Manufacture Specs:
All-titanium construction
Waterproof (IPX8)
User replaceable glass lens
Turbo boost technology
Battery reverse polarity protection
User removable pocket clip
Tail stand
SPECS
DIMENSIONS | Length: 2.9 inches (75 mm) Body diameter: 0.78 inches (20 mm) Head diameter: 0.78 inches (20 mm) Weight (without batteries): 1 ounce (29 grams) |
LED EMITTER | Cree XP-G2 R5 |
VOLTAGE RANGE | 0.8V - 3.2V |
BEAM PROFILE | Center spot angle: 9° / Spill angle: 75° / Beam distance: 120 meters (131 yards) |
BRIGHTNESS LEVELS; LED(ANSI) | Low: 1(0.5) lumens, 150+ hours / Medium: 35(23) lumens, 10 hours / High: 251(158) lumens, 1.6 hours / Turbo: 381(242) lumens, 0.9 hours Up to 550 LED lumens can be achieved when using an RCR123A cell. |
SPECIAL MODES | Strobe, Strobe(Var), Flash(Hi), S.O.S.(Fast), S.O.S., Beacon, Flash(Lo) |
REFLECTOR | Very light textured aluminium reflector |
BODY MATERIAL | Titanium |
BEZEL MATERIAL | Titanium |
LENS MATERIAL | Impact resistant waterwhite glass lens, anti-reflective (AR) coating on both sides |
INCLUDED ACCESSORIES | Spare o-rings, User manual, Polished stainless steel pocket clip, Rigid nylon holster with self-retention device and flip, Mil-spec paracord lanyard with quick attachment clip |
(Basic) Press on the switch button until it clicks to switch on. Press the switch again for off. Access output groups 1 & 2 by tighten or loosen the head. Slightly press the switch to switch between different outputs.
(Advance)
1) Moonlight output - dim or increase the entire output range of the group 1 output. Toggle this setting starting with head loosens, turn on the light, and then repeat tight and loose for three times.
2) Mode memory - remembers the last output in group 1. To toggle this setting, with head tighten, turn on the light, and repeat loose and tight for three times.
Feature - Specs - My Impression
- Current bump from 1.5A - 2.3A (I can probably bump current higher by tweaking the driver some more however this might affect CR123A function)
- Recommend IMR16340 for highest performance
- XPG2 LED Dedome bonded to Copper
- Each light fine tune for best focus
- Best thrower for this size I have seen
- Crazy bright for the the size
- Perfect fit and finish for the money
- Strong handsome pocket clip
- Good looking overall
- Flawless beam
- Wide spill width for peripheral vision paired with excellent throw
- Great Survival Light
- Great EDC Light
- Great Back Up Tactical Light
- Great Christmas Gift
- Great WOW / Show off light
- Short burst on High Only
$105 XPG2 or XML2 PDT
+$5 for "V54" hand engraved bezel
+$7 if you are outside of USA
If you want Shipping Insurance Please Ask
Email/Paypal: [email protected]
