Murgatroyd
- Joined
- Aug 30, 2013
- Messages
- 1
Hi everybody. I work at a big box store, and a customer called asking only about getting four 1000W Metal Halide lights for a youth arena with general dimensions of 150 FT X 200 FT. My thought was the customer wants one fixture for each side of the arena.
To get me started, a Cooper Lighting rep sent me a spec sheet for their outdoor flood AS Allstar:
http://webconfigurator.cooperlighti...AS_AllStar_ADH082298_20130830102713_13691.pdf
The Allstar has narrow, medium, and wide, beam options WITH or WITHOUT spill louvers as well as other options such as:
C3 = 3' Cord with no plug (Specify Voltage) C6 = 6' Cord, Prewired (Specify Voltage)
U3 = 3' USL Water Tight Cord & Plug for USL System (Specify Voltage)
F1 = Single Fuse (120, 277 or 347V only)
F2 = Double Fuse (208, 240 or 480V only)
HD = Heavy-Duty Shroud
RQ = Remote Quartz
RT = Remote Quartz Cold Start Time Delay
TV = Top Visor (Black Polyester Powder Coated)
Any suggestions on the best common sense options for configuring the product (or a different product) for the customer? I realize I may need to ask the customer some additional followup questions to satisfy his needs. Some concerns are which beam option would be best fit the need and if it should have spill louvers or not as well as the voltage option.
Does 1000 watt sound sufficient for a 150 x 200 ft space? That particular model maxes at 1650 watts. I'm open to other products from Cooper Lighting if anyone has suggestions since I reached the limit of what the Cooper rep could do for me over the phone. Thanks in advance for any help given.
RQ = Remote Quartz
