Malkoff
Results 1 to 21 of 21
Thread: Defiant ArmorMax 3D Review
    Sep 2009
    Fresno, CA
    Default Defiant ArmorMax 3D Review
    Okay, this is my first actual review ever done so please bear with me and my amateur skills. There will be no lumens or Lux readings and definitely no driver information. I do not have the tools or equipment to measure them.
    Just a few days ago, I read up about a light from Home Depot claiming to be a huge thrower for a small price. It was the Defiant 3C thrower. To my disbelief, I checked their website and saw the light myself. I looked at the photos and saw that they look similar to today's 1x18650 reflector throwers. Based on the price, I knew that the lens and reflector is plastic but for this low amount of lumens, it wouldn't melt.
    There were two lights at the store: 3D and 3C version. I picked the 3D version for two reasons. One, I wanted the XM-L emitter and the lumens it can pump out. The 3C held an XP-E/G? I'm not too sure since the package blocked me from being able to see the emitter clearly. Two, the bezel diameter is MUCH larger than the 3C by far and would make a much better thrower once an XP-G2 emitter is placed in.
    The light utilizes a similar driver you would see from many of the budget lights from China. High>Low>Strobe. The driver itself looks very similar. However, with the increase in voltage, the driver managed to put out 2.85a on high and 0.76a on low.
    Now lets let the photos speak for themselves...
    Here's the light removed and laid next to the actual packaging:
    The logo on the light:
    Bezel. Noticed the fins machined on this light?
    Here's one thing I'd like to mention about this light. As a amateur machinist, I noticed that the milling/lathe work and final finish before anodizing on the light is not smooth. As a result, you can see the machining marks clearly on the body of the light. For the price you pay for, the machine quality is better than what I'd expect.
    Here's the massive tail-cap. This thing is huge and majority of the unit is solid aluminum.
    Here's how big the light is when I am holding the it. Note that I weight 145lbs and am 5'7". Expect that I have a relatively smaller hand than the average male American.
    The threadings are standard 60-degree, V-shaped throughout the whole light. I noticed that the pitch is different throughout the light but do not have tools with me right now to say which pattern belongs to which part of the light.
    Here is the tailcap's threading:
    Here's the inside of the tailcap: I thought this is unique how the tail-cap unit is covered with this plastic housing rather than an exposed retaining ring just for the rim of the tail-cap. Upon inspection of the inside, I've noticed that the design is a retaining ring keeping the switch onto the tail-cap.
    Now onto the business end of the light. Looking at it, it's a standard cool white emitter--possibly a T6 emitter as they are commonly used in all B&M stores featuring an XM-L emitter:
    Here is a close up of the emitter itself:
    The beamshot on a white wall displays multiple rings outside of the hotspot. However, the hotspot itself is surprisingly round once past 10 yards of distance even with regards to the finished of the reflector:
    With the bezel removed is the entire pill of the light and is quite common with many manufacturer lights.
    For a $29.99 light, they did a very good job with machining the pill to seat the MPCB board. It is just slightly off from fitting snugly. I was surprised that a mass-produced light has this close of a fitment and is not a custom work.
    Here is the contact side of the pill. It all has a plastic housing to thread and keep everything compressed:
    With the plastic removed, there is something unique with this light that I have not seen in many production lights before: This is all the emptiness that you see in the pill. The rest of the pill (including the top 3/4) is a giant aluminum slug. This is how Defiant managed their heat. It is threaded onto the thick body. After running it for 15 minutes on high, I decided to stop because the pill did not get any warmer.
    Here are the three lights I will be testing and currently have in my inventory: Preon 0 with an XP-G2 5000k on a 10400 cell (donated from tobrien), Eagletac D25LC2 XM-L NW, and the Defiant ArmorMax 3D. My Surefire 6P with triple 219 is out of commission.
    Here's the business end of the 2 lights:
    Please forgive the phone quality pictures. This is actually better at capturing light in the dark than my digital camera. Now for a little outdoor shoot at 9PM PST. All lights were set at their maximum brightness:
    Control 1. The car is 40 yards away:
    47's Preon 0 with XP-G2 5000k:
    Eagletac D25LC2 XM-L NW:
    Defiant ArmorMax 3D:
    Control 2. The tree is roughly 150 yards:
    47's Preon 0 XP-G2 5000k: It did not do a good job reaching the tree but did light up the nearby surroundings.
    Eagletac D25LC2 XM-L NW: It did reach the tree but barely noticable in the photo and in person.
    Defiant ArmorMax 3D: The light managed to hit the tree with no problems. It could reach out further but do not have a long enough distance nearby to take photos without arousing suspisions with the neighbors.
    For a light at this price, I was surprised with its overall quality. The plastic lens and reflector will need a replacement for anyone that is interested in doing a modification to improve the throw and/or overall brightness of the light. I see that this light has the potential for increased throw with a light modification. If anyone plans on keeping it stock and running it on primaries, the plastic lens and reflector will suffice. Thank you for taking your time with putting up with my first time review
    Matt
    Sep 2009
    Fresno, CA
    Default Re: Defiant ArmorMax 3D Review
    ~Reserved for future modifications photos~
    Matt
    *Flashaholic*
    Jan 2012
    NJ
    Nice job!
    Could you post a few pics showing all three lights in the comparison next to each other?
    Flashaholic* bigchelis's Avatar
    Oct 2008
    Morgan Hill, CA
    Nice find. This light looks like it can be modified pretty easily and the 3D form/factor is one I prefer for my tool bag!
    Surefire 6P with Malkoff M60 simple, bright, efficient.
    Sep 2009
    Fresno, CA
    Quote Originally Posted by TEEJ View Post
    Nice job!
    I thought about standing them next to each other and taking a far away shot of them. The Defiant light is just too big to make them stand side-by-side. I will need to borrow a neighbor's 3D Maglite for this size comparison.
    Matt
    Sep 2009
    Fresno, CA
    Quote Originally Posted by bigchelis View Post
    That's what I thought too the moment I pull the pill out. I could not believe how heavy the slug is and thought about how much I could push this light with the replaced lens and reflector.
    Matt
    Flashaholic* Poppy's Avatar
    Dec 2012
    Northern New Jersey
    I'd be interested in seeing a comparison of the 3D maglight with the LED to this light. I don't know what emitter is in the mag, but it is definitely smaller than an XML
    Oct 2008
    Morgan Hill, CA
    Quote Originally Posted by Tiresius View Post
    I think this light most likely has just a XML, but with XM-L2 and 4A~5A of current it could really be impressive.
    Sep 2009
    Fresno, CA
    bigchelis, are the Tenergy D NiMH cells safe to use at 4A? I've read an older post about them being quite reliable for a NiMH cell. I'm hoping to get direct replacement cells without doing any mod to fit them.
    Matt
    *Flashaholic*
    Jan 2012
    NJ
    Well, also because those are the lights who's beams you used to compare it to. IE: It gives a sense of scale as to what this light was compared to, as all we really saw were the beams. Its nice to at least lay the three on a table and shoot them as a group, etc.
    Oct 2008
    Morgan Hill, CA
    Tenergy NiMH Cells are arguably the best in the industry at high current. Mine are over 2yrs old and still going strong. I have discharged them at well over 30A with no issues. I think even at 20A the cells will sag very little if any.
    Sep 2009
    Fresno, CA
    It's updated. All four lights stacked next to each other. Note that this guy is huge.
    Matt
    *Flashaholic*
    Jan 2012
    NJ
    LOL
    You're not kidding!
    Its like a Goliath vs 3 wee Davids!
    Sep 2009
    Fresno, CA
    LOL
    You're not kidding!
    Exactly This guy's quite massive and can be used as a bat if needed. If you thought the Maglite is tough, think again. If this guy drops on your toes without the rubber protection, you'd: http://www.youtube.com/watch?v=k5reDsSIiAk
    Matt
    Oct 2012
    Norcal
    4A is no problem with NiMH Tenergy D cells. I've run that with a 6D ROP light. And the cells don't even get warm! These cells are capable of MUCH more than that.
    Sep 2009
    Fresno, CA
    Quote Originally Posted by StorminMatt View Post
    Which cells should I use? The LSD ones or a certain color cell? There's the green, blue and white ones.
    Matt
    Oct 2012
    Norcal
    With Tenergy, you have the blue cells (older HSD), the blue and white Premium cells (HSD), and the green and white Centuras (LSD). I have not heard the greatest stories about the older blue cells. So I would avoid them in favor of the Premium or Centura batteries. Choose here according to your needs. If you tend to use your batteries within a short time (like a job, hike, or camping trip) and will fully charge your batteries beforehand AND want maximum runtime, go with he Premiums. But if you use your light intermittently and want something that's always ready to go, go with the Centuras. Centuras are also good for all-around use because even LSD D batteries have an insanely high capacity. And neither is any slouch when it comes to delivering amperage.
    Flashaholic* ronniepudding's Avatar
    Sep 2013
    NY Capital District
    I picked up this light over the weekend and tried it out in the woods with very little ambient light. I am very happy with how far it throws (with some usable spill), and the beam is pretty good for a Home Despot special. The build quality is very solid... the amount of aluminum you get is probably worth the price tag alone I appreciate the review, -- it was instrumental in my decision to buy this light, and I feel like I was well informed.
    Given the weight and the way the UI/modes are designed, it will live in my tool bag in the trunk of my car most of the time. Though the plastic lens feels cheap, it is probably better suited to this use-case than glass anyway. Likewise with the tailcap clicky... though it's not the most ergonomic placement for the switch in a light this big, it seems less likely to turn on accidentally (especially when the rubber boot is installed).
    Due to the form factor, this light invited comparison to the old Maglite DD and DDDDD incans I have lying around. The incans obviously don't fare well when comparing output, which is not a surprise. However I had forgotten how terrible the beam quality is on the Maglites. Out of curiosity, I took a look at Amazon to see what the DD LED Pros (274 lumens, about half the output) were going for these days.... the prices are comparable, but I'm afraid to try one of the newer Maglights since I'm pretty sure the beam will be nasty on those as well due to the legacy focusing head design.
    Flashaholic* tobrien's Avatar
    Dec 2005
    Georgia Highway 441
    great job with this review!
    Great job on the review thanks
    great review i am new here and dug this one up on a search !!
