This is definitely not the case. Most drivers do not have adequate light on low beam to drive safely. This is why the "full-time high beam"/"glare-free high beam" systems recently being released are such a big deal: they finally, at long last, fix that problem
save for the fact that they're not approved for use in the US yet (that is, unless it's happened in the last month or two when I wasn't paying attention.)
I think we're actually saying the same thing but thinking we're disagreeing with each other. Given the constraints of a low beam pattern, and required aiming specs, there is a finite distance past which you won't be able to see farther. After a certain point, throwing more lumens out the front won't allow you to see any farther or drive any faster (with no streetlights or other traffic to contribute to the light that you can use to see by); you'll be simply illuminating the area you're already seeing to a brighter level, which may actually be counterproductive. At least to me, it seems like the Cibie H4s (at least the 7" round and 200mm rectangular, the two that I've used) with a relay harness and 55W lows reach that goal.
And they *are* superior to pretty much every headlight I've driven behind, with the exception of the HIDs in my BMW. Here's a partial list off the top of my head
- sealed beams of just about every format
- 1988 VW GTI 16V US spec "aero" halogens
- 2002 VW GTI 1.8T US spec halogens
- 1990 VW Corrado US spec halogens (OMG those were some awful headlights. "I can't see a (expletive deleted) thing" comes to mind. Shockingly bad.)
- 1990 VW Corrado EU spec halogens with relay harness (these were actually quite good and right up there with the Cibies)
- 1993 Ford F-150 US spec halogens (nearly as bad as the Corrado lights, but with the added bonus of causing lots of glare to other road users)
- 2005 Chevy Impala halogens
- 2008 Chevy Impala halogens
- 2011 or 2012 (I forget) Ford Fusion halogens
- Pontiac Montana halogens (don't know year, friend's vehicle)
- Isuzu Xterra halogens (same)
To date, the three cars I've driven that I've felt the most comfortable at night have been
- my old Porsche 944 with 7" round Cibies and a relay harness (it was pretty pathetic with the stock wiring and non-halogen sealed beams...)
- the Heep with 200mm Cibies and relay harness
- E92 BMW 335i with factory "adaptive" HIDs.
I can't really rank them because I don't feel that I "outdrive" any of those lights on high beam before limiting my speed for other reasons. I learned to love the Cibies when I got them installed on the 944; at the time I felt silly spending so much as a proportion of the value of the car on lighting, but at the time I was commuting on a windy, unlit two-lane road without much traffic, often while it was dark. Before installing the Cibies I felt limited to a safe maximum speed of about 40-45 MPH even on high beam. After upgrading, I installed some old stock 55/60W bulbs I had laying around to try (the kit came with I think 90/100s but I was worried they might be too glaring) and I never installed the brighter ones because on the roads I drove now my speed was limited by how far away the next curve was... I was lighting up the entire length of the longest straightaway on that road and then a little farther on into the woods, even with only 60W.
Some of us still have our minds stuck in 1979. In America, it was either crappy sealed beams or "European" H4 lights by Cibie, Marchal and Hella. Hard to adjust to all the good options we have today (also, I tend to choke on the prices of some of those really good options).
Well, some of us don't make the factory headlights one of the primary factors in the purchase of the vehicle; however, I've learned my lesson by buying a vehicle that I thought was a good deal at the time and finding that retrofitting either UNECE headlights or sealed beam buckets was a very difficult proposition! But when I do get a vehicle that was either originally equipped with sealed beams or has "aero" headlights but UNECE versions available (see Corrado above) upgrading is a no-brainer. I actually prefer sealed beams as that opens up more off the shelf choices for upgrading.
Probably the OP is sick of us going back and forth about this, but as you say, the price of any options that offer any significant advantage over a good Cibie H4 sealed beam replacement is eye-watering, especially for a utility vehicle like a pickup truck (or, say, a Jeep Cherokee to pick a completely random example) and doubly so if you've already made the commitment and installed a heavy-gauge relay harness. At least for me, the Cibies bring my vehicle up to the level where I'm comfortable driving it and am not really wishing for more - in sharp contrast to many of the vehicles that I've owned pre-upgrading.
