Hi all!
I am doing a lighting system for the cupboards in my house, and I think I need a diode in there.
Here is the situation:
I have a cupboard with two doars, one LED strip on each door, being fed by two 12V 15W constant voltage driver( one for each door), controlled by door switches. I have one central strip in the middle of the cupboard, fed by BOTH drivers, so it comes on whichever door I open. Imagine a big H, in which I need to power each side and the middle individually, without power going from one side to the other.
For this I think I need two diodes on the central strip, so when I open one door, it doesnt feed the strip on the OTHER door through the central stip.
So I started looking into diodes and got confused with the types etc.
So my questions:
1- which type of diode do I need ( are they going to cause voltage loss, on the voltage being fed to the strips?)
2- do I need to use one with a specific power rating? ( 12v 15W, circuits, so the back voltage will be 12v as well.)
Thanks in advance for your help guys!
So my questions:
