RMSK, Inc.
Results 1 to 5 of 5
Thread: Test/Review of Xtar 18350 900mAh (Black)
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Default Test/Review of Xtar 18350 900mAh (Black)
    Official specifications:
    • Capacity: 900mAh
    • Voltage: 3.7V 3.33Wh
    • Size: °18.0▒0.2mm x 36.3▒▒0.5mm
    This battery has slightly better capacity than specified.
    The battery does very good up to 2A, at 3A the cells show variations.
    Conclusion
    The battery has good performance and at can match some IMR cells at 2A (It has more capacity and about same voltage).
    I will only rate the battery as acceptable, because it uses an unknown cell.
    Notes and links
    The battery was supplied by Xtar for review.
    How is the test done and how to read the charts
    How is a protected LiIon battery constructed
    More about button top and flat top batteries
    Comparison to other LiIon batteries
    My website with battery, charger, usb reviews, comparisons & information: https://lygte-info.dk/
    Latest addition is multimeter reviews
    Default Re: Test/Review of Xtar 18350 900mAh (Black)
    Excellent job, thank you HKJ!
    Aug 2010
    ROLL TIDE!
    Very interesting! Easily the highest capacity 18350s I've seen tested. However, I'd be especially impressed if they can maintain this level of performance after very many 3a discharge cycles. I intend to find out.
    Where to buy?
    SPY 007 XM-L2, BVH 150w Vec192 HID, Gen III Maxabeam, Barn Burner, FireFoxes III & IV, Mac's Customs 3840L & Damascus/Cu/Al Tri-EDCs, ma_sha1 FrankenMag, Drake, MF Scorpion 4x XM-L2, Tri-219 EYE10, XP-G2 X10
    HKJ's Avatar
    Mar 2008
    Copenhagen, Denmark
    Quote Originally Posted by Colonel Sanders View Post
    I hope you will report back when you find out.
    Where to buy?
    I do not know, but I will expect that any place with Xtar batteries will get this one also.
    Aug 2010
    ROLL TIDE!
    It would be great if Xtar could tell us when and where these cells could be bought. Never know, might sell a few that way!
