NITECORE -- Keep Innovating
Page 1 of 2 12 LastLast
Results 1 to 30 of 55
Thread: Fire-Foxes FF4&FF3 HID Reviews
    Enlightened Ethen's Avatar
    Mar 2010
    China
    Default Fire-Foxes FF4&FF3 HID Reviews
    FF4
    Basic parameters
    Color-temperature 4300K
    Light source flux Super high: about 6000 lumens
    High: 4000lumens Low: 2000lumens
    Illuminate distance (ANSI) About 1500m
    Reflector Tech: High purity aluminum SMO
    Focu: 8mm
    Depth: 27mm
    Features: large area search inthe middle distance
    Bulb life ≥2500hr
    Boot time ≤15s
    Size Length x handle diameter x head diameter:
    155 x 49 x 75mm
    Weight About 520g(w/o battery
    Main body 6061 Aerospace-grade aluminum
    Finish Hard Ano III
    Ballast AC
    Output power Super high: 60W
    High: 42W Low: 24W
    Thermal protection 24w when thermal protection kicks in
    Waterproof IPX7、IP67
    Power Supply Battery rack, user can change the batterys, short-circuit, reverse polarity, over discharging protection
    FF3
    Basic parameters
    Light source flux high: 4000lumens
    Focu: 8mm
    Depth: 25mm
    Bulb life ≥2500hr
    Boot time ≤15s
    149 x 49 x 70mm
    Weight About 420g(w/o battery)
    Finish Hard Ano III
    Ballast AC
    Output power : 42W
    </p>
    The world light for me
    Default Re: Fire-Foxes FF4&FF3 HID Reviews
    VERY nice pics! Thanks for that! Looks like the FF4 is a definite winner.
    Hey Ethen, lovely pics!
    Just wondering, have you noticed any issues or bugs with the light, such as a whining noise (PWM) as seen in the first batch of FF3's?
    Thanks!
    From those photos it shows the FF4 is a real upgrade over the FF3. Thanks for the very nice comparative photos.
    *Flashaholic* Patriot's Avatar
    Feb 2007
    Arizona
    Excellent comparison photos!
    Flashaholic* KuanR's Avatar
    Jan 2012
    Macau S.A.R.
    These pictures have pushed me over to order the FF4. I am wondering what service doing outdoor uses to ship to Canada. I don't want to deal with couriers because of the brokerage fees
    I'm Ryan.
    Yes please! This will be my next light. Thanks for the review!
    Mar 2010
    China
    Thank's
    The first batch of FF3 (PWM),Is there will be noise.FF4 do not have this problem,very quiet
    Quote Originally Posted by ryansoh3 View Post
    Thanks!
    Quote Originally Posted by Ethen View Post
    Thank's
    Good to hear, thanks again.
    Flashaholic* yifu's Avatar
    Oct 2011
    Australia
    Thanks for the review, this might just be the greatest light ever made. 500K lux and 6000 lumens from a 'pocket light' is just amazing. I wonder if a FF5 might be released with said 100W input and 8000-9000 lumens, would be possible with the upcoming 4000maH NCR18650s or IMRs. Then we will finally have near LarryK output and throw in a pocket!
    Flashaholic Fresh Light's Avatar
    Mar 2009
    Stratford WI
    Quote Originally Posted by yifu View Post
    For a somewhat reasonably priced light of high quality not sure any thing is even in the ballpark but the ff3. There aren't many lights over 400 k lux and no pocketable lights over 5000 lumens. This light has both along with selectable levels and replaceable cells. If it works as advertised I would call it the best to date. I love the ff3 and this sure looks significantly improved.
    Lambda and other high power Lights
    i've noticed that in some photos the iphone is not catching the full brightness of the 60W mode and its making it look a bit like the 40W mode. the super high mode will be stunning to say the least IMHO
    Flashaholic* Fusion_m8's Avatar
    Dec 2005
    Melbourne, Australia.
    I wonder if the issue of the glass lens cracking under the extreme heat generated in super high 60w mode has been solved yet??
    Before we can become old and wise, first we have to be young and foolish.
    When I die, I want to be like grandpa, peaceful and asleep. Unlike his passengers, screaming and yelling...
    Quote Originally Posted by Fusion_m8 View Post
    I really hope this problem is addressed before the release of this light. I'm not too worried about it since FF lights has been around for quite awhile with their HIDs and so far I have not read any negligent behavior on their part as a manufacturer.
    Mar 2010
    China
    Quote Originally Posted by jalal20 View Post
    Yes that's right, the iphone ability is limited,Can't fully display should have some effect
    Mar 2010
    China
    The ignition testing
    Flashaholic from Mars Leoht's Avatar
    Jun 2010
    Australia Earth
    That got me, I'm hooked now, I will have to get one of these!
    Sent from my iPhone using Tapatalk.
    Mar 2010
    China
    Flashaholic* Lips's Avatar
    Mar 2005
    Louisiana - USA
    Nice pics Ethen!
    Is that a camera lens cap you have on there?
    Mar 2010
    China
    Thank's
    Yes,This is a 67mm camera lens cover,FF4 head is compatible with threaded.
    Quote Originally Posted by Lips View Post
    Nice pics Ethen!
    Jan 2012
    Macau S.A.R.
    I just had a chance to play with my FF4 and it KICKS! There 2 things that bother me though, one is the light can't go back into 60W mode once you leave it. This means you have to turn it off and turn it back on to get to 60W. This is very inconvenient because once you turn it off you can't turn it back on right away. Second is you can't jump into 60W right after start up, even after the light has warmed up, you have to wait at least 30 seconds or more before you can turn on max power.
    Does anyone else have these same issues?
    I'm Ryan.
    Is there any runtime limitations on 60W??
    Dec 2006
    US of A
    Quote Originally Posted by KuanR View Post
    Your light is behaving as designed. What's you're reporting is correct.
    Reportedly it is limited to 3 minutes.
    Hey Ethan, just curious how long it took to set the paper on fire?
    Mar 2010
    China
    Quote Originally Posted by 1SICKLT1TA View Post
    About a one minute,I think if the blowing will be quicker
    Mar 2010
    China
    This is my least favorite
    Jan 2012
    Macau S.A.R.
    Oh well, 40w is still very bright. For the price there's nothing else that can compare in output. I forgot to mention the light feels very solid and well built. My example came with perfect anodizing that feels just right
    I'm Ryan.
    After turning it off and then back on, what setting does it revert to?
    Jan 2012
    Macau S.A.R.
    The start up setting is always 40w. With HID's, you shouldn't turn them on and off repeatedly (re striking it) as that shortens the bulb life. Which is why it's a bummer you can't switch between ALL power settings without cycling the light off first
    I'm Ryan.
    Jan 2012
    Macau S.A.R.
    Thank's
    Thanks for the tip, I just ordered one of these lens covers off ebay for $1.55!
    I'm Ryan.
