There is an "energy saving feature" (on by default) when the light reduces output by ~25% after 200 seconds in Turbo (was ~20% on the original G25C2). To toggle this feature off/on, loosen the head to the fourth level and the click the light off/on 20 times rapidly at the switch. When off, you will get a smaller ~10% drop in output after 200 secs.
    There is also a momentary tailcap strobe setting (off by default). To toggle this feature, tighten the head fully and click the light off/on 20 times rapidly at the switch.
    Video:
    PWM/Strobe
    There is no sign of PWM that I can see, at any output level – I presume the lights are current-controlled.
    Strobe I mode:
    The main strobe is a fairly typical fast "tactical" strobe, of 9.8 Hz frequency.
    Strobe II:
    The second strobe mode is an alternating or "oscillating" strobe, switching between 6.5Hz and 15.1Hz every 2 seconds.
    Hi-Flash:
    Hi-Flash is basically a full power slow strobe/beacon mode. Frequency was a reasonable ~1.6Hz. Note that the deflection spikes you see above are just the on and off signals of the pulse (i.e., it spends roughly half the time on, half the time off, with each pulse).
    SOS I:
    The "fast" SOS signals the full SOS sequence (dot-dot-dot, dash-dash-dash, dot-dot-dot) in just under 3 secs. Note again that the traces above refer to both the on- and off-signal for each pulse of light.
    SOS II:
    In contrast, the "slow" SOS takes just under 3 seconds just do the "S" (i.e. dot-dot-dot), and about 4 second to do the "O" (i.e., dash-dash-dash), with a good 3 seconds in-between each Morse code letter. Personally, this seems far more useful than the rather frenetic initial SOS mode.
    Beacon:
    Beacon is a slow full output flash (almost 2 secs long), re-occurring approximately every ~14 secs (i.e., a very slow beacon)
    Lo-Flash:
    Lo-Flash is a lower output, slower frequency strobe/beacon than Hi-Flash. I detected 10 flashes in a ~20 sec period (i.e. about 0.5 Hz).
    For white-wall beamshots below, all lights are on Max output on an AW protected 18650 battery. Lights are about ~0.75 meter from a white wall (with the camera ~1.25 meters back from the wall). Automatic white balance on the camera, to minimize tint differences (i.e., my G25C2 Neutral White won't look any different from the others, but it is a lot warmer in real life).
    Note that the flip-top diffuser cover assembly was installed for the original G25C2 shots, with the diffuser up (although this still narrows the spillbeam slightly, due to the extended collar).
    The XM-L2 U2-equipped G25C2-II has more output than the original G25C2 (XM-L T5/T6 version), and is overall very similar to the new Olight M22 (XM-L2). Note that use of the screw-on flip-top diffuser on my original G25C2 above narrows the spillbeam somewhat – with equivalent bezels, they really have comparable spillbeam width.
    In case you are curious as to how the diffuser changes the beam, here are some beamshots of the original G25C2 (NW XM-L T6) with the diffuser in place:
    As useful as the above shots are, I know people like to have a better idea of the beam angle with the diffuser. So for that, I have turned to my famed "integrating carpet."
    The G25C2-II (with XM-L2 U2) is a definite output upgrade from my G25C2 (with XM-L T5/T6). This is due to more than just an emitter output bin upgrade – it would appear that Eagletac is driving these Mark II series lights higher than my original G25C2. I will discuss output bins in more detail below, but also check out my runtime results for more info.
    It is interesting to compare these results to my recent TX25L2 (XM-L2 T6 NW) sample. Based on output bins alone, you would expect the XM-L2 U2-bin Cool White version here should be ~7% brighter on average than the TX25L2's XM-L2 T6 – if they were driven the same. Since my G25C2-II is marginally dimmer than my TX25L2, this leads me to suspect that the TX25L2 is driven even harder than my G25C2-II. I will discuss this further after we inspect the runtimes.
    In any case, the ~870 estimated lumens of my G25C2-II still puts this light at the top end of the 1x18650 class. Along with the TX25L2, it's remarkable to think this much light can be generated from a single 18650 cell.
    In terms of center beam throw, my G25C2-II sample is consistent with the manufacturer's specs.
    At the lowest level, output has increased on my G25C2-II compared to my original sample (i.e., now basically 9 estimated lumens, up from 2 originally).
    Let's see how the new G25C2-II sample compares to the currently reported Eagletac specs for this light:
    As you can see, my testing results are again generally very consistent with Eagletac's own specs. The one exception is perhaps the highest level, where my output measures seem to slightly under-report.
    It bears repeating again that my estimated lumen scale is just that - an estimate, based on a consistent calibration of my lightbox. I suspect that the calibration slightly underestimates lights in the high-hundreds lumen range, but I have little data to compare in this range. In any case, even though the absolute value correlation is unknown, the relative comparisons still hold. All I can really say is that one light is higher or lower than another, by a certain relative percentage (e.g., my TX25L2 is slightly brighter than my G25C2-II, despite what the output bins are supposed to be). So please don't get hung up on the absolute values of the estimates, or on small relative percent changes.
    XM-L2 vs XM-L
    While on the subject of output bins, I realize all this emitter talk may seem confusing, especially for those that don't keep up on the fine details of LEDs.
    Basically, these new XM-L2 emitters are very similar to the old XM-L, but are reported by Cree to deliver "up to" 20% more lumens and lumens-per-Watt than the classic XM-L of comparable output bin number (see Cree XM-L2 spec sheet here). However, directly comparing back to XM-L is complicated by the more stringent testing and reporting measures Cree is now using for XM-L2 output binning. If you are curious, XM-L emitters were previously output bin rated by luminous flux @350mA, @25 degree C. With the XM-L2, Cree has switched to a more representational (but more stringent) @85 degree C for binning purposes.
    There is actually an easy conversion though - if you look up the Cree spec tables under the same conditions, you will see that the new XM-L2 bins are exactly two bin steps brighter than the same bin number on XM-L. So a XM-L2 U2 is basically the same thing what a XM-L U4 would be (if such a beast had ever existed). This is part of the reason for the switch to the new process - there is now more "headroom" on the new XM-L2 platform, and higher output XM-L2 emitters can ultimately be produced.
    In terms of lumens though, you have to keep in mind how the binning process works. Given the ~7% range within each bin, this means that for any given specific XM-L2 sample could be anywhere from ~7-20% brighter than a comparably bin-numbered XM-L sample. This is presumably where that "up to" 20% brighter statement comes from in the Cree literature. But you need to keep in mind that on average, a XM-L2 U2 should be ~13% brighter than a XM-L U2, for example. You really have to think of these things statistically – the bins are a range, and you don't know where exactly in the range any given sample will fall.
    Output/Runtime Graphs:
    There's a lot there to summarize, but a few points seem clear to me.
    First, my G25C2-II (XM-L2 U2) is driven harder on Turbo than my original G25C2 (XM-L T5/T6), given the runtime differences. The three-four output bin steps between the emitters on these samples do not explain the ~50-60% increase in overall output on Turbo.
    Secondly, my TX25L2 (XM-L2 T6) is driven slightly harder than my G25C2-II (XM-L2 U2) on Turbo. This is interesting, given that my G25C2-II is supposedly an output bin step up from my TX25L2.
    And third, the overall efficiency of my TX25L2 and G25C2-II seem virtually identical (even though my G25C2-II is supposed to be one output bin step up). Such is the nature of output binning – any two samples separated by one bin could be anywhere from ~1-13% different. And given the variation in circuits, reflectors, lightbox placement, etc., expect a few more percentage point in either direction. In this case, my G25C2-II XM-L2 U2 seems to be performing equivalent to my XM-L2 T6-equipped TX25L2 (and XM-L2 T6-equipped Olight M22 for that matter).
    But all this to say that output/runtime performance remains excellent on my Eagletac lights.
    As before, on Turbo, the default setting is for the light to step down after 200 secs – which allows it to enter a period of flat-regulation, before eventually dropping off in a typical direct-drive like pattern. Note consistent with the higher initial Turbo output, my G25C2-II seems to step down proportionally further than my original G25C2 did (i.e., a ~25% step-down now, instead of ~20% previously). With this feature turned off, there is a smaller ~10% drop, and the light remains largely in direct-drive most of the time.
    On all other levels, the light maintains perfectly flat regulation for an extended period, before dropping off slowly in output (on 1x18650 or 2xCR123A) or with an abrupt shut-down due to protection circuits being triggered (2xRCR). Note that like my TX25L2, the main LED begins to flash once the batteries are nearly exhausted (on 1x18650 or 2xCR123A). The flashing is at a slow rate, about once every 30 secs.
    As with my other recent Eagletac lights, ANSI FL-1 runtime specs are pretty consistent with my results. Recall that I use lower capacity 2200mAh 18650 cells, and that the FL-1 standard calls for time to 10% output (not 50%, as reported in the graphs above).
    Flat-top cells will not work in the light, due to the physical switching mechanism in the head. I recommend you stick with button-top cells (small and large button top both worked fine in my testing).
    You need to keep all contact surfaces in the head clean, or you may experience mode switching problems (especially between first and second levels, also required for auxiliary modes). The limited range between first/second modes makes switching very susceptible to any contact surface issues. Not an issue for regular use, but heavy mode switching may require periodic cleaning.
    The light is bit longer than most 1x18650 lights, especially with the flip-top diffuser installed.
    Tailcap threads are no longer anodized on Mark II version of the G25C2, so lockout is no longer possible.
    The G25C2 series is one of main tactical lines produced by Eagletac. Since my original review of the G25C2 last summer, the light has undergone a few (relatively) minor build and user interface updates – now known as the Mark II version. More recently, Eagletac has updated the line with the new crop of XM-L2 emitters.
    As before, there is a lot to like about this series. Output modes are available in sequence by a simple loosening of the head (with the user-configurable choice between a Regular or Tactical mode set). This is a very intuitive interface, and works well in practice. The "hidden" blinky modes are all still there if you want them, and Eagletac has provided a few more options on the revised Mark II. In general, the interface is more configurable than most lights, with the ability to turn on/off features like the automatic step-down from Turbo, or access to Strobe from off, etc.
    The only potential drawback to this new Mark II build is the lack of tailcap screw thread anodizing now. I suspect this is due to patent issues with another maker, but have no direct knowledge of the matter.
    Performance-wise, output/runtime efficiency remains top-notch, as you would expect for a current-controlled light. The new XM-L2 emitters typically add at least two output bin levels of higher output – for both Cool White and Neutral White (see my discussion of the bins earlier in this review). It also appears that my Mark II sample is driven harder on max than my original G25C2, which will appeal to many here, I am sure. Note that overall performance of my XM-L2 U2-equipped G25C2-II seems remarkably similar to the XM-L2 T6-equipped TX25L2.
    Physically, I like the G25C2 design – while larger than some lights in this class, it offers greater throw and output in stock form. Knurling is good, and the range of bundled carry options is appreciated. Even the rubber tailstanding attachment is a nice feature, expanding your range of use options.
    One of the best features for me remains the excellent aluminum flip-down diffuser/filter assembly. I personally use diffused lights a lot, especially for walking the dog at night. With a traditional beam, I tend to find myself distracted and tracking the hotspot (i.e., the "follow-the-bouncing-ball" effect). With a good diffuser, I can pay proper attention to what my dog is doing, and what is in the local environment. But when you hear a sudden sound off in the distance, a screwed-on style diffuser cover is a handicap to seeing what is going on. So while I may like a good diffuser, I also like having the option of decent throw at a flick of the finger – as this diffuser cover allows.
    For me, the G25C2-II remains as one of the top lights in this category. If you prefer a more compact build (while maintaining generally comparable max output and throw), you might want to consider the electronic switch-based TX25L2. Personally though, I find the wider output levels on the G25C2-II more useful, and you can't beat the flip-top diffuser.
    G25C2 Mark II was provided by Eagletac for review.
    *Flashaholic* kj2's Avatar
    The Netherlands
    Default Re: Eagletac G25C2-II (XM-L2, 1x18650 2xCR123A/RCR) Review: RUNTIMES, VIDEO, BEAMSHO
    Thanks for the great review
    Am wondering too, why the anodizing at the tail is gone
    Mostly reading.
    Great review as always, thanks for your work!!
    I am wondering if this means that all flashlight manufacturers (except the patent owner) that use anodized screw threads for tailcap lockout are committing patent infringement. Before I read this review I would never have thought it was possible to get a patent on something that seems so straightforward and easy to wrap your brain around. Obvious solutions are not so obvious until someone has come up with them though.
    This is probably not the place to discuss patents and lockout features, but for those interested, this might be a good thread to revive.
    http://www.candlepowerforums.com/vb/...refire-tailcap
    Thank you for the review, by the way. A little more challenging than usual - especially at 3:30 AM - but as always a good read.
    Flashaholic holylight's Avatar
    Feb 2013
    Germany
    Default Eagletac G25C2-II (XM-L2, 1x18650 2xCR123A/RCR) Review: RUNTIMES, VIDEO, BEAMS
    Very versatile and efficient good flashlight. Thanks for the wonderful review.
    lights: saber1a, v11r, sc52, sc600ii, ea4, tn31, archer1a.
    Thanks everyone, glad you are enjoying the review.
    Yes, there have been a number of threads about this over the years, including most recently this one on CPFMP.
    Again, I have no knowledge of the issue in this case, and I would ask people to keep any such discussion/speculation to the appropriate threads (and not here).
    Yes, it was a rather long one, wasn't it?
    Once the XM-L2 become common place, these will probably go a bit faster ....
    Unenlightened
    Jul 2012
    Ukraine
    Nice review!!! Thanks a lot!
    Looks pretty weird that G25C2 MKII beam intencity is even slower than TX25C2, but than I should save some money for a little brother of my MKII (TX2C2).
    another great review, Thanks
    Mar 2013
    New Jersey
    I've been considering this light for a short time now. I think the flip cover really puts it over the top. But I am concerned about the twist control. How easy is it for the head to twist accidentally? For example if it was in a pocket or backpack? And I would think the flip cover hinge would only make this more likely that most other EagleTac lights.
    And speaking of the flip cover, how secure is the latch? I assume it may also be difficult to unlatch with gloves.
    Mike
    Jul 2012
    I think this light is the best one in its catagory; the flip diffuser makes it my personal choice.
    Quote Originally Posted by LuxClark View Post
    The head twist is reasonably stiff, I don't think you'll have a problem. In any case, you can always verify the position before activation if you are concerned it may have shifted.
    Most definitely would be hard to use the hatch with gloves. Personally, I never use the latch - the tension in the hinges of my samples have always been great enough to hold the diffuser flap firmly in place on its own.
    Jul 2012
    I agree with selfbuilt I do not use lock feature and I have not yet found a condition where the latch needed to be locked.
    Since you've reviewed both the G25C2 and Olight M22 XM-L2 lights, is the G25C2's head harder to turn, easier, or about the same? Still considering this light and I've found that I can turn the M22's head one-handed (thumb and forefinger on the body, pinky holding the head). If the stiffness of the head turn is similar, I might get the G25C2 to check it out for myself.
    Max
    Quote Originally Posted by bluemax_1 View Post
    Wow, you've got stronger pinkies than me!
    But in answer to your question, my G25C2-II has less resistance in the head than my M22. And since you don't need to do a loosen-tighten twist on the G25C2-II, you should find it comparatively easier to switch modes on the G25C2 single-handed.
    Default Eagletac G25C2-II (XM-L2, 1x18650 2xCR123A/RCR) Review: RUNTIMES, VIDEO, BEA...
    One thing you've mentioned in both this and the original review is the thread sensitivity, and having to keep it cleaned and greased just right. For general home use (i.e. not getting it dirty), do you have to clean it frequently? Or is it good to go once you get it right?
    Mine had bad flickering problems until I cleaned the threads. That's fine for what I use this one for, but I now want a dedicated light to keep upstairs, and need it to be low maintenance but reliable. Although I prefer the G25C2 UI, the thread sensitivity may be enough to push me towards an M22 versus getting a second EagleTac. I only fixed the flickering problem this week, so it's too soon for me to tell with mine.
    Default Re: Eagletac G25C2-II (XM-L2, 1x18650 2xCR123A/RCR) Review: RUNTIMES, VIDEO, BEA...
    Quote Originally Posted by benhar View Post
    That's a really good point that I should clarify.
    My comment stems from my testing, where I go through a LOT of battery changes and head twisting (i.e., working through the modes repeatedly, etc.). This is a pretty heavy-duty workout with all the tests and runtimes I perform, and I found intermittent contact issues could creep in over time. These were all immediately resolved by a thread and contact surface cleaning in the head.
    For regular use, it is not a problem. I've kept my original G25C2 by my back door for over six months, for taking the dog out at night. This light gets used at least once or twice a day, and has gone through a couple of battery changes. And in all that time, I have not had to clearn the threads again. So it is very stable light for light usage over time.
    Jul 2012
    I would agree too with selfbuilt.
    I use the G25C2 mainly with the head tight and keep my Eagletac D25LC2 for low, medium and high settings; with both lights I have not had a problem.
    I do when I change batteries I clean all threads with Deoxit.
    Perfect, thanks! I may have to be boring and buy the same light twice (well, the MkII version).
    Sweet, thanks!
    *Sigh* I was looking for A new 1x18650 light, and now this will be the 4th LOL.
    Max
    Thanks for the awesome review selfbuilt! It was your review that pushed me to buy the G25C2. That flip top diffuser was the icing on the cake...along with the battery extender.
    Eagletac G25C2 MKII | Fenix TK22 | Olight i3S
    Flashaholic* Chevy-SS's Avatar
    Feb 2010
    Rhode Island
    God dang nabbit - that is a terrific review! I hope you're getting compensated for these fine editorial pieces. Please keep up the great work. These reviews are much appreciated by everyone that reads them, I'm sure.
    Quick question on the strobe - can the light be programmed so that the maximum strobe comes on at the initial button press??
    Thanks, Dave F.
    "Be careful, even in small matters" - Miyamoto Musashi
    Quote Originally Posted by Chevy-SS View Post
    Just by the appreciation of those who read them.
    Yes, but you need to do a double-press of the tailcap to activate strobe (if you have this feature turned on).
    EDIT: the above is referring to the tactical tailcap strobe feature. You can have the light come on in strobe all the time with a single button press - just have the mode set in the tactical group (100% > 10% > Strobe I > Strobe II), and leave the head in the third or fourth position, for whichever strobe you want.
    Feb 2010
    Rhode Island
    Yep, much appreciation from the crowd here, that's for sure!!!!
    Too bad about the strobe requiring a double-press. That kills it as a 'defensive strobe'. I'm VERY surprised they don't have some method of setting it up so that strobe comes on with first touch of button.
    O well, thanks again for the very fine work!
    Sorry, I thought you were just asking about the tactical tailcap strobe feature. There is indeed a way to have it come on in strobe all the time with a single button press - just have the mode set in the tactical group (100% > 10% > Strobe I > Strobe II), and leave the head in the third or fourth position, for whichever strobe you want.
    Jul 2012
    I have my G25C2 set up for a rapid double press and click will put the light in strobe.
    I do not use strobe, but if I ever want it this is the easiest and fastest light to enter a strobe mode.
    Feb 2010
    Rhode Island
    Ahhh, thank you very much! I apologize as I must have asked a confusing question (it's a bad habit I have, LOL).....
    Thanks again, you're a real credit to this forum.
    Unenlightened
    Apr 2013
    Norway
    Hope they make velcro holsters :-)
    Thanks for the excellent review!
    Quick question, is the double-click strobe going to be Strobe I or Strobe II? That is, is it the alternating "disorienting" one or the regular?
    Jul 2012
    Quote Originally Posted by res1cue View Post
    It is set for only the 'regular' strobe for the double click option.
    Quote Originally Posted by sidecross View Post
    Gotcha. Thanks
    Seems silly to have a quick access feature and not have it on the "disorienting" strobe
