HDS Systems
Results 1 to 10 of 10
Thread: Modded MTE H8-1A with Circular Beam
    Jun 2010
    Black Forest, Germany
    Default Modded MTE H8-1A with Circular Beam
    Hello everyone!
    A while ago, I had the chance to mod a quite unknown MTE H8-1. The light uses an interesting lens system to produce a circular beam.
    Following my little build-log:
    Almost all threads were "secured" with glue. The first glued part was the battery tube...
    ... followed by the lower part of the head.
    Of course, the heatsink-pill was glued, too...
    ... like the secure ring in the front.
    Fully disassembled. There were four lenses in this light. One small condenser lens in front of the LED, followed by a aspherical lens 2cm above, and two spherical lenses behind each other in the front.
    The ground of the original heatsink-pill was really thin.
    So I added some more mass to it. The aluminium part was press-fit and also glued with Arctic Silver thermal adhesive.
    Used a XM-L U2 on copper PCB (without dielectric) from LED-Tech, which was also glued under pressure using Arctic Silver.
    The new driver with custom modes got a massive brass contact and was potted with a high mineral (75-80% purest SiC) thermal adhesive.
    Close-up of the condenser Lens. I enlarged the openings a little bit on all three parts.
    Done! What a massy thing...
    For size comparison, next to a 4Sevens X10.
    Ready for beamshots!
    • MTE H8-1 - 5.2 Amps
    • 4Sevens X10 - up to 5.3 Amps (direct-drive mod)
    Target is at 65 meters.
    60 meters.
    95 meters (tree in the center).
    25 meters.
    195 meters to the small house.
    The original circuit had 5 modes (3+2) and around 2.6 Amps in the high mode. The new one is equipped with two modes (800mA & 5.2 Amps) and starts always on "low".
    Regards,
    Vinz
    Flashaholic* tobrien's Avatar
    Dec 2005
    Georgia Highway 441
    Default Re: Modded MTE H8-1A with Circular Beam
    this is so cool!
    Flashaholic Tacitus's Avatar
    Jun 2007
    Carroll Co., MD
    Thanks!
    KITROBASKIN's Avatar
    Mar 2013
    New Mexico, USA
    Very interesting. Impressive. You do great work.
    Sent from my iPad using Candlepowerforums
    Jun 2006
    SE Kansas
    This is probably my favorite beam type. It reminds me of the circus, and other shows I went to as a kid. I was always fascinated at how bright the spotlights were, and how they made such a small concentrated circular spot.
    I have been looking at building a light with the cbt-140 since it has a round die and would do the same thing, but the cost and power requirements are out of my league. This looks to be the perfect solution.
    Flashaholic* Icarus's Avatar
    Nov 2003
    Belgium
    Nice and interesting beam!
    Has anyone taken a lux measurement on the MTE flashlight? I wonder if the round beam is more intense than the plain aspheric lenses?
    May 2009
    WNC
    WOW I see your at it again. Your mods are so great. So glad you shared this with us. BTW I still have my drop-ins from you. Thanks Vinz, would like to see you on the forums more with your great talent. ....Robert
    Feb 2016
    Athens Greece
    The light is good,but I think it should have a strobe mode as well.I want something like that, for self defense.
    Feb 2016
    Athens Greece
    As I have learned that there is the possibility of taking one with the strobe mode,I ask if it is possible to be modded,how far could go with this light, and how would be the cost.
    I prefer the light to have the strobe mode and the high mode, first in a row.
