HKJ
[size=+3]Orbtronic 18650 3600mAh (Black)[/size]
Official specifications:
This is the next increase in battery capacity, from 3400mAh to 3600mAh, this is not a huge increase.
With my test conditions (Discharge to 2.8 volt), I do not get 200mAh more capacity, more like 100mAh.
The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity.
Orbtronic uses a very nice packing for this battery.
Due to the protection the battery cannot deliver 7A continuous.
[size=+3]Conclusion[/size]
When comparing this battery to the 3400mAh cell, the new battery has slight higher voltage and slightly higher capacity, this is not a revolution in any way, just a small improvement.
Being based on a Panasonic cell the battery is, of course, a very good battery.
[size=+3]Notes and links[/size]
The battery was supplied by Orbtronic for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
- Capacity (Ah): 3.6 Ah (3600mAh)
- Energy (Wh): 13 Wh
- Nominal Voltage (V): 3.6V - 3.7V
- Charging Voltage (V): 4.2 V
- Weight (g): 47 g
- Diameter (mm): 18.6 mm (+/- 0.03mm)
- Height (mm): 68.9 mm (+/- 0.03mm)
- Max. Discharge rate: 2C (7.2A)
- Chemical Composition: Li-ion (Lithium-Ion)
- Protection ICs: Made in Japan (Design by Seiko)
- Bare Cell: Made by Panasonic, Made in Japan
- Button Top: Yes
- External Resettable Protection: Yes
- Overcharge Protection: Activated at 4.35V
- Overdischarge Protection: Activated at 2.5V
- Overcurrent Protection: Activated at 7.5A-8.5A
- Overheating, and dual short circuit protection (External, and Internal).
