Greeting all,
First of all it should be noted that I have only a basic understanding of circuits. Thus I am here seeking guidance (and to be frank possibly even someone to take this project as a commission).
Background
Anyway, I have an OMS Phantom 10W HID canister light: http://www.omsdive.com/downloads/oms_10w_hid.pdf
The battery pack is comprised of 11x 4/3 NiMh cells for 13.2V and 3500mAh
However, I think that I must have version one of this, because instead of the magnetic reed switch that has been alluded to in a previous post: http://www.candlepowerforums.com/vb/showthread.php?327491-OMS-phantom-HID-10w-repair my light has a mechanical switch that articulates a lever switch http://www.mouser.com/ProductDetail/Omron-Electronics/D2F-L/?qs=ISjK4nnpKfGN15FPx5TQjg==
It runs the Welch Allyn B10N002 Ballast and I don't know what light. However, this doesn't matter because I would like to convert this to a LED as I am tired of spending so much on these fragile bulbs.
Project
Idea #1: 1x LED with reflector
Reflector: 35mm diameter x 32 mm length: http://dx.com/p/35mm-35mm-aluminum-textured-op-reflector-for-cree-led-emitters-2-pack-14599
LED: Cree XM-L2 U2 12mm Star (cool white): http://www.kaidomain.com/product/Details.S021213
Driver ???
Idea #2: 3x LED using aspherics
LEDs: 3x Cree XM-L2 U2 12mm Star (cool white): http://www.kaidomain.com/product/Details.S021213
Optics: 3x 15mm Optical Glass LED Lamp Lens - 1pc: http://www.kaidomain.com/product/details.S020649
Spacer: ???
Driver: ???
Discussion
Idea #1
This would seem to be the easiest, however the big problem that I see in going this route is the power input. Namely that I have a great deal of power that is going to need to be stepped down in order to avoid damaging the LED. The listed specs are 10W and 3A max. I figure that I would probably be running this at or near its max. So my question is (Q1) what diver and what sort of driver do I need? (Q2) Do I need to make a separate resistance circuit?
The other problem would then also be the heat that is going to be present. I do not have any machinery to create an aluminum heat sink. However, this is likely to be a problem regardless of whichever path I take. This problem will necessarily result in me having to contact a custom manufacturer.
Idea #2
This would make a monster of a light and I think I would prefer to undertake this project. For this I would need to find some 15mm o.d. x 13 mm i.d. tubing to use as spacers. The optics say that it has a focal length of 10mm, so I take it that I would need to cut 10mm lengths. (Q3) Do I cut 10mm spacers or is there some other measurement to take into account? Next I figure I would drive these at about 1.4A and 3V (Q4) What driver(s) should be used?
General discussion
I have a 35mm foot print hard limit to fit inside the exterior casing.
Once again this being the first generation there is a large problem: water tightness is maintained by pressing a piece of glass down using a spring washer (it is wavy thin piece of metal) onto an o-ring which is on a spacer. The spacer fit onto the HID lamp. The width of that spring thing is ~3.5mm, thus spacing tolerance is very low.
I am interested in hearing some feedback
(Q5) Is this project even reasonably feasible?
Thanks in advance for your sage advice.
Background
Project
Driver ???
Spacer: ???
Driver: ???
Discussion
Idea #1
Idea #2
General discussion
