RMSK, Inc.
Results 1 to 11 of 11
Thread: Regulare Alkaline mAh?
    Default Regulare Alkaline mAh?
    So I just got a my first FourSevens flashlight, QPA Gen2.
    Been reading up on 14500 and other rechargeable NiMh AA batteries. I see the rechargeable batteries have different mAh, but what are the mAh rating on say regular AA alkaline battery? How about the mAh rating on a energizer lithium L91?
    Also are all the AA NiMh rechargeable batteries less then 1.5 volts?
    Will I notice much of any difference in brightness running a NiMh rechargeable battery over a regular 1.5 volt alkaline?
    Thanks
    Flashaholic* AnAppleSnail's Avatar
    Aug 2009
    South Hill, VA
    Default Re: Regulare Alkaline mAh?
    Alkaleaks are junk. On the modes above moonlight, the AAs have 1000 (low) to 500 (high) mAh. Turbo mode won't work well, and alkaleaks leak. I suggest Eneloop AAs. They work very well in the Quark.
    My biggest light-hog is my camera.
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by appliancejunk View Post
    Both alkaline and lithium has about 3000mAh, but for alkaline the mAh will be reduced with load, i.e. with a 1A load it will be below 1000mAh
    The 14500 size specification is usual only used for LiIon batteries, not for NiMH.
    Yes, but their actual voltage under load is higher than alkaline in many cases.
    There exist NiZn rechargeable AA batteries with 1.6 volt, but they have a couple of problems and are not mainstream.
    Most of the time the NiMH will be brightest.
    My website with battery, charger, usb reviews, comparisons & information: https://lygte-info.dk/
    Latest addition is multimeter reviews
    Thanks for all the info...
    Good to hear!
    Been doing some more reading and it seems that some white top Deracell Staycharged batteries 1500 "made in Japan" maybe the same or similar to the Eneloop batteries?
    May see what I can find locally for the Deracell's then order some Eneloop's if I can't find anything local.
    Thanks.
    I have some generic alkalines AA's with an actual mah label of 2600 mah. I would assume most alkaline AA's are around the same amount.
    Flashaholic* uk_caver's Avatar
    Feb 2007
    Central UK
    I think regular Duracell/Procell AAs are ~2700-2800mAh, but as HKJ said, that's at low current draws, and at high current draws, the effective capacity of alkalines drops significantly.
    As a rather rough (but fairly easy-to-remember) approximation, with decent quality alkaline AAs pulling half an Amp, they'll act as if they had about 2/3 of the nominal capacity before showing exhaustion, and at a 1 Amp draw, they'll exhibit about 1/3 of the nominal capacity.
    If you have a Costco locally, they usually carry some Eneloop packs.
    Jim
    I don't have nothing locally, lol...
    Thanks,
    *Flashaholic*
    Jan 2012
    NJ
    Thanks,
    OK, Good, since you have local places to buy them you can get them there...
    Online ordering it is then.
    Oct 2012
    Norcal
    Quote Originally Posted by TEEJ View Post
    If you hate mail ordering as much as I do (and online ordering is just mail ordering by a different name), you have another option. And that's Duraloops. While Eneloops as such are not widely available in stores, you can get the exact same battery rebadged as a Duracell at many grocery and drugstores. Just look for rechargeabke Duracells with white tops that are made in Japan, and you're good to go. No waiting or shipping charges necessary. The best part? For whatever reason, they often seem to be on sale.
    Flashaholic Frijid's Avatar
    Feb 2013
    USA
    Quote Originally Posted by StorminMatt View Post
    I've found them around here in two stores CVS and RiteAid
    ~Pray for the best, but prepare for the worst~
