lightyearsaway
One of my students is going through flight school right now and will be basically finished in a few months. He has been assigned to the Boeing 747 and will probably stay on as a 3rd seat for awhile before being moved to a co-pilot. However, this is a great achievement for him and I would like to buy him a decent light for his bag or as a spare. I don't have money to buy him the type of light he may need for the walk around. Have no idea what he may need it for, cockpit maybe, just a spare perhaps. Batteries have be long life I think, but Lithium batteries he may forget to charge and I read on another thread they could explode, so... not sure how good of an idea that is, but... I may consider. I originally bought him a Maglight XL100 before I found this forum, and to be honest I hate it, it's a piece of junk and hard to use. Definitely not pilot material.
____I would like to purchase the light from a brick and mortar store. I am located in ______________.
_XXX___I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest!
____Less than $25.
_XXX___Less than $50.
_XXX___Less than $100.
____Less than $150.
____Less than $300.
____I have no limit.
____I'm flexible, tell me what you gotJ.
____Other, please specify ________
3) Format:
_XXX___I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a dive light.
____I want a portable spotlight.
4) Flashlight-specific format/size:
____Keychain size.
__XXX__Every day carry small (2-4 inches).
__XXX__Every day carry medium (4-7 inches).
____Holster carry.
____Big enough to need its own travel caseJ.
____I don't care.
____I don't know.
____N/A
5) Emitter/Light source:
_XXX___LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
XXX____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
____I would consider getting a light that is pieced together (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
_XXX___I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today's most powerful lights)
_XXX(Maybe)___I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
____I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
____I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
____I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
_XXX___I want to navigate a dark room or read a map (0-10 lumens).
__XXX__I want to walk around an unlit rural area (50-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
_XXX___Less than 1 yard/meter (reading, other close work)
_XXX___Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
_XXX___5-20 yards/meters (check out a noise in the backyard)
_XXX___30-50 yards/meters (I have a big backyard)
____150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____30-60 minutes (I have plenty of batteries just ready to be changed)
_XXX___90-120 minutes (Runtime is moderately important, but still not critical)
_XXX___3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
_XXX___Very Important (Camping, Backpacking, Car Glove-box).
_XXX___Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't care.
____I don't know.
12) Switch Type and location (choose all that apply):
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
____I don't care.
_XXXX___I don't know.
____A simple on-off with only one output level is fine for me.
_XXX___I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
_XXX___I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Blinks to show location.)
____I want SOS mode.
____I want a beacon mode.
____I don't care.
____I don't know.
I think I need at least two, one for the cabin at night and one for other things. But needs to be easy. A twisty would work, but I am not familar with how the others work. So this is critical, if any pilots out there, let me know what works the best for you.
14)Material/Finish/Coating
_XXX___Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's flashlights).
_XXX___Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
____I don't know.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
_XXX___Red filter (for preserving night vision). Might be nice but not critical
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
Ok have at it and thanks in advance. If you are a pilot and you think what I want is odd, then please give me your ideas, I have no idea what you guys really need. Again though I am not looking to buy him an expensive first hand light, I am looking at buying him something he can use in the cockpit and for emergencies and stuff like that.
____Less than $25.
____Less than $150.
____Less than $300.
3) Format:
____Keychain size.
____Holster carry.
____I don't care.
____I don't know.
____N/A
____I don't know.
6) Manufacturer:
____I don't care.
____I don't know.
____I don't care.
____I don't care.
____I don't know.
____I don't care.
____I don't know.
____Holster
