C21Cvn The Ideal EDC
Must Read & Agree Before Purchase: Click Here
Factory Specs:
Features:
CREE XM-L2 and XP-E P2 LED, with a lifetime of up to 50,000 hours;
Side switch on the top, 6 output modes:
White Light
Turbo: 830 Lumens (Automatically enter High mode after 5 mins continuous use to avoid overheat)
High: 510 Lumens (1.9hrs.)
Mid: 130 Lumens (9.5hrs.)
Low: 42 Lumens (31hrs.)
Strobe
SOS
Red Light
High: 98 Lumens(3hrs)
Mid: 63 Lumens (9hrs)
Low: 14 Lumens (45hrs)
Strobe
SOS
Constant current circuit, constant output
Specifications:
Effective range of 188 meters
Intensity: 8800cd
Uses one single 18650 battery (2*CR123A/16340 batteries)
Working voltage: 2.8~8.4V
White light uses high quality metal reflector, maintains great throw distance and spread with an ideal beam pattern; Red light uses high quality resin lens
Aerospace-grade aluminum alloy, Stainless Steel retaining ring on the top
Military Specification Type III- hard anodized body
Waterproof, in accordance with IPX-8 standard
Ultra-clear tempered glass lens resists scratches and impacts
Tail stand capable- can be used as a candle
Dimensions:
Dimensions: 27mm (head diameter) x 107mm (length)
Weight: 78g (Excluding Battery)
Accessories:
Lanyard, O-ring
Modification:
$125
+5$ for "V54" hand engraved on the bottom of the tail cap.
+$15 if you are outside of USA
+ $15 for PDTc or PDTc front LED
Email/Paypal: [email protected]
Factory Specs:
Features:
White Light
Strobe
SOS
Red Light
Strobe
SOS
Specifications:
Intensity: 8800cd
Dimensions:
Accessories:
Lanyard, O-ring
Modification:
- XM-L2 Neutral or Cool White of your choice
- Convert Red XPE to XPL 5700K or 4000K
- Beautiful beam all around. I think this will be my new EDC as I always love a good Mule.
$125
