therock
- Joined
- Feb 26, 2005
- Messages
- 195
I wanted to report my experiences after nearly a year with the conversion of my 2002 Dodge Grand Caravan single element OE headlights to the European Chrysler Voyager dual element headlights.
First I want to thank all who helped me in the process in THIS THREAD. Other than being great resources, they demonstrated the patience of the saints with me. I was given information, instruction, and put straight on issues I never considered. And provided services for a Jam Up wiring harness and a daylight running light module, and some great lamps.
It was lots of money to put into a set of headlights. But knowing the vehicle was going to be kept until the wheels fell off and doing tons of night driving, I have no regrets.
First, the driving experience improvement is amazing. The lights are not blue or yellow, they are completely neutral in color. I can onlt describe it as Crisp or Sharp.
Second, if you don't get the aiming right or VERY close it sucks. You either offend everyone on the road you approach form front or rear, or have lousy range.
Getting them aimed right. Mercy! This was tough and I am still not 100% sure because I refuse to pay $100.00 for a Volkswagen dealer to put a beam setter on it.
I live 40 miles north of Atlanta and venture down there everyday. I called all kinds of businesses, shops, and Webb searched for a beam setter location. I even called Hella!
Hella informed me that all Volkswagen dealerships are "Required" to have one. I called and they want an hours pay @ $100.00 after taxes. And I had to gently argue with him to agree take a non-VW vehicle for the job. So not only did he "Not" really want to do it, the amount hurt my feelings.
So I used Daniel Sterns template and a pea soup thick fog to finally get them to be very close. I do understand a beam setter is the official or preferred method, and the template is a starting point or if you have nothing else.
On the Daniel Sterns template instructions. I am an industrial maintenance technician and machinist. I understand measurements. I mention this because I found you need to be very accurate with your measurements, especially with the distances from the center points of the lamps. If you get it wrong you are beaming either cross-eyed or the opposite as the distance increases.
Another frustrating thing is finding a relatively level piece of ground. I set out with a 6' level and a measuring tape and it was a chore here in N. Ga I tell you. I finally found an upholstery shop that had a long section of pretty level concrete.
All this took lots of time and several efforts here and there and it was not until I hit a very thick fog in the early AM that I really seen how bad I was doing. I was WAY cross-eyed, and this was most noticed when I put the highbeams on, and not far enough to the right side of the road at all on low beam. And I believed I was doing good. I was not getting flashed at all by motorists but that's not a defining gauge is it.
This fog was so thick I had the motor off while I was making corrections so I could hear any vehicles coming.
I proceeded to align the high beams so they beamed straight forward and level as best my eyes could determine, and then hit the lows. They now were going towards the right side of the road as they should.
All I could think was WoW!
As soon as I could I returned to the upholstery shop with the template to see the results there and the amounts that I was off of my marks were not much but it enlightened me to the fact of how close I needed to be when I made the template. There is not much room for a tolerance.
Next I (again) had my girlfriend drive my van while I drove hers, towards me, follow me, pass me, and travel steady at varying distances in the lane to my left to see what its like for other motorists with these euro beam pattern.
I seen nothing offending and again liked in what I seen as far as the color.
I think its amazing how much more light is delivered to the right side of the road in comparison the the US pattern. And how much more the road signs are reflecting and at the greater distances.
As far as the side marker LED's I put on the front they really put out nice and do not look out of place or like an add-on at all.
I still plan on getting in front of a beam setter. I just have to hunker down for the cash.
Thanks, Guys.
Thanks, Guys.
