Steelwolf
I am quite enamoured with the MYO 5 design, but feel that there is a possible shortcoming with the use of an incandescent bulb. I have seen the bulb and think that it is well built to withstand quite a high level of impact shock. Nevertheless, it is still an incandescent bulb and subject to the usual deficits, especially yellowing as the battery runs down.
I was wondering if it might be possible to substitute the EverLED in place of the incandescent? I know that there will be quite a fair bit of modding to do as the original bulb is bi-pin. But before I blow about AU$150 on it, I need to know some things.
Is the incandescent direct driven or regulated?
Is there enough space to put in a PR base holder or would it be better to separate the circuit and side-emitter LS?
If it is to separate the circuit and LED, would there be enough space to put in a Sandwich anywhere?
How well does the reflector work on the long range focus of the original incandescent, and can anyone hazard a guess as to how well it will focus a SE?
Would the output of the SE compare well to the output of the original incandescent?
Thanks in advance.
Thanks in advance.
