jack in the matrix
- Joined
- May 22, 2012
- Messages
- 11
Last winter (2011), I finally built a dynamo-hub front wheel (Shimano Alfine Hub and 26 in MTB rim) for my winter/wet commuter. I was tired of charging batteries and getting lazy, with the obvious results. The Alfine powers my 2 XML headlights and tail light (19 red LEDs) "to infinity and beyond", and all I have to do is turn 'em on and clean the lenses. I built a circuit (fits in the steer tube) that boosts output at my optimum speed and also provides an acceptable stand light (one headlight and taillight) when the bike comes to a stop. It works so well, I decided to do the same thing for my summer commuter.
While the Alfine works great, I had since read about this hub and wanted to try one.
Shutter Precision touts their dynamo hubs as the lightest, most efficient on the market. The PD-8 is a (6 bolt) disc version of its 6V3W hub intended for 26 in. or 700c wheels. As such, I assume it puts out 500 mA, and take efficiency to mean less drag, when the lights are on or off. (FWIW, on the road, I don't notice the drag from the Alfine, but less can't be bad.)
It cost $130.00 USD (including shipping from Taiwan) and arrived at my door in Canada in under 2 weeks.
I was very happy with the price, delivery, and product from the box. The QR hub (skewer not included) seems well constructed, and is certainly small and light (for a dyno-hub). The bearings are sealed, so replacement may be problematical. Time will tell.
Build-up was straightforward, while the left flange is 2 mm bigger than the right (at least on the PD-8, not really an issue). In the workstand, with tire (700 x 32c) mounted, it definitely spins more freely than the Alfine, in both modes, but the light didn't seem to come on as early.
On the road, the hub works as expected, but it does take another (3rd) pedal stroke to put out full, steady light. This system has 2 P7 headlights and 1 red XP-E taillight, and it powers them all with no noticeable drag from the hub, so I just leave them on during the day too. (The XP-E is quite effective, running near its max. At a stoplight, a motorist had to tell me how bright it was, and where could he get one? This was in broad daylight, and music to my ears.)
I've read that some dyno-hub users feel vibrations in the handlebars at certain speeds, usually above 20 kph. I believe this issue mostly arises on older (road/touring) bikes with more flexible frames and (especially) forks. I haven't noticed any vibrations on either of my bikes - both have steel MTB frames and robust straight blade forks.
After limited use, I'm very happy with this hub. It's light enough, looks good, and seamlessly powers my 2 headlights and taillight. Just remains to be seen how well it stands up to everyday use.
