Angryfox
Results 1 to 30 of 30
Thread: *new* Eagletac T25C2, S200C2 and MX25L4
    *Flashaholic* kj2's Avatar
    The Netherlands
    Default *new* Eagletac T25C2, S200C2 and MX25L4
    Just found these, at my local Eagletac dealer.
    The EagleTac T25C2 is one of EagleTac's biggest announcements of the year. Designed from scratch, the T25C2 is a big improvement from its predecessor T20C2. The T25C2 boosts output to 1180 LED lumen with its C3300 Extreme3 circuit.
    The T25C2 also uses upgradeable LED drop-in module design, which allows the user to use optional LED dropin modules (e.g. XML color/UV 365|395/IR 850|940, etc or future released LED's). The T25C2 shares the G25C2 remote switch and extended body tube.
    The S200C2 is based on the T200C2 platform, but has an increased reflector size. It has the same size as the reflectors from the EagleTac S-series.
    The S200C2 has 380m beam distance and produces 1116 LED lumen
    The EagleTac MX25L4 is a step up from the MX25L3. The MX25L4 uses 4 18650 batteries, or 8 CR123A batteries for more runtime and higher output values.
    With the SST90 LED it produces 2850 LED lumen (2210 ANSI FL-1 lumen)
    With the SBT70 LED it produces a lower output, but an even better beam distance of 593m.
    Flashaholic* Ryp's Avatar
    Jul 2013
    Default Re: *new* Eagletac T25C2, S200C2 and MX25L4
    This is great, thanks!
    Any ideal of pricing on the T25C2 as well as the drop-ins for it?
    "Do not trust the internet when citing quotes. It is often inaccurate" Thomas Jefferson
    Quote Originally Posted by Lun@ticFringe View Post
    Around $90 with XM-L2 drop-in.
    Flashaholic* LilKevin715's Avatar
    San Diego, CA USA
    I just bought a T200C2 a month ago... Why oh why did you have to post this new info?
    The T25C2 MKII looks to be a definate upgrade from the older T20C2 MKII (still a great light). The T25C2's C3300 circuit (3.3A) is probably the single biggest upgrade compared to the T20C2's C2100 circuit (2.1A Turbo boost, 1.5A sustained) of the XM-L/XM-L2 models. I’m glad Eagletac decided to continue the module implementation so users can upgrade (or modify ) their light without having to buy a whole new light. FYI according to the pics I've seen the existing T20C2 MKII modules wont work with the new T25C2.
    The S200C2 with the larger head and reflector will definately increase throw. Everything looks fine except the bezel, it just looks out of place compared to the rest of the light. A more aggressive look with crenulations on the bezel would look better IMO.
    Overall its good to see Eagletac releasing new models. For a while in the past they were pretty stagnant in terms of updating their product lines.
    My Mag Mods: SST-50 , XM-L
    Jul 2009
    Illinois
    Did you actually see these lights or just the literature/pics?
    The Netherlands
    Quote Originally Posted by Mr. Tone View Post
    Just pics.
    Jul 2009
    Illinois
    ok, thanks
    Flashaholic Blitzwing's Avatar
    Apr 2009
    Straya
    They are kicking butt - just imo need a tight focus, high lux, long range 25mm body thrower. Maybe an xp-g2 in 55mm head or similar.
    A little bit more data:
    S200C2:
    T25C2:
    MX25L4:
    Dec 2007
    USA
    I wonder if the S200C2 still steps down, slightly-10%, like the T200C2?
    It has substantially more mass in the head [5.9 oz, versus 4.4], so if it still steps down, presumably that would be because of 18650/cr123A limitations, and not heat.
    It steps down but simply because it's T200C2 with bigger reflector (it has the same driver), not battery limitations.
    San Diego, CA USA
    Quote Originally Posted by phantom23 View Post
    It steps down but simply because it's T100C2 with bigger reflector (it has the same driver), not battery limitations.
    Typo? I think you mean T200C2
    Yeah, just a typo. Corrected, thanks.
    PS. I'd love to see TX25C2 with x200C2 (or even T25C2) modes, current onea are not very useable.
    I would like the SBT-70 version. Anyone have a Review?
    Default EagleTac S200C2
    Just wanted to comment on this light. My first "real" flashlight. Amazing. Don't have anything to reference against but I can't imagine getting any more out of such a small package.
    Default Re: EagleTac S200C2
    I almost purchased one of these last week. Looks like it has some nice throw to it!
    GOOD TINT!
    Apr 2009
    Straya
    I've been interested as well. Found a beamshots video on Youtube and it looks good.
    Really pleased with the light. It does have great throw but also a very useable flood. Also like the simplicity of just having 3 settings. I had my eye on a few others (Streamlight Protac HL, Armytek Predator 2.5, and an EagleTac T25C2) but went with this one. May buy all three in the future. It's crazy how much better a quality flash light is. My wife is concerned with my new hobby.
    Flashaholic* Roger Sully's Avatar
    Sep 2009
    New Jersey
    Icon15 Re: EagleTac S200C2
    As well she should be!
    Nice choice of lights BTW. I started out with EagleTacs and it was just tip of the iceberg!
    I like my T200C2 which uses the same body and electronics. Only negative I can think of is that it could use a fourth brightness level around 80 lumens as the spacing between low and medium is pretty big.
    Dec 2007
    USA
    Really, they should call it low, high, turbo. (and the turbo+ for the first 200 seconds)
    I agree with the large jump between the low and medium settings, however it's nice to see that jump from medium to high as well. On a side note, I received this light with a battery and charger.
    The battery I'm not too worried about as it seems to be quality stuff (correct me if I'm wrong)
    [IMG][/IMG]
    The charger....not so much
    [IMG][/IMG]
    So far I haven't burned the house down but I'm opened to suggestions for a better one.
    I went with the Nitecore i4.
    Flashaholic C.M.S's Avatar
    Oct 2014
    Kansas
    Default Eagletac S200C2 ?
    Any of you have one of this and how do you like it .
    this one is a front runner for my next light .
    Zebralight SC600 mkII L2 , Streamlight ProTac HL , ET D25AAA Nichia.
    Flashaholic CUL8R's Avatar
    May 2009
    Colorado Springs
    Default Re: Eagletac S200C2 ?
    Quote Originally Posted by C.M.S View Post
    I have the vn edition and love it - can't comment on the stock model: http://www.candlepowerforums.com/vb/...aby-Throw-King
    Feb 2016
    Athens Greece
    Hi.
    I have just received a Eagletac S200C2 XP-L Hi V3 from Ledfire torches UK.It is a very good thrower,having it compared with a Nitecore MH27.The tint is bluish,and there are three modes only. Unfortunately,there is not a strobe mode also.
    Because there were two little batteries as a gift in it,I tried to charge them via a XTAR VC4,without check them enough,but after 5 minutes,I understood that the batteries were non rechargeable.Exactly,they were 2X123A.Luckily,they were not exploded,but they were hot ,ready to explode.
    You see the letters on the batteries were very small,and I couldn't read the text on them.
    I am very lucky indeed.
    Aug 2014
    Fairfax Va
    Hey somebody else finally got the new S200C2 HI upgrade! Great to see. Truly one of the sleeper lights of the year. Cheap(for and ET)simple as a framing hammer with only 3 modes and man does this thing throooooow! Downsides are no holster for some reason, I did not get a lanyard with mine which is weird, no cool rubber tailstanding boot had to order mine separately did I mention only 3 modes? Regardless this thing more or less devours all my other mid sized throwers from the MH27 to my TN4A HI to my Pred Pros in terms of throw. Blinding white output looks dead on. Running fresh Keeppower 3500mah GA is awesome with this light. If you get this light I highly suggest getting a rubber tail stand boot separately greatly improves ergos of the light.
    Feb 2016
    Athens Greece
    Quote Originally Posted by CelticCross74 View Post
    Where are you going to buy this rubber tailstanding please?From the other hand,I use a 30Q and it shines.
    Aug 2014
    Fairfax Va
    I see you are in Greece. Go to Eagtac's US site and click on "dealers" one is a semi official ET distributor that has the rubber boots that fit on the end of the S200C2, T25C2 and G25C2 they are all the same single size I bought a couple. Youll have to pay for overseas shipping but I do not know where else to get them click through the US dealer links I believe it is one of the first four. Awesome khaki tan higher quality lanyards to be had as well if that is your thing. S200C2 feels like a much more expensive light with the boot on. Worth it.
    A 30Q? Man that is pretty hot! Hey if it works and you can get em cool...
