kj2
Every now and then, Fenix writes out a Global Testing Campaign. One of the latest, was the TK76 campaign. I was one of the lucky ones, who received one.
It took some time before I received mine, but it looks like I've a later Testing-sample. Easiest way to spot the difference, is how the brand and product-name is lasered on.
As many of you have seen, Fenix is producing more and more flashlights (and headlamps) now with double or triple leds. The TK76 features a Spot led with two wide-angle leds. The right led has a neutral color.
I find the neutral color specially handy, when you need to see true color. I mostly use it while walking outside. It lets you see everything, but isn't that intense what Cool-White is.
Specs and Features: (given by Fenix)
·Uses two Cree XM-L2 (U2) LEDs and one Cree XM-L2 T6 neutral white LED with a lifespan of 50000 hours
·222mm (Length) x 55mm (Diameter) x 100mm (Head length) x77mm (Head Width)
·800-gram weight (excluding batteries)
·Digitally regulated output - maintains constant brightness
·Reverse polarity protection guards against improper battery installation
·Intelligent thermal control to protect the flashlight against over-heat
·Tri-color displays indicate the running level and the remaining power with low-power warning
·Anti-roll and slip-resistant body design
·Independently–controlled lighting heads permit easy and fast operation
·Instant Turbo activation for immediate illumination
·Made of durable aircraft-grade aluminum
·Premium Type III hard-anodized anti-abrasive finish
·Toughened ultra-clear glass lens with anti-reflective coating and quality PC lens
As I received a review-sample, I only received the light itself. There are some pics out on the internet, where you can spot the box it comes in.
The Light:
Size and weight-wise it's comparable with the TK75. It isn't a lightweight light, but also not that heavy that a shoulder-band is needed.
The TK76 has 5 buttons for the UI. It looks difficult, but with 5 buttons Fenix have made is easier instead.
With the red-button you turn the light on and off. If pressed all leds will turn-on at the Lowest level.
Hold the red-button for 1 second and it will turn into Strobe mode, hold it for 3 seconds and it goes into SOS.
The yellow-button (or panic-button as I call it) with turn all leds at Turbo on. Hold the yellow-button for more than 5 seconds, and the light stays on at the Turbo level.
The other three buttons correspondent with the leds in front of them. From Off, press and hold to turn-on. Press ones to cycle between Low-Med-High and Turbo.
Hold again to turn-off.
With this UI, Fenix also included a led level-indicator. Each led has his indicator. One bar means Low-mode, four bars means Turbo.
This makes it very easy to see (with daylight or at night-time) in which mode you are in.
But, Fenix didn't stop there. From Off, double press the (middle) button of the Spot-led, and you get a battery-level indicator.
Four bars means you are OK, and with one bar- you really need to charge your batteries
At the underside of the head, there is a tri-pod mount available. This comes in handy, when you need to light a (large)area for long period of time.
The light can head-stand but is a little bit wobbly. The part of the spot-led (middle led) slightly protrudes from the rest of the body.
The TK76 supports the extender-kit Fenix has for the TK75. I've confirmation from Fenix, that they won't come with a special TK76 extender-kit. So, you can install the TK75 kit, but
you will have two different knurling-styles on your light.
Some reviewers received their TK76 sample with corroded screws. Because I received a 'later-version' I assume Fenix has taken care of this.
The Battery-carrier looks the same, as the one inside the TK75.
Both the right and left led have a optic in front. The right optics, gives a 60 degree beam-angle while the left led give a 120 degree beam.
Due to the wide-angle, almost every thing in front will be lit up. To get an idea, the road you are standing on, will be lit from left to right with every side-led.
Of course, with the left led it's wider than the right one.
The leds are accessible from the outside. This is easy for the mods. It does looks like my right-led isn't a XM-L2 but a XM-L. More reviewers have this.
Fenix notes, on the final light all leds will be XM-L2.
AND THEN.. Finally.. the beamshot (yeah, I hear you )
I had a hard time to get the Low-mode, good on a picture. After 10 minutes of trying, I found-out it was a can't-do for my camera.
Do hope the shoot them soon inside my house, for comparison.
(note: both wide-angle led beamshots don't include Low-mode at this moment)
Fence at the back, is around 10 meters from the camera. Trees around 18 meters.
Control-shot: (Photos shot around 17:00Hr)
Left-Led:
Spot-Led:
Right-Led: (neutral)
All Leds on Turbo:
Size-comparison:
Having this light for about two weeks now, it quickly became one of my go-to lights. Having the choice between a wide-beam or throw (or combi) suites me well.
The three leds are working nicely together, and don't disrupt each other.
The TK76 does have 200 lumens more than my TK75, but overall the TK75 does light-up a larger area (because of the bigger reflectors).
The TK76 is in a class of his own. The aren't many lights out there, where you can directly compare it with. Fenix did a smart move with putting a neutral led in it.
And because of the leds are easy accessible for mods, I'm sure we will see full neutral or even full warm-white TK76's soon.
Overall Fenix did a really good job on this one. And before I forgot to mention; Yes, it does look like something out-of Star Trek
But that does make it different than all other lights
First left led from Low to Turbo, then right led from Low to Turbo. At the end I combined both side leds on High.
Video doesn't do justice to what you see with your eyes.
- Review-sample provide by Fenix -
The Light:
Left-Led:
Spot-Led:
All Leds on Turbo:
Size-comparison:
