Wuben
Results 1 to 6 of 6
Thread: First Charging = Eneloop XX
    Post First Charging = Eneloop XX
    I'm New to Candlepower and i wanted to Ask when Charging new Eneloop XX's in the MaHa C9000 what is best method for the first charge is it best to just charge them or Use Break-End for the First initial charge.. Thanks B-52
    Silver Moderator
    SilverFox's Avatar
    Jan 2003
    Bellingham WA
    Default Re: First Charging = Eneloop XX
    Hello B-52,
    Welcome to CPF.
    Most of us just charge them and use them. The Break In may provide a marginal increase in capacity, but the time it takes to do the Break In doesn't seem to justify the small amount of capacity gained. At any rate the capacity seems to fall into place after a few charge/discharge cycles.
    The default charge rate of 1000 mA is good for the Eneloop cells.
    Tom
    Behind every Great man there's always a woman rolling her eyes...
    Most batteries don't die - they are tortured to near death, then murdered...
    Flashaholic* PapaLumen's Avatar
    Apr 2010
    UK
    Some just use them. Some charge them and use them. Some run the break-in cycle. Some (me) discharge them first, then run the break-in.
    Hey Thanks Guys.. And while i was on here and doing some looking around getting my feet wet! I found the Thread on Panasonic removing the Eneloop Name). I guess it's Ok if the Batteries remain the Same Quality but i wasn't expecting a Name change this Soon as so Many are A custom to the eneloop name an Quality of the battery..
    Apr 2010
    UK
    Quality will remain. Shame to lose the name and design though.
    Flashaholic Frijid's Avatar
    Feb 2013
    USA
    When i buy new batteries, if they are already pre-charged, i verify they still have charge in them. if they do and it's a good charge, then i just use them. if they are not LSD, then i charge first. that's all. the only thing i do that would be considered "break in" is by just using them like i normally would.
    like i bought some 2300 mAh energizers for a spotlight. they had charge still in them cause they were precharged. i just stuck them into the light and used it. when they got run down, i just charged them, then put em back into the light. then when they went down again, just charged and put back in. i've never done any of the fancy break in things. i've got some cheap ol 2000 mAh eveready's from 2008 that i bought and have just used em, with nothing fancy, and they are still running good. matter of fact, i have them running right now in a handheld police scanner. but since they are not LSD batteries, when i first got them, i charged em first. when i got my new set of eneloops about a month ago, i just stuck them into the device and used em.
    ~Pray for the best, but prepare for the worst~
